Question about Nikon Speedlight SB-800 TTL Flash
LCD moniter locking up on SB800
Just sent in the flash unit to be repaired, and I got it back and it is still malfunctioning, just not as bad.  When I go into custom settings to put the flash on REMOTE (to shoot in commander mode on my D300), It always locks up once I put it on remote.  I can put in on Master and Master RPT just fine, but it always freezes when I put it on Remote.  Also, when I put it on SU-4, it just starts firing away, and I can't get it to stop without removing the batteries.
I'm bummed, I really needed this for a shoot today.  Should I just call the company that repaired it?
  • Matthew Reilly
    Matthew Reilly Oct 30, 2013
    I am having the same issue here, did you ever get it resolved? if so what did they say the problem was?
    Genius:
  • 1,691 Answers
I would pack it back in to the box with a detailed description and send the flash back!
Jerry G.
Posted on Apr 19, 2008
SOURCE:
Tip
DLP TVS
I get many calls every day from customers that the lamp light is flashing and they want to charge the bulb alone. I also get many calls everyday from customers that have bought that new lamp from a web site and installed it themselves and the unit still does not work why? A word of warning any malfunction with the color wheel or the ballast will cause the lamp light to flash, and what is even worst allot of the units you can not change the color wheel by itself it is inside the light engine a costly repair
on May 18, 2010 | Televison & Video
Tip
Dlp tv
I have found since the dlp televisions have come out customers want to change their own lamps. This saves them money and techs time to work on other problems, many customers make the mistake of not putting the door that houses the lamp back on before trying the unit. the latch mechanism must be in tact or unit will still flash lamp light bad.
on Apr 27, 2010 | Televison & Video
MY TV WENT OUT LAST NIGHT THE POWEWR LIGHT JUST FLASH AND NO PICTURE IT IS A SHARP LCD 32 '
Hello; Your model # shows that is a 30 in. set. First try unplugging both pieces and plug both back in a minute or longer (doesn't matter). If still bad, your monitor has bad inverter boards or main unit. The set has 2 or 4 of them. You must replace all. About $700.00. Sharp told me to replace all 4 , but I was able to force them to stay on, which proved they were OK. Later I took in the same model for repair. I swapped the main units ( the big board in a metal box ) and my first set started working! The Main unit is not available, but it can be sent to Sharp for repair ( about $250 - $300 ). The swap that I did proves the problem can be inverters OR the main unit. A lot to gamble with here! You may find these boards cheap on the net ( EBAY, Shop Jimmys dot com & many others. To get your part #'s go to Encompass Parts dot com and key in your model # . John
Oct 06, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Just cleaned the unit. (Which I have done several times.) When pluging the unit back in I had the lcd display say the unit was in away mode. I pressed the buttons on the front to change the mode to 2500 sq...
Oops. It's possible that the incorrectly inserted plate caused the machine to malfunction. It may need to be sent to the factory so the computerized controls can be recalibrated. Call Vollara (new name for EcoQuest) Customer Service 800-989-2299.
Jan 31, 2011 | Ecoquest Fresh Air Living Air Purifier
The Xbox power button is flashing a red colour around it when turned on
You have what is commonly known as the "Red Ring of Death" There are a few different types of rings (denoted by which actual quadrants of the ring are lit), the most common one can TRULY only be fixed by an experienced tech. You should eject any discs, turn it off, eject the hard drive, take out any other storage devices, unplug all cables from the unit, and mail it to Microsoft for repair. Hopefully it is still under warranty. I got a refurbished unit sent back to me just a week after I sent my own off to them when this happened to me a couple years ago, I had a custom face plate on mine so I had to remove that as well when I sent it in because I was not guaranteed to get my actual unit back.
Nov 01, 2010 | Microsoft Xbox 360 Console
Nighthawk carbon monoxide alarm model KN-COPP-3. ( ERR appears in the window, what does this mean ....
Readings You May See When Unit is AC Powered
Display Shows Alarm Sound Unit Status Recommended Action
Steady "Err" "Chirp" every Unit malfunctioning when Call KIDDE customer
and flashing dot 30 seconds AC powered service at 1-800-880-6788
Readings You May See When Unit is on Temporary Battery Backup
Flashing dot None Normal battery-only operation - Plug in to AC as soon as
unit will show reading only if it possible to conserve battery
senses CO
Flashing dot and "Chirp" every Unit malfunctioning when Call KIDDE customer
"Err" 30 seconds battery powered service at 1-800-880-6788
Hope this helps. Manual is here:
http://www.detectorsandalarms.com/images/pdf/Manual_KN-COPP-3_900-0100en.pdf
If this helps you resolve your problem, please consider giving a good rating and a quick thanks or good job.It will help me as well Thank you.
Oct 26, 2010 | Computers & Internet
I have a Minolta 5600HS flash that I have used for four years with my maxxum 7d without a problem until recently. The flash continues to function fine while on the camera and can be set to wireless mode on...
It could be a simple connection that is loose and just need to be put back into position, or it could be a controller circuit that is bad and needs to be replaced. This is not a user repairable problem. It should be sent in for repair.
Jan 20, 2010 | Konica Minolta 5600HS for Maxxum Minolta...
Canon A640 flash problem
I sent my camera into Canon for repair. They said the flash was malfunctioning, and there was something wrong with the flash exposure control. The repair cost about $87. It took approximately 10 days from the time I sent the camera in until the time I got it back.
Jul 11, 2008 | Canon PowerShot A640 Digital Camera
Nikon Speedlight SB-800 TTL Flash Logo
106 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
