Question about Philips HDRW720 DVD Recorder
Pictures distorted play/record mode
I have a hdrw720/05 DVR that play/records distorted pictures. When tv is directly connected to cable the distortion is no longer there. Any suggestions?
Thanks!
  • 396 Answers
Run the diagnostic software by unplugging the unit. Hold the Play while reinserting the power cord. Continue holding the Play until the diagnostic program is displays NUC XXXX where XXXX is a series of numbers. Once the diagnostics is finished it will pass or fail. To return to normal operation unplug the unit and reinsert the power cord after 15 seconds or so.
Posted on Jun 27, 2008
Why can't I record on my DVR?
Check all your connections and configuration between decoder to DVR and TV. I find it is more practical to use the DMI connectors for this purpose. Between my LG TV, LG DVR, LG Blue Ray Player and Decoder I use 3 DMI connector cables. Ideal for me because my TV has 3 DMI points, I just connect each of 3 items to TV via a DMI cable. Now connect decoder to DVR via video-audio cable (red-white-blue). This setup allows each unit to be used individually (i.e. tv viewing, recording, blue ray playing and when recording live TV the TV can be switched off while recording. Just remember to select the appropriate DMI connected unit on your TV remote (on "input" button).
Feb 16, 2016 | Panasonic Televison & Video
Snowy screen when I play a DVD
hi!!!!
try to change the cable!!!
may that helpS :)
Sep 27, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
DVD-VR357 RECORDS VIDEO (FROM VIDEO1) FROM COX DVR, BUT NO AUDIO
well there the first thing i would check is the audio connection..
basically if you are recording from a playing media, like a dvf player
it would be like this
audio and video out from the dvd player to the inputs in the recorder.. then the out puts from the recorder to the input in the tv... (just a refrence)
upload your diagram, and state exactly what you want to record from.. if its the tv or another media type..
If its from the tv,, lets say you got cable and you want to record from cable,, Its
connect the out put from the cable box to the input of the dvr, then the out from the dvr to the input of the tv..
or
if its from an arial
connect the arial to the dvr,, now connect the dvr to the tv,, I guess you got the picture of what i am saying..
Basically all the out put from the media you wish to record from to the DVR and then from the DVR to the Tv..
Feb 22, 2008 | Samsung DVD-VR357
We recently connected to Direct TV...I want to transfer some old western TV Shows I recorded on my Direct TV DVR Recorder to VCR Tape. I was told by the people at Direct TV that I would need to contact you...
You can try this: Connect your DirecTv to VCR with Red/White/Yellow cables. Then the VCR to your TV with the same type of cables. Make sure the VCR is set to the video input, not the tuner. Turn your TV to the correct video input. Get the program ready on the DVR as if you were going to watch it. Press record on the VCR and then play on the DVR. At the end of the program, press stop on both. You may have a problem with the video recording properly. Some stations broadcast with copyright protection.
Apr 12, 2011 | Emerson Televison & Video
How do I work my camcorder
What brand of DVD recorder? On my Panasonic, I use RCA cables to connect my camcorder to the yellow and white inputs on the front of the DVR. I have to press "input select" on the remote a few times until I get to L2, I think. This is a "line in" sort of setting and it directs the DVR to get its input from the RCA-style cables. Have your camcorder playing something you've recorded in its Video mode. If your TV is on the correct input (mine is called "Video 2", I think), you should see the camcorder image on your TV screen. Now, just rewind to the beginning of your camcorder tape. Insert a DVD-R disk (that's what mine takes) in your DVR. Hit Play on your camcorder and quickly press REC on the DVR remote. Let me know if this doesn't work.
Apr 03, 2009 | Canon ES400V Camcorder
Trying to record from TV.
TRY HOOKING THE COAX TO THE DVD RECORDER THEN TO THE TV ,BEST I COULD THINK OF.
Mar 27, 2009 | Cyberhome DVR 1600 DVD Recorder
Adding a dvd player to my dvr and older tv
leave coaxcil cable on dvr ;unplug the colored wires from the dvr output and plug them into the output of the recorder;plug a second set of colored wires into output of dvr and into input of recorder;be sure to set recorder input to proper setting on recorder (input one or two) now you should be able to record what your dvr plays or just use it as a dvd player ; you will need to have all three on to watch tv though.
Mar 01, 2009 | Cyberhome DVD Recorder - DVR1600
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
Jan 22, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Philips HDRW720 DVD Recorder Logo
204 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
