Question about Cst /Berger Lasermark LM800GR Series Self Leveling Rotary Laser Complete Tricase Package
No self leveling on LMH600 at lower temperature
Self-leveling on LMH600 does not work if temperature below 55 degrees F Eventually shuts down
How long is complete drive cycle for a 98 chevy blazer s-10 4.3
what do you mean by complete drive cycle as it is unknown terminology
Nov 18, 2017 | Cars & Trucks
Can any make of freezer be used in garage. Told only Beco
Refrigerators are designed to be used inside at typical to normal household temperatures. The problem with refrigerators are if the ambient temperatures drop down below 55 Degrees F Food in freezer will begin to defrost when the temperature in the garage goes below 55 degrees Fahrenheit. The fresh food section may begin to freeze food slightly below this temperature. If you live in an area where the outside ambient temperature does not get below 70 degrees F or 20 degrees C then the refrigerator will work fine but to have it located in an area where temperatures drop well below this you could lose some food. There are heaters that can be adapted to the compressor if used in an unheated area. Hope this helps, Sea Breeze
Jul 05, 2012 | Whirlpool Freezers No Refrigerator Model...
What is the temperature setting for normal wine cooling?
It's between 55 and 65 degrees fahrenheit. If you're storing a lighter red wine, you'd want to keep it on the lower end (55 degrees). And for the darker (deep) red, you'd want to keep it on the higher end (65 degrees). All white wines should be on the lower end, and below. You can drop down to 50 degrees if you'd like. I hope this helps. Good Luck!
Mar 29, 2010 | Emerson (025806803716) Wine Cooler
Self defrosting fridge/freezer
Good day,
That is normal if the room or area is too cold. If the room temperature drops below 55 degrees Fahrenheit then that problem will start to show up.
All manufacturers state the machine will start to unbalance below that temperature.
Mar 13, 2010 | Bosch Refrigerators
I have a Frigidaire refrigerato with top freezer that I keep on the back porch. The freezer has quit working completely. The temperature has been below freezing lately and I was wondering in this has...
Good day,
Yes, Frigidaire specifically states any temperature below 55 degrees will unbalance the machine causing the freezer to warm.
This is due to the fact that the thermostat that runs the entire machine is located in the fresh food section. When it reaches it's normal temperature it shuts the entire machine down.
In cold weather it could stay off for the best part of the dy, if not the entire day.
As well. on some model Frigidaire's, they makes a winterizing kit.
It is wired to the thermostat in a manner that heats the thermostat artificially in cold weather to cause it to cycle more.
Contact your local appliance parts house to see if they carry the kit for your machine.
Feb 17, 2010 | Frigidaire FRT21H8 Top Freezer...
What type of oil to use when changing oil
For any four cycle engine (engines with separate oil and fuel fill locations) use high quality detergents in the following viscosity.
For Briggs & Stratton engines use an SAE30 oil above 40 degrees F (4 C) and below this temperature use 5W-30.
For Tecumseh engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30.
For Kohler L-Head engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30. For Kohler Overhead Valve engines use a 10W-30 above 0 degree F (-18 C), and below this temperature use a 5W-30.
For Honda engines,10W-30 is recommended for general use, and above 55 degrees F (10 C) you can use an SAE 30.
For MTD Brand engines, SAE 10W-30 is recommended for general, all-temperature use.
(From the MTD answer pages). Best regards, --W/D-- Please feel free to rate my solution. Thanx.
Jul 25, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I also want my air conditioner to cool to 55 degrees F or 12 C
12 degrees celcius equals 53.6 degrees Farenheit. You can have a unit hard wired but I don't recommend it. There are limitions to a\c units, they really shouldn't run if the outside temp is below 60 degrees.
Jun 08, 2009 | Fedders A6Q10F2B Q Chassis Room Air...
Shutdown requested due to temperature problem-E2900
Dear,
Open the front cover and make sure all the fans are working well. If not relplace it. Check the room temperature, it should be below 20 Degree C
Apr 04, 2009 | Sun E2900 Server (E294P16GB1200)
Does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Nov 21, 2008 | Frigidaire FRT21H8 Top Freezer...
Dose not get cold enough?
Does the compressor run or shut off when it gets to 55 &57? Leave unplugged over night and try again.. Let me know.
May 30, 2007 | Danby DWC283BLS Wine Cooler
Cst /Berger Lasermark LM800GR Series Self Leveling Rotary Laser Complete Tricase Package Logo
29 people viewed this question
Top Cst Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cst Measuring Tool and Sensor Expert? Answer questions, earn points and help others
