Question about Denon AVR-3200 Receiver
My denon avr 3200 receiver has a constant overload red light on in digital mode. Is there a way to try to reset this. Can i listen to the dvd player in non digital mode. How would i connect that.
  • conic395 Aug 08, 2010
    Analog mode works ok ?
5 Suggested Answers
tech48
  • 624 Answers
SOURCE: Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Posted on Jun 22, 2008
mattvierra
  • 74 Answers
SOURCE: Denon receiver AVR-3300: Unstable source selection
Very important you have run system set up menu it configures your receiver with inputs analog or digital,speaker size,input,room correction etc Different input modes can be selected for the different input sources.
The selected input modes for the separate input sources are stored in
the memory.
q AUTO (auto mode)
In this mode, the types of signals being input to the digital and
analog input jacks for the selected input source are detected and
the program in the AVR-3300’s surround decoder is selected
automatically upon playback. This mode can be selected for all
input sources other than PHONO, MD/TAPE and TUNER.
The presence or absence of digital signals is detected, the signals
input to the digital input jacks are identified and decoding and
playback are performed automatically in DTS, Dolby Digital or PCM
(2 channel stereo) format. If no digital signal is being input, the
analog input jacks are selected.
w PCM (exclusive PCM signal playback mode)
Decoding and playback are only performed when PCM signals are
being input.
e DTS (exclusive DTS signal playback mode)
Decoding and playback are only performed when DTS signals are
being input.
r ANALOG (exclusive analog audio signal playback mode)
The signals input to the analog input jacks are decoded and played.
t EXT. IN (external decoder input jack selection mode)
The signals being input to the external decoder input jacks are
played without passing through the surround circuitry Your remote is searching for inputs because you did not properly run system set up!!! Here is a link to your manual [PDF] AVR-3300/1 3.3E*
Posted on Jul 22, 2009
SOURCE: Denon RC-980 subsitute remote for Denon AVR-3200
I have a remote left over from my denon ACR3200. the remote is RC-825. It is currently listed on Ebay.
Posted on Jan 10, 2010
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
Denon AVR-3200 wont go into standby mode
Not sure what you mean by standby mode. The power button on most of the audio remotes I deal with merely turns the equipment on and off.
Nov 24, 2013 | Denon AVR-3200 Receiver
Only red light is blinking on my denon avr 1508
It sounds like you overloaded the Denon avr with too much resistence from the speakers. Please check the total resistence of the speakers before you connect them all. Also check that the speakers or their wires are not shorted!
Jan 20, 2013 | Denon Audio Players & Recorders
How can i run speaker test tone without a remote for a Denon avr 3200
The setup mode can only be entered using the remote on this model of Denon receiver
Mar 10, 2012 | Denon AVR-3200 Receiver
I have an avr 3200 can it use 2 coaxial inputs and how good is the sound quality compared to newer avrs
Denon being one of the best names in the biz and this being an upper-crust modfel, I'd say anyone without a 'golden-ear' would be hard pressed to t\distinguish its sound from any other amplifier in existence.
The Denon site doesn't list and AVR-3200, but the AVR-3300 has 1 coaxial digital audio and 3 optical digital audio inputs.
If you're looking to run multiple coaxial devices and there aren't enough inputs this is what I do...
Helpful hint: Coaxial digital audio cables can be joined using an RCA cable splitter so they can share a given input or distribute a given output to multiple places. You just have to remember to have only the DESIRED units turned on when sharing or there will be digital confusion on the buss and it will result in silence or horrendous noise.
Jan 15, 2011 | Denon AVR-3200 Receiver
I own a Denon AVR-3200 circa 1998. No sound output. Red "Standby" light constantly lit. Tried unplugging the power cord (not the other cables attached to powered units) and light remains red. ...
bbkaufman
If the light is staying on after you unplug the AC power this means you have a short in the loop some where that is giving power to the receiver.
Try unplugging all connection to the receiver except for your speakers. Next hold down the power button for 45 to 60 seconds. Doing this will clear the flee power off the system board. Next plug back in the AC adapter and the receiver should turn on. If it does not then there is a problem with the receiver it self. If you did have a device shorting/grounding out to the receiver over time it would have damaged the receiver.
Let me know how things go
Issken
http://www.fixya.com/users/issken
Sep 08, 2010 | Denon AVR-2802
I just purchased a used Denon AVR-3200 and have nothing hooked up yet but plugged it in on my kitchen counter and upon turning the unit on, noticed the error overload button was lit up but the unit did not...
Hi
I've had an AVR 3200 for about 10 years - occasionally (maybe once every 6 months), the error overload button comes on... for no real reason than i can detect (ghosts in the machine, maybe)... rebooting has always fixed it for me.
Aug 21, 2010 | Denon AVR-3200 Receiver
Dec 24, 2008 | Audio Players & Recorders
215 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
