Used toner bottle is full how do I change it or fix it?
  • 59 Answers
Hi just empty it in plastic bag and re use the bottle
thanks
Posted on May 15, 2010
Fix an error message on the Ricoh Aficio 1224c that says 'used toner bottle full'? We have emptied the used toner bottle but the error message persists. What is the best way to fix this?
Check the waste bottle to see if there is a chip mounted on it somewhere. If not see if there is an optical sensor or clear window. If there is a chip it will need to be replaced or a new unit used. If there is a window or optical sensor you should be able to remove it, clean it out, and replace it. These are often the last part to fill with toner and create a light path block.
Feb 06, 2015 | Ricoh Office Equipment & Supplies
Says to empty used toner, did that, and still says empty used toner, how can i fix this?
Did you empty the bottle and put a new empty bottle on...OR did you empty the bottle and put the empty "dirty" bottle back on.????
The bottle has to be clean or the sensors that look at the bottle will still think its full.
Jun 23, 2010 | Toshiba 2060 Copier
Used toner bottle is full, how do I change it or fix it?
One possibility is the toner is caked inside. Solution: shake and reinsert in machine.
1) Wrap toner bottle w soft cloth or pliable paper 2) Shake gently up/down twist. 3) Replace container into machine.
This solution has avoided the trouble of repurchasing the same product.
Good luck.
Mar 22, 2010 | Office Equipment & Supplies
Ricoh copier imagio error used toner bottle is full
Change the used toner botle,desasembly the LCT tray,open the front cover and change the waste toner bottle.
Feb 09, 2010 | Ricoh Aficio 450 Copier
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
Change bottle or empty old one and replace. Better to recycle the used toner and get another bottle though
Jan 20, 2009 | Gestetner DSC530 All-In-One Laser Printer
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Oct 07, 2008 | Ricoh Aficio 1035 Copier
Used Toner Bottle Full - how do I empty it?
Hello Pete,
I have your bulletproof fix. Open the front door,and look at the far right bottom corner.You will see a piece of sheet metal about 3" by 6" that is locked down by a black plastic button that looks like an oversized thumb tack(if its still there). The black retainer holds the sheet metal slider in place. The sheet metal slider holds the used toner bottle in place.Remove the black plastic retainer and slide the sheet metal towards you.The sheet metal will actually have a hold on the waste toner bottle and so they both will come out together,as you will see when you pull it out. Empty the bottle into a trash bag (be careful, its not dangerous but can make one hell of mess). This machine uses an auger and tube assembly to deliver the used toner to the bottle. As the bottle reaches maximum capacity, the backpressure of trying to push more toner into a confined space causes a bind in the delivery system which trips a sensor(photo interruptor) and you get the message to empty the waste toner. So once the bottle is emptied you should be ok. Note: on rare occasions the tube and auger assembly(which became somewhat packed and therefore gave the message) will remain slightly bound even after the toner in the bottle is emptied.You might have to slide the waste toner bottle back in a couple of times to dislodge the clogged toner. In fact I have had to use a slight amount of "force" to jog the clog loose.Again this is rare. The copier should immediately recover once you put the bottle back and close the door. Another rarity can occur which will cause you to turn the copier off and back on in order for the copier to return to a ready condition. Have a fine day. ............SPINAL............
Jul 17, 2008 | Office Equipment & Supplies
206 people viewed this question
k24674
jasbo
jasbo
