Question about Acer TravelMate 2300 Notebook
Acer travelmate(belongs to my grandson), one rear usb three side mounted. Rear socket had been damaged, plastic contact support missing, pins touching case. Before I looked at it, notebook crashed if any USB port used. Cleared pins touching case and tried memory stick in side mounted ports. PC did noot pick up stick. Tried connecting Digital camera - 'USB error' comes up on camera. Have checked Device Manager and all are shown as workoing correctly. Tried un-installing and letting XP pick them up again. Picked up and showing as working correctly but no dice when try to connect to any port. Help please
  • Mike Waldron May 11, 2010
    By 1 of the USB ports shorting out, they,re probably all inter-connected. hence blown fuse on motherboard to USB Ports.
    Test with a multimeter. 5volts on 2 outer pins of USBs.
    Mike @ Compurepair.
  • 520 Answers
Motherboard dont have fuse has diodes which act similar to fuses but wont be blown.only things that will blow in that area are transistors or capacitors;but if these were blown usb's would not be detected.
in device manager were its says working correctly it relates to software istalled and working properly it cant tell u that the hub connection is damaged internally.
if your usb's are on card and connected to motherboard they can be replaced otherwise if built into motherboard youll have to take it to repair shop.
if the only problem is when u connect a usb device and not causing any other problems,u could use usb hubs that go into the pcmcia
Posted on Apr 12, 2008
Right turn signal quit working on my 2011 Harley heritage Flstc . I am having trouble finding the fuses. Looked under the seat, side panel. Where the heck is it.
Hi Jim, there is a black plastic box behind the battery lift the top up and away to access the fuses, before diagnosing any turn signal issue make sure the bulb is good and the light fuse has continuity. If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion. If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function. If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction. If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, (the harness connector is usually located under the seat on the front of the rear fender) then keep tracing the wiring look for obvious harness damage caused by the rear tire. If you still can't find the malfunction backtrack from the rear fender wiring harness connector. If one side does not work you could have a faulty turn signal switch or module check for continuity. For more information about your issue, please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day. http://fullmanuals.com/search/?q=2011+Harley+davison+heritage+softail
Sep 01, 2015 | Motorcycles
Ports on acer travelmate 4200 not working?
sounds like you may have driver for usb ports missing. check in device manager and see. if so simply reinstall drivers
Aug 12, 2012 | Acer TravelMate 4200 Series Laptop Charger...
I keep getting a blown fuse belonging to the left side rear and side lights. The fuse should be 10AMP. I have tried 15 AMP and 20AMP fuses and those also blew. Any ideas? By the way, this car is a...
First put the required fuse dont go up you do more damage, For a fuse to blow you left rear side light and side light has shorted out to ground. left side rear light look at the wire are there any exposed, If no go to the side light inspect the wire are the exposed, if you see any repair it, Now if fuses keep blowing go the lamp belonging to that fuse and pull the bulb out with the bulb out an fuse installed twist the socket one at a time did the fuse blow,if it did you found the source,more than likely you ll need a bulb socket, as long as the wire are in good shape . Remeber correct fuses,No foil No nails No other Range just the required fuse
Apr 26, 2011 | 2000 Suzuki Esteem
Any time I plug anything into any of the usb ports on my Advent roma 4001 my laptop switches itself off. Please help!
If the laptop switches off as soon as you insert the usb cable, there is a problem with either the usb socket or the cable. It is a safety system which stops usb power being re-directed down the usb data lines.
If you have tried multiple cables with the same result then the problem is with the usb socket. try a different socket (a usb hub will help if you are short of spare sockets).
Using a mall light, and maby a magnifying glass, inspect the usb port for bent pins or contacts, some sockets have pins (older dell machines especially) which are not supported at all by plastic backing strip and can be bent easily by inserting the usb plug incorrectly or by children armed with a pen etc.
If you find bent pins (there should be 4 pins evenly spaced or 4 metal strips along a plastic backing peice) remove the battery and attempt to realign the strips with a small screwdriver. switch the laptop on and try a usb plug in the socket - make sure you insert the plug gently and squarely (and the right way round). If the laptop still fails, have another go or ask someone else (who is nimble fingered and technically minded) to try it.
Don't give up (unless you find the socket is broken ie. missing pins) I can guarantee 99% that this is the problem.
good luck
Jan 19, 2011 | Advent Computers & Internet
Do I remove the entire cover or the little door thats atached to this cover on the passenger side? There are 3 brake lights that were recommended to replace. Driver side and passenger side plus the third...
