Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
How do I reset the timer
My fridge is blowing the electrical fuse. It goes after I turn the red knob about 20 clicks for about 6 hours then blows the fuse again. can you help please, I recall having a similar problem some years ago and the technician told me to turn it a specific number of times to reset it.
  • 30 Answers
Problem likley to be defrost heater, the timer energises defrost heater every 6 to 12 hours depending on timer model ,replace defrost heater....this will solve your problem...
Posted on Jun 08, 2010
Why does my mower keep blowing the 20 amp fuse
could be the safety switch for the pedal
Apr 23, 2012 | Husqvarna Garden
I replaced the thermal fuse because there was no heat. Now the dryer over heats and shuts off. Everything checks ok on ohm meter. The timer works in the "no heat" mode. Could it be the timer...
after you changed the thermal fuse did you clean out the dryer and the vent line?if not you blew the fuse again and it will keep doing this until you clean out the duct that the lint filter slides into,vac and blow out the motor and the cabinet where the motor is and blow out the vent line,if it's a long run remove the vent line from the back of the dryer and blow it out with a leaf blower.the dryer went over 300 degrees from lint buildup and popped the thermal fuse,it's a safety so the dryer doesn't run hot and start a fire.if the dryer is running and sfter like 20 minutes it shuts down and won't start for a while until it cools down then the motor is bad also probably from the dryer running to hot from the lint build up.
Apr 08, 2011 | Amana DLE330RAW Electric Dryer
The timer will not advance, it heats up on the correct settings, but will just stay on indefinately. Sounds like a classic Timer issue, but just want to ask for a second opinion, and ask what the part...
We have a dryer ( could be any make! ) that is consistently blowing fuses after about 15-20 minutes. We have taken the dryer apart to check for clogs in the venting system and to check if the heating core was okay and they seem to be fine. Any ideas?
Blowing the house fuses? If yes....the dryer usually will blow a fuse right away if there is a problem in the dryer....more often than not a fuse that blows after the dryer has been running a while it is a fuse box issue. A test: Put 2 new 30 amp fuses in and run the dryer with the heat on for 5-10 minutes, turn off the dryer and quickly remove the fuses from the house fuse box and see if they are hot at all ( especially on the bottom )....if the fuses are getting hot they are probably melting the fuse link and not really blowing = fuse box problem.
As for most things there are exceptions....a grounded heating element -may- blow the fuse after the dryer has been on for a while, it is easy to test for that as well. See. A burnt/loose power cord/plug -may- also give this type of a problem.
Dryer basics- Venting problems and power supply:
Most dryer "to long to dry" or "poor/low heat" complaints can be traced back to a bad or poor venting system and sometimes a poorly maintained lint filter. Do not go outside and put your hand under the vent opening and say " it is fine - I feel air coming out"...that is not good enough...take your venting apart, clean it ALL out and make sure the vent hood flapper works and that it is not clogged with lint. Make sure your venting system is short, straight and resistance free as possible. A poor venting system will shorten the life of your dryer, plug up the fan blower and duct work inside your dryer as well.
Gas dryers need 120 volts to operate the whole dryer. Electric dryers need 240 volts to operate the heating element and 120 volts to operate the timer and motor. You should see 240 volts between the black and red wires, 120 volts between the red and white wires, 120 volts between the black and white wires at the electric dryer main power harness. A blown house fuse ( or breaker ) would stop a gas dryer from working at all. A blown house fuse ( or a 1/2 tripped breaker ) would still allow the electric dryer to run but you would get no heat. Depending on which fuse goes, sometimes the dryer could be dead as well. If you have problems with a fuse letting go or a breaker tripping after the dryer runs for a while, normally the problem is not in the dryer but is in the fuse box.i think it will work
Dec 16, 2010 | Dryers
Intermatic ej351, i ned the instructions for resetting the timer. to turn it on at 630pm and off at 100am pleae
1) Use this procedure to automatically program, letting switch timer "record" ON/OFF activities over 24-hour period.
-Move control lever to OFF-CLEAR for about
20 seconds. Red indicator light goes off and previous
time settings are cleared.
-Move control lever to ON position. Red indicator
light starts flashing.
-At 6:30pm, manually press dial 'on' >>> then at 1:00am manually press dial 'off'
-At the end of 24-hour period, switch timer is programmed and Red indicator light will stay ON, indicating
switch timer is in AUTOMATIC mode.
2) Or you can manually program times using instructions from page 1 of manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Sep 19, 2010 | Hardware & Accessories
The fridge is blowing the 12 volt fuse as soon as I power up the motor home, The fridge is turned off and it still blows the fuse, I tried to undo the 2 wires that go to the 12 volt block on the fridge and...
Unplug the wire located at terminal J4 (12v positive) on the control board, and see if you are still popping fuses. If so, then the fault lies between the wire you just removed and the fuse that keeps blowing.
If the fuse holds, and blows when you plug the wire back onto J4 terminal, then unplug the wire(s) at J2. These go to your door heater (used in humid conditions to remove condensation), as well as the interior light. The switch for the door heater is located on front panel, or is at the top edge of the freezer compartment with door open. It is not unusual for this switch to have issues since it gets chilled and moisture condenses on it. If unplugging the wires at J2 allows the fuse to hold, you probably got a shorted heater or bad heater switch. But, pull the lens off the interior light, and check the contacts there as well.
If the fuse still blows with J2 removed, then unplug the connector in the top left corner of the control board. This goes to the control panel on the inside of the fridge. If the fuse blows, replace the control board. If the fuse holds, the replace the control panel.
Jul 13, 2010 | Dometic RM2652 Refrigerator
Bostitch compressor won't start
it has a reset button somewhere and usually a fuse. take the cover off (unplugged) and look for a red reset button or a fuse. if it keeps blowing the fuse or tripping the reset then it will likely need service by a service center.
Jun 03, 2010 | Stanley FactoryReconditioned Bostitch...
The circuit breaker for out kitchenaid glass
Water probably did get into the switch(es). The best bet for a fast fix is to pull the knobs off and use an air can (like for blowing dust out electronics) to blow down into the holes. This will dry out any water in there and should allow you to use it again. To be extra sure, blow out the switches and leave the knobs off over night. In the morning the knobs can be replaced and the cook top should be good to use. Hope this helps!
Dec 11, 2009 | KitchenAid 30 in. Architect KECC507KSS...
Epson 7300
Hi there
The Epson Powerlite 7300's lamp has got a chip on the side of the lamp's bracket that resets the lamp timer automatically when a new lamp is inserted. And it only does it once - first time the unit is switched on after replacing with a new lamp.
The fuse on this chip blows and causes the lamp timer to be reset. Unfortunatelly this is the only way to reset the lamp timer on this model. There is no manual way.
So to cutt to the chase , you will have to buy the original lamp and replace it before it will reset.
Part Number is : ELPLP05
Apr 17, 2008 | Office Equipment & Supplies
Sumsung top fridge and bottom freezer
Hi, The infeller struck to build of ice , causes the the beep sound ,defrost manually by two hours put electric fan to fast defrosting ,set rotate knob to defrost , you hear sound cracking of ice and smell burning that was could heating element for defrost if you hear sound like that in manual , later set automatic if timer will not turn you may replace timer .
Jan 20, 2008 | Samsung RS2578BB Side by Side Refrigerator
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
224 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
