Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Loose change I have a wtw6600sw2 and I can't figure out how to get the change out from under the tub.
  • 4 more comments
  • Anonymous Apr 22, 2008
    I am missing clothes that must have fallen down somewhere, and now the cycle won't complete, and gives you the code "UL" . How do I get my clothes back.
  • Anonymous Oct 05, 2008
    i have the same issue. change stuck in the pump. how do i get it out?
  • ghr8 Jan 05, 2009
    I hear a loud sound when the washer is in the spin cycle - that sounds like I have loose change, or loose screws behind the tub, and they are getting ounced all around. Anyone else have this? Do I need to fix it and how do I fix it?
    Thanks, George
  • silloway2 Jan 06, 2009
    I also have the "loose change" sound when the machine starts to spin. I just took the whole basket out and can not find any coins, loose screws, etc. Has anybody solved this problem? My machine has also started leaking out the bottom after about 15 minutes into a wash cycle. Has anybody had this problem?
  • Pennlk1 Apr 02, 2009
    Loose Change socks, keys under tub
  • webbguy May 11, 2010
    Loose change slipped under the wash plate of Whirlpool Cabrio washer. Is there any harm leaving it alone? I
    Is there any trick in removing the wash plate? I removed the center bolt, but can't get lift the wash plate off and don't want to force it as it is flexible plastic.
    President:
  • Whirlpool Master
  • 2,651 Answers
The tub oo this machine just sits on apost, weight of the tub only thing holding down, you will needa putty knife adn insert it about 3 inches in from either side t o "pop" the top hold down clips, the main lid assy will the tip back wards, next remove the outer tub cover (10 or so clips holding around the outside of outer tub.) after that the inner basket should lift right up and out. reaasmble teh same way.. be carefull the outside if the inner basket is extremely sharp from all those holes
Posted on Apr 02, 2008
I just got a penny out of my my cabrio wtw6600sb2 by taking the inlet and outlet hoses off the discharge pump after removing the back. YES CHANGE CAN GET IN THE PUMP!!!
Posted on Jan 17, 2009
If you hear change in your machine,Get it Out! I heard a clicking noise for couple of weeks while the washer drained. I realized too late that there was two coins in the drain pump. My wash room and kitchen flooded because the coins had broke one of the walls in the pump. The water had leaked out, under to the floor boards and under my hard wood floors. Damage in the thousands! The fix was extremely easy. Online manual - indentify part - online order - repaired in 10. Good Luck!
Posted on Sep 08, 2012
Dishwasher not draining
drain hose should be attached to drain under the sink. pull it loose from that drain should be a small hoe with a black end on it. use a wire coat hanger to run through the hose to loosen clog.
Jan 23, 2013 | Bosch SHX45L05UC Dishwasher
My whirlpool cabrio washer makes a loud noise when it spins
The bearing is probably going bad, spin it with your hand if it makes noise or you feel a vibration its bad Parts for Whirlpool WTW6600SW2 Motor Basket and Tub Parts
May 27, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio washer is unbalanced all of the time
Move the tub by hand in all directions and see if it is equally as hard and also it should return to the center with some force. if not you may have a broken support
Parts for Whirlpool WTW6600SW2 Top and Cabinet Parts
Jul 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whirlpool cabrio washer WTW6600SW2. The washer makes loud thumping noise during spin cycle and then uL code flashes and it stops until you open the door. After moving the clothes around and...
ON SOME CAPBRIO IF YOU HAVE SOME LIME ONTHE WATHER THE TUB IS A FREE FLODING AND WILL GET STUCK ON THE UP POSICHONAND WOND GO INTO SPIN. TRY TO RUN A CLEANER YOU CAN VUY AT ANY BIG WALL MART. IF NOT TRY TO LIFT TUB AND PUT BACK DOWN . IT SHOOD BE VERY EASY TO PULL UP IF NAT YOU BEST BET ID TU BUY A NEW WASHER. PARTS ARE PRICY.
Jun 30, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a wtw6600sw2 giving a f-51 code. I replaced rps sensor and harness and control board. Still giving me f-51.Also there is nothing between the tub, tub turns freely.
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit.
This can be caused by several different problems.
Make sure that you are not overloading the washer. Overloading can cause this problem.
A toy or foreign object could be under the washer that is interfering with motor rotation.
With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily.
If not, you could an item caught between the spin basket and the tub.
You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board.
A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa!
Feb 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio wtw6600sw2 f50 code.It spins freely.What now?
Any time you get a F-50 code on one of these, Whirlpool recomends you replace the control, wire harness, and RPS sensor if the tub bearing main shaft aren't binding.
Dec 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Washer WTW6600SW2 very loud spin cycle
Bearings in the outer tub are shot. Unfortunately, you are going to have to change out the whole outer tub as the bearing and shaft spline are one piece. Parts are about $200. I just changed mine out a couple of days ago and is not that hard if you have some mechanical ability.
Jul 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have change stuck is washer making noise when washing. How do I get it out
If this is a Whirlpool Cabrio, it has two pumps. One is the drain pump and the other is a recirc pump. In most cases, loose change an other items end up in one of these pumps. The following link explains how to access and check the pump(s) on the washer for obstructions.
http://www.fixya.com/support/r4155097-checking_drain_pump_whirlpool_cabrio
If you have something stuck in the wash tub, you will need to remove the washplate in the center of the wash tub. Follow these steps:
1. Lift the washer top panel by locating the retaining clips in the seam along the front (about two inches in from each side). Use a putty knife to push in while lifting on the top panel to release.
NOTE: Its a good idea to tape the lid shut to prevent it from flying open when you lift the washer top.
2. Remove the wash tub ring. This is the plastic ring around the perimeter of the top of the wash tub. There are a series of release tabs around the tub that you can pry with a screwdriver.
NOTE: The washplate will not come out with the tub ring in place.
3. With the tub ring removed, pop the center post cap off the washplate. Locate the center nut and remove. Hold the washplate with one hand as you loosen to keep it from turning.
4. Lift the washplate out of the tub.
With the wash plate removed, you should easily be able to access anything stuck in the spin basket.
If you have any questions, or if this is NOT a Cabrio, please post back and let me know. I hope this helps you.
Mar 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
At high speed spin cycle sounds like a jet engine...
if your thinking bearing, its part of tub assm not basket hub. $200 part
Mar 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,384 people viewed this question
Dan Webster
Dan Webster
Sal De
