Question about Boating
Motor just raises on its on while all switches off already took to 3 diff boat mechanics all certified. Stil same problem
  • 5,546 Answers
There not much here to work with. Outboard? I/O? What brand?
It sounds like a hydraulic bleed problem. The thrust of the engine is compressing the hydraulic fluid back to the reservoir. Then some valving is leaking and the fluid returns to the lift cylinders and raises them.
The strange part would be the storage of the high pressure fluid. You are suppose to need a pump for both directions. You might want to check the vent for the hydraulic reservoir. Anyway, the line pressures can be gauged.
Posted on May 15, 2010
Yamaha outboard 90/65 4stroke jet only getting 5000 rpms. New motor with 6 hours on19' flat bottom boat. Tach is flashing a engine symbol. Suggestions?
The amount of RPM's on a boat motor depend on a number of things...
1. Height if the motor in relation to the bottom of the boat. - too high and it over rev's.. Too low and it won't rev..
2. The correct size (O.D.) of the prop. Too large and you have mechanical interference or too large for the motor to spin...- ..Too small and the motor will over rev!!
3. The correct pitch of the prop. - Too large/big of pitch and the motor can't spin it..-.. too small and it will over rev the motor.
..... these are the big three...
Now, Make sure the carburetor butterfly(s) are opening exactly flat or vertical ...and not under/over opening..if this is a fuel injected motor...have the dealer check it out..
Jul 11, 2017 | Boating
We have no power but battery appears full charge cannot raise/lower motor or start motor--any thoughts
Hi Jim:
I'm confused.
Raise or lower motor sounds like a boat outboard leg.
Cars and trucks section???????????
I'm guessing that you first need to confirm that the battery is fully charged.
Just an idea, but boats often have an isolation switch that has to be turned on before power is available to the engine. Follow the positive lead from the battery.
Please reply as a comment to this post so I can try to assist.
Cheers
May 08, 2016 | Cars & Trucks
Troubleshooting bass tracker boat
kill switch possibly problem.
Jun 26, 2013 | Boating
Powertrim tilt
the switch on the throttle arm is probably stuck or shorted from the wash down
May 23, 2013 | Boating
Wiring diagram 3/4 hp boat lift motor
It will be dependent upon the line voltage and switching mechanism...
Please advise drum switch or relays?
115V or 230V
Remote control present?
If a drum switch, is it a 6 or 12 terminal model or some other configuration?
Make and model of the switch?
There may be more questions depending on the answers to these...do you have a wiring diagram for the control? Are you replacing a motor and have the old and new motor schematics?
John
Apr 10, 2011 | AO Smith A O Smith Motors Century 1hp 115v...
How to manually raise 200 hp 1995 johnson motor
Mate.Have a look at the bolt holes on the transom.If there is some that are lower than the holes used,no problem.Lower your trailer at the front all the way to the ground.Loosen the transom bolts.2 should be in holes,2 should be in a slide hole.Chock the motor under the skeg.Remove the 2 bolts that are in the holes and very slowly raise the front of the trailer.The motor being 'chocked'.will then rise as you lift the trailer.If you run a line from the bottom of the boat through to the middle of the g/box a cleaver prop should be about 2.5 inches and a chopper prop can run up to 5 inches on a really quick boat.This is for 3 blade props.Make sure when the bolts go back in,plenty of sealant.Hope this helps
Jul 13, 2009 | Boating
Boat outboard outdrive power lift only goes 1/3 way up then stops
There is a 'trailer' or some such labeled switch (usually on the side of the throttle) which you need to push in order for the motor to go all the way up. It stops at 1/3 because it thinks it's in the water. If you push that switch with no better result, then a related wire may be broken or disconnected.
Apr 19, 2009 | 2008 Mercury Mariner
Boating Logo
37 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
