Question about Stanton C-303 Single Top Loading CD Player CD Player
Stanton c303 cd turntables
On the lcd display screen where the auto cue is displayed there looks to be 2 other options,can these be selected?
The c303 has the same screen and inturnal curcit board as the 304 ans 314. the other two items you are seeing are for the other units. it was a way for stanton to save money by useing the same parts in other table top cd models.
Posted on Oct 26, 2008
Stanton deck issues
Does decks are too bad build, i gave them away
Jul 23, 2012 | Stanton ST-150 Turntable
Have a stanton STR8 60 turntable that I forgot about. Hooking up it only has one output. Where do you put it?
turntables have very low output signal need a phono input to amplify it more than cd,cass. if has mono output use rca conn 2 to 1
Jun 10, 2010 | Stanton STR8-60 Turntable
Cant cue up cd, it just starts playing when inserted
no need to worry, there may be problem with micro switch.
Micro switch is that when u press cue there is a another micro switch just bottom of the cue button. I think micro switch needs to be replace and all done.
Feb 18, 2010 | Pioneer CDJ-800 Turntable
Stanton Cdj Eject Problem
I would take it to get it looked at if you don't feel comfortable taking it a part. It is probably the motor.
Jun 11, 2009 | Pioneer CDJ-800 Turntable
Audio level of Stanton T90 Turntable connected to speaker system
You can use either type of input but you have to tell the Stanton which one.
I hope you realize that "Phono" isn't just a generic connection with a different name. It actually goes to a preamplifier (either in the Stanton or in your receiver) that not only raises the level of the signal but radically modifies its frequency respone via the RIAA curve (look it up) to make it normal.
A normal turntable without internal electronics would not have the LINE option.
1) There is a switch marked PHONO/LINE on the rear apron.
2) Select PH if you're connected to PHONO on your receiver or select LINE if you're connecting to a line level (non-phono) input, say, a soundcard or a standalone amplifier without a a phono section.
Apr 02, 2009 | Stanton T.90USB Turntable
Stanton C.314 CD tray wont open
You can replace the cd drive by ordering another one from American DJ online.Give them the model number and replace about three multiple connectors in the same order you have the bad one. That will fix your problem.
Jan 02, 2009 | Pioneer CDJ-800 Turntable
Stanton C303 wont eject CD
Remove the power completely replug and then quickly turn it on press eject emediatly..... this should work
Jan 01, 2009 | Stanton C-303 Single Top Loading CD Player...
I have a stanton-vestax cd-11 dual cd player, and was wondering how to get a cd to play on it. I put one in, turned the player on, pushed all the buttons and nothing happened. how does it work?
I have had one of these for many years: Switch it on, you must make sure the two transit screws at the back of each deck are fully unscrewed and loose, let the machine displays settle down, then insert a CD, then press the 'reset' button. There is a built-in delay of about 11 seconds before the deck begins to read. After this the machine should then display the first track number, and pressing the big red button will start play.
Pressing the 'reset' button again stops playback and the CD spins down, but if you leave the CD in there it will eventually re-index and cue up again. This feature is to enable fast, one-button CD changing and it works very well in practice, as the 11 second delay is enough time to take one CD out and get another in there before it tries to read it again.
To stop playback just press the 'reset' button (this is the most used button!) and take out the CD. After the delay, the machine will try to read a CD as normal, but display 'no CD' on the display. There is no stop button, as this unit was designed for continuous use in a club or disco.
Hope this helps. :)
Oct 18, 2008 | Audio Players & Recorders
Stanton C304 Single Top... Problem
i had the same problem on the c303. ended up sending it to FL for fixing. when i got it back it worked fine for a few days then other issues such as not reading disc. unfortunately i could only recommend another manufacturer since this one seems unreliable.
Aug 22, 2008 | Stanton C304 Single Top Loading CD Player...
Stanton C-303 Single Top Loading CD Player CD Player Logo
157 people viewed this question
Top Stanton Audio Players & Recorders Experts
da surgen
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