Lamp, Rear Hi-Mount Lamp Assembly
Removal
  1. Disconnect the battery ground cable (14301) .
  1. Raise the liftgate.
  1. Remove the liftgate door trim panel (46404) . Refer to Section 01-05 for the removal procedure.
Trim Panel, Liftgate Door Removal
  1. Disconnect thebattery ground cable (14301) .
  1. On vehicles with a rear window wiper, remove the three rear wiper motor cover screws and remove the rear wiper motor cover.
  1. Pry the liftgate door trim panel (46404) away from the liftgate.
  1. Disconnect the luggage compartment lamp electrical connector.
  1. Rotate the rear hi-mount lamp socket counterclockwise and remove it from the rear hi-mount lamp (13A613) .
  1. Remove the two rear hi-mount lamp housing nuts and remove the rear hi-mount lamp lens and housing.
Oct 18, 2010 | 1995 Ford Aspire
How do I change a rear turn signal bulb in a 1994 lincoln mark vii
1994 was the mark viii. here is what you need to do.
Lens/Bulb, Turn Signal-Rear
Removal and Installation
To remove the plastic socket, turn the socket counterclockwise to the stop, and remove the socket. Remove miniature bulb from socket. Install miniature bulb in socket. Index the smallest tab for locating the three locking tabs, then press the socket into the rear lamp and rotate clockwise to the stop.
  1. Remove retainer (unscrew) attaching the luggage hold down net and luggage compartment side trim.
  1. Pull trim down to expose the lamp attaching nuts
  1. Hold rear lamp in place and remove the three attaching nuts.
  1. Pull rear lamp away from vehicle far enough to remove the two lamp socket and wiring (13410) and remove the rear lamp .
  1. Replace miniature bulbs , if necessary.
  1. To install, reverse Removal procedure. Tighten nuts to 5.2-7.2 Nm (46-63 lb-in
Sep 23, 2010 | 1994 Lincoln Mark VIII
... I cannot remove the right footpeg post from
Hi Dtravis13, this is a moderately easy fix but you are going to need a service manual for torque specifications and clarification please visit website below for $6.50 download.
1. Remove exhaust system.
2. Remove the screw and clip to free the brake line from the sproket cover.
3. Remove the two socket head screws and lock washers to free the rear brake master cylinder from the sproket cover.
4. Loosen the locknut and turn the brake push rod at the flats untill it is free of the rod end.
5. Remove the three sproket cover screws and washers. As a single assembly, remove the sprocket cover, footrest mount, rear brake pedal, and master cylinder stiffner.
6. Remove cotter pin and nut from footrest mount. Use blue Lock Tite on threads and torque footrest mounting nut to 40 ft lbs. replace cotter pin and assemble in reverse order. Good luck and have nice day.
May 24, 2010 | 2001 Harley Davidson XL Sportster 883
Acer travelmate 290 beeping, starts with blue screen and then black and beeping
See if there is an error beep. If there is an erro beep, then change
main board.
Power off. Then check if RAM CPU BIOS are well-connected.
Press Fn+F5 three times slowly
LCD FPC
LCD inverter
LCD
USB does not work correctly USB device cable is firmly connected into the USB ports. Test
Oct 29, 2009 | Acer TravelMate 290 Notebook
The prop will turn on my minn kota endura 44 but it has no power is there a shear pin on this motor
Odds are you have sheared the pin (slides through the prop shaft) holding the prop, or you have damaged the slot on the prop that the pin sits in.
Prop is secured to the shaft with a metal nut, or flat plastic wing nut. Remove the nut to remove the prop. You may have to pry, slightly, the prop from the motor housing. Removed, you will see a whole in the shaft where a pin should be located. If the pin broke, it probably hit the floor when the prop was loosened. If the pin is intact, examine the rear side of the prop and look for damage to the plastic slot where the pin would sit making contact.
If you've snapped the pin, you can make a replacement with a nail using a hacksaw. Replacement pins can also be ordered from Minn Kota. If the back side of the prop is damaged (recess for the pin to sit), the prop is toast. Replacement props are often carried by Walmart, and include a new pin.
If neither part is broken, perhaps the prop was just not seated on the pin correctly allowing the prop to freewheel.
May 04, 2009 | Minn Kota Endura 30 Freshwater Transom...
2001 Sportster 883 Hugger Right Footpeg post
Hi Bkocher, this is a moderately easy fix but you are going to need a service manual for torque specifications and clarification please visit website below for $6.50 download.
Feb 11, 2009 | 2001 Harley Davidson XL Sportster 883
Computers & Internet Logo
138 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
