Samsung DLP 1080I
My screen has a rectangular shadow which covers 95% of the screen. When the TV is off the red light of temp stays illuminated. I unplug the TV for 30 minutes with no resolution of the problem when replugged and turned back on.
Change P T C after replace ptc if problem same then crt may be defective.
Posted on Apr 05, 2008
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Samsung dlp hl61a650c1fxza turned off in the middle of the nfl playoff game. Turned it back on and the blue on/off button stays lit but the three lights (red, green, green) blinks constantly with no...
Hey dsfrank6088, i have the same issue right now. I called tech support and they are telling me that i need to change the light bulb which i did less than 3 months ago. Please let me know if you did find a solution!!
Jan 19, 2011 | Samsung HL61A650 TV
I have a SamSung HL-S6187W DLP whide screen tv
You need to replace the light tunnel.you will need to remove the lamp and color wheel along with the lamp housing and fan housing to replace it .If you are not comfortable taking things apart you might want a tech.
Nov 30, 2009 | Televison & Video
The temp light on my Samsung DLP tv stays lit. Is
No. Refer to your owner's manual on cleaning. You may have dust buildup around the vents or you aren't providing adequate ventilation for the unit.
Jul 23, 2009 | Samsung DLP HL-P5663W 56" TV
I had a 73' TV that was1080p. Well I got a brand new DLP that is 1080i. My settings on the PS3 are set to 1080p. How do i set them to 1080i if I can't see the screen?
Use the original composite (yellow, red, white) cable that came with the PS3 and connect to a composite input on the TV. This way you can see the setting for the PS3 and make your changes. Hope this helps.
Dec 24, 2008 | Samsung DLP HL-P5663W 56" TV
1080p to 1080i
Shadow top to bottom of screen on left side about 2" wide...
This can be the sync wheel assy, failure in the drive circuit for the display chip, or an illumination fault. You will have to give the set out for service.
Jerry G.
Nov 26, 2008 | Samsung DLP HL-P5663W 56" TV
Mitsubishi WS-55809 Shadow
check the "close caption" option on the menu should be of
Oct 14, 2008 | Mitsubishi WS-55809 55" Rear Projection...
My samsung 52" flat lcd hd tv
yours DLP TV not a LCD.
LCD has on one light with red.
If the DLP likes that.
1st -- check the thermostat
2nd -- check the power board.
Jun 10, 2008 | Samsung 52 in. LCD Flat-Panel HDTV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
