Question about Startrac Fitness Products Star Trac 4500 Hr Treadmill Remanufactured
The belt seems to slip - Startrac Fitness Products Star Trac 4500 Hr Treadmill Remanufactured
    President:
  • Startrac Fit... Master
  • 832 Answers
Tighten the left and right tail roller allen screws clockwise in equal 1/4 increments.repeat until running belt is tensioned properly
Posted on May 18, 2010
Serpentine belt
sounds like belt tensioner might be worn out.check to see if belt has tension after u install
Sep 29, 2013 | 1998 Ford Escort
Why do cutting blades start slipping in heavy grass?
either the engine speed is to low or the belt is slipping how old is the belt is there a oil leak that got the belt wet with oil?
May 20, 2012 | Garden
Belt seems to be slipping
As a general rule, the belt should be kept as loose as possible. However, the belt must not slip on the rollers in normal use. Possible overtension can be quickly checked by walking on the belt at a speed of 3 mph The belt must slip on the front roller if you brake the belt with your feet, holding onto the hand rails, while you walk. If the belt does not slip, the tension is too high and the rear roller must be loosened. The belt tension and alignment is done by adjusting the rear roller position with the attachment bolts at the back of the treadmill a 1/4 turn at a time until correct tension attained. T
May 13, 2010 | Tunturi T60 Folding Treadmill
Belt stops/slips
Sometimes tightening the belt is not the problem> What I would be doing is to get on the machine a determine which of the belt is actually slipping. What happens if the drive belt is glazed slippage occur no matter what you do. With the running belt you may have to it limits of adjustment and the belt can be stretched that no matter how you adjust it it will slip!!
Mar 14, 2010 | Weslo Exercise & Fitness
I adjusted the belt so it would be more centered by following the instrucitons in the manual- turning left side hex screw 1/4 turn at a time until more centered. once it was more centered the belt started...
Under your motor hood you have a drive belt that can also slip. Depending on make you may after loosening the motor bolts and have an adjusting bolts.
Feb 25, 2010 | Proform Exercise & Fitness
Proform Crosswalk Advanced 525X the belt slips and it squeaks when slipping.....I have tried adjusting the end of the belt but that doesnt seem to help
One possibility is the pulley in the front roller.The shaft that goes into the roller slips making the belt seem as if its slipping. To check it it requires tmarking both surfaces with paint and then see if the mark seperates.
Nov 30, 2009 | Proform Crosswalk 500 Treadmill
Treadmill may be slipping
Depending if this is a new issue or old, It could be a couple of issues. Check the belts for slipping. Proper tension on walking belt (check your manual) or drive belt -remove the cover and you might be able to see if the belt is slipping or it could be a load issue (electronics not sensing added load fast enough). My bet is belt tension. Also Lubricate,lubricate,lubricate
www.twincityrepair.com
Feb 28, 2009 | Reebok Exercise & Fitness
Treadmill seems to slip while running,
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Feb 22, 2009 | Proform XP Weight Loss 620 Treadmill
How to replace belt??
there are two wheels unplug every thing and turn upside down you will find the other wheel
Sep 21, 2007 | Amana ALW480DA Top Load Washer
Startrac Fitness Products Star Trac 4500 Hr Treadmill Remanufactured Logo
64 people viewed this question
Top Startrac Fitness Products Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Techmotionusa.com
Techmotionusa.com
Tim Loy
Level 1 Expert
Are you a Startrac Fitness Products Exercise and Fitnes Expert? Answer questions, earn points and help others
