Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Frost free freezer smells like fish
Freezer had a layer of ice on the bottom, we unloaded it and unplugged it. After cleaning out the bottom evaporate tray it smells like fish. We are in the process of plugging up to see if will freeze, but the smell is so strong.
  • Anonymous Apr 24, 2008
    Food on the upper shelf thawed..was large amount of ice on bottom of freezer, we cleaned it..and put food back..solid frozen meat is still frozen cartons defrosted and I put a glass of water on the top shelf a day ago..today it is still unfrozen tho all the food on the bottom shelves are still solid.
    Novelist:
  • 184 Answers
IF THERE WAS A LAYER OF ICE ON THE BOTTOM OF THE FREEZER, THE DRAIN IS PROBABLY PLUGGED UP. IT WILL NEED TO BE CLEARED BEFORE PUTTING BACK INTO SERVICE OR IT WILL JUST DRAIN INTO THE FLOOR OF THE FREEZER AGAIN. AS FAR AS THE ODOR, TRY PUTTING CHARCOAL IN IT TO ABSORB THE ODORS. IT WILL HAVE TO BE LEFT IN THERE FOR QUITE A WHILE. WHEN THE FREEZER IS CHILLED, IT WILL LESSEN THE SEVERITY OF THE ODOR. IF THAT IS UNACCEPTABLE, THERE ARE COMMERCIAL ODOR NEUTALIZERS ON THE MARKET YOU CAN USE.
Posted on Apr 05, 2008
SOURCE:
Ice collects in the bottom of the freezer not allowing door to shut
BA Baker... hello,
Ice collecting on the bottom of the freezer.. is not such a terrible thing...
(Probably means the defrost is working... (merely not EXITING)).
New refrig or unfamiliar refrig could cause deeper analysis...
but if ...
If this is not a new device... and has been happily tending to it's own needs (evaporating well) for a while (months would be re-assuring)...
Then you are MOST probably looking at a clogged evaporator drain... (usually easily fixed by negotiating "WARM" (not hot) through the bottom vents slots of your freezer section.
Looking under your Refrigerator/Freezer... or consulting your owners manual... Locate your defrost "catch" pan...
It should NOT be dusty...
(easily tested: clean paper in tray...
Still clean tomorrow = clogged drain (pan is watered daily).
Close inspection should reveal a tube descending into it.... This is where you will watch for your patiently applied doses of warm water to appear... (near immediate).
It may take several doses... because ice can also have formed over the drain... Be persistent... You will be proud.
Please comment me back... I really like REFRIGERATORS/Frzrs...
few appliances tend to themselves so well (adorable).
Samsung RF4287HABP User Manual
Apr 17, 2016 | Samsung RF4287HABP 28 cu. ft. 4-door...
Top is frozen lower shelves food is dethawing
One of two things is going on here, either the door is not closing properly (or some one left it open), check the seal all the way around especially at the bottom.
Or most likely you have a refrigerant (freon) leak that has left the charge low enough that you are unable to get it to cool throughout. A leak on this type of unit is usually in the evaporator in the corner where a weld was made. The evaporator is about $189.00, with refrigerant a new drier and supplies I bet it would run about $450.00 to repair.
Apr 26, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore chest freezer - why is there a 1/2 inch of ice in bottom
Hello. If your freezer is not a self defroster, you must have had a power failure for a few hours that caused a melt with water ending up on the floor of the freezer and then refreezing. IF you have a self-defrost model, your defrost cycle produces some water which should make it's way down to the evaporator tray just above the floor... in your case, the small hole in the floor is plugged and the water is accumulating on the floor rather than making it's way to the evaporator tray. The fix is to clean the evaporator tray, defrost the ice with a blow dryer, locate the hole and clean it out with a couple of pipe cleaners or cotton swabs. Regards, Joe
PS please rate my answer. thank you.
Jan 28, 2010 | Freezers
Sears Freezer, Model 253 9284013-unable to locate manual, nor online. Freezer did not maintain freezing level, fish thawed slightly, dripping liquid onto bottom interior. It froze over. On bottom, at the...
Your problem could be caused by a clogged drainage tube. even though you may have removed the ice it may still have a clog. my suggestion would be to take all of the contents out of your fridge and let it sit unplugged for atleast 24-48 hours with the doors open this will eliminate any left over ice that may be clogging your drain tube. if this dosent help then you may have a defrost heater problem, or possibly a defrost termination switch problem. as for the smell i know that vinegar works well for getting rid of odor. ther eis also a product you can purchase called fridge aid, it is a charcoal based air purifier and should work well.
Oct 11, 2009 | Kenmore Freezers
Ice build up in the bottom of my upright freezer
If it's a frost free model, it could be caused by a plugged defrost drain. Every time it goes through a defrost cycle the water is supposed to drain into the compressor compartment. You can defrost it by unplugging it for a day or two and then remove the panel covering the evaporator coil. You should be able to see the drain tray under the coil and find out whats blocking it.
Aug 15, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Fridge/freezer model FFA90P frost free ice has
The water coming from the bottom is from the evaporater tray because it is too full and running over. There is a grill on the front bottom of the frig. ,and there is a srew or two on either side probably 1/4" maybe 5/16" loosen these and remove the grill. If no srews visible then it just snapps in. Remove grill and slide tray out and dump it.
The icing problem under the freezer tray is a defosting issue. you can move the food items to a cooler with ice or another unit and let this one thaw out with the doors open and unplugged and towl on the floor, the tray that is overflowing now will overflow again while the frig. is unplugged because there is no heat being generated to cause evaporation. You will need to have this checked out by a pro, generaly a service fee and they will tell you what has failed and can ballpark a price to fix. once the unit is thawed, ( this can take 12- 14 hrs) the unit will work again until the air passages get frozen over again. I suspect defrost heater element, defrost heater timer if ice maker equipted,there is also a little fan up there tan can fail. without seeing the unit in person only guesses. the thawing trick will buy some time.
Jul 12, 2009 | Hotpoint Freezers
Frigidaire side by side: water fills up in bottom of freezer
You have a blockage in your drain tube, at the bottom of the metal tray there is a hole which is connected to a tube which runs down the back of your refridge to a pan next to the compressor. It is an easy fix have done this 1000's times. Remove back panel in freezer, grab a heat gun or hair dryer and melt the ice it the bottom of tray. Clean the water in the tray with some paper towel next get some hot water in a measuring jug and pour into the pan(hot water will help melt ice in tube) repeat this process a couple of times and then get a curtain wire or something flexible to push down the pipe to clean the blockage...you will know when the blockage is clear because the water in the pan will suddenly drain off....put cover back on...make sure to unplug appliance before servicing...hope this helps :)
Jun 22, 2009 | Frigidaire 17.8 cu. ft. / 504 liter...
Ice forming at base of freezer part
you need to urinate on the tray amanda it may smell but will solve the ice prob as the urine is heated
May 26, 2009 | Siemens Freezers
Up right 14.7 cu GE freezer
HI to clean the drain tube. pull fridge away from the wall .find the drain tube, by the drain tray. push a small plastic hose, up the drain tray. blow in the hose, to clear the debris. thanks the appliance doc.
Jul 28, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
753 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
