Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Are those right?
Woke up to broken tv this morning, I was wondering if the replacement numbers you typed were right or miss typed the correct ones are stk392-040, stk392-010, your saying these numbers convert to stk392-140, stk392-110? just trying to clarify since i will be purchasing chips. oh one more thing when i replace chips does the tv automaticaly reset to factory settings or do i have to do anything with the settings of the tv?
  • Samsung Master
  • 8,617 Answers
No STK392-040 will not change to the 110. STK392-040 and STK392-010 are the same chip except the 040 is a better chip more durable. Use both STK392-040 they last alot longer. You will need to do the perfect focus after replacing the ICs but thats it. If you order through the link I provided you will recieve the instructions as well as free support while your doing the repair via online chat. Thats a good service. heres the link I dont remember if i posted it before for you.
Posted on Mar 30, 2008
What's your question?I have a 50" inch bauhn TV,I woke up one morning to realise the TV works well with sound playing but the screen is very dark.what do I do.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 09, 2015 | Televison & Video
No power even to light inside refrigerator
Check the fuse in the plug to the fridge and replace only with the same type and values. Unplug and check the cable for signs of damage.
Apr 05, 2014 | Refrigerators
I have a 2010 50" Samsung plasma hd 3d tv. I woke up one morning and had no picture. I had sound and could change the channels and listen to whatever was on, just no picture. no picture in menu, or source...
It is not an easy task to repair a Plasma TV, for any inexperienced user. It will be best to contact any service technician. If you're sound in electronics, and wish to get more details, check this link. Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 20, 2013 | Samsung 50" Plasma Pn50c7000yf Main Logic...
3 inches of black on both sides of my monitor
I have seen this when using HDMI cables from the computer side.. The TV has a resolution that is not always full screen with TV shows. There is a setting that allows you to "zoom". My TV has 4 settings: normal, stretch and crop, stretch left and right, stretch and pinch (shrug).
Jul 07, 2009 | Hansol (720ESB) (Black, Silver) 17 in.CRT...
Cell phone
if you are good at opening then just open and check the keypad sensor might have got displaced ... if so then correctly place it ...
or may be the key pad buttons are not in contact correctly with the sensor board ...
if so just place it correctly & check whether the keypad is right or not ... if not replace with the good one ...
it will surely work ...
Mar 31, 2008 | Cell Phones
Television won't come on
Could be as simple as a blown fuse, but if you know so little about TV's, go see a serviceman!
Mar 27, 2008 | Durabrand DWT1905 TV
check the ac wire if it is plug properly.make sure it have energy power in the outlet.if it has,then open the unit and look the fuse on the high voltge.if the fuse is bad.replace it.after
Dec 29, 2007 | GE 25GT240 25" TV
LCD has no light neither does outside LCD
Hi Robin I am sure 100% that your LCD Cable has broken. That is the common problem for most Flip cell phones because the LCD cable is connected one side on one end of the flip and the other end to the connector under the board below the keypad. Therefore, several open and close times the flip will cause the cable is broken one day. I has showed it common on most Motorola V-series phones and all other models so your are not an exception. Now, the only solution is purchased the new LCD cable and replace it.. If yo can provide me your phone model, I can send you the link to show you how to disassemble you r phone and how to replace it. I hope my repair list has your phone model. If you can still dial the number and still can receive a call, I can be 100% sure you need to only replace the LCD cable. Email me at so I can send you the instruction.
Mar 05, 2007 | Audiovox CDM8910WW
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
111 people viewed this question
Jerry Greenberg
Jerry Greenberg
