Commercial Maytag top load , what is D8 error
Commercial Maytag top load what is D8 error message I replaced the motor the water pump the clutch pads still happen
5 Suggested Answers
  • 61 Answers
SOURCE: Maytag MAV6000 Top Load Washing Machine
Tip the machine back remove the belt try to turn the drive pulley manually . sorry the larger pulley in the centre. if you can turn it counter clockwise and feel the inner drum moving then the thrust bearing is ok. if not you may need to replace it.Also a bad lid switch can cause this problem.
Posted on Dec 18, 2008
  • 61 Answers
SOURCE: clutch on a maytag
no this machine has a thrust bearing not a clutch if the machine is not spinning well you need to replace the thrust bearing kit it come with a new drive pulley
Posted on Jan 20, 2009
landsend
  • 1066 Answers
SOURCE: maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Posted on Mar 11, 2009
  • 298 Answers
SOURCE: I have a Maytag commercial
go to appliancerepairplanet.vstore.ca to get a service manual on this
Posted on Dec 07, 2010
What does E2 error mean
Generic pump error
Error Code-control panel display "Err2" (Error 2, Error2) ' question ...
www.haier.com/za/help.../washing_machine/.../question/.../t20140313_209219.shtml
  1. Cached
  2. Similar
Mar 13, 2014 - Error message:Drain error, water can be not drained fully within the required drain time (controlled by PCB software). Reason 1. Pump filter is blocked. Solution 1. Please open and clean the pump filter. (Filter access door is on the bottom right, at floor level of the washing machine). Step 1.Push a flat blade ...
How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front ...
9k=? 5:23 https://www.youtube.com/watch?v=by94vOVmmhQ
  1. Similar
Mar 18, 2017 - Uploaded by Nancy Gurish How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front Load Washer Stopped, Repair Of ...
Washing Machine Error Codes - Front Load and Top Load Washers ...
https://removeandreplace.com/.../washing-machine-error-codes-front-and-top-load/
  1. Cached
  2. Similar
May 5, 2015 - F9 followed by E1 - (drain pump system error) F5 followed by E2 - (door will not lock) F7 followed by E1 - (motor drive error) "rL" - (remove load) Washer making error beeps - Door has not been opened and closed for at least 3 cycles. Washer beeps when HOLD TO START is touched - Door not closed
Mar 22, 2018 | Washing Machines
GE Washer top-load WLDSR416FOWC
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Jul 23, 2008 | GE WDSR2080D Top Load Washer
Why does washer not complete cycle & lid not unlock?
Probably leaked thru tub bearing on tub and got into cluth, ur lucky to have this washer for as long asyou have costs more to repair than replace either way if that your problem
Jul 12, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Washer won't fill
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jan 16, 2013 | Maytag Washing Machines
Can't find where the clutch goes on a Maytag Performa PAV 3300, is it in the transmission?
This washer is a single belt driven model that uses a thrust washer system to release the brake when the motor reverses. In wash mode a 200# spring locks the tub place while the transmission agitates the clothes. The pump cannot remove the water in this direction. In spin mode the the brake is released and the water gets pumped out. Here is a great pictorial that shows how to replace the kit along with a Maytag single belt washer service manual.
Oct 08, 2011 | Maytag PAV2300 Top Load Washer
I have a front loading Maytag Neptune washer. I am constantly gettings the "SUDS" message even when I am hardly putting any soap in. I will also get the "No Drain" message, which used...
This typically happens when you use regular detergent instead of HE detergent, which stresses the pumps. Are you using HE detergent?
Also check for blocked drain hose or clogged water filter.
Apr 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune top load washer. I continue to get the DC balancing error during the spin cycle. This was repaired less than a year ago and is happening again. Last time they replaced the clutch...
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%@4$
Jun 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Model FAV6800AWW will not pump water out if clothes are in machine but if I take out clothes, the water pump comes on and the machine pumps out water and spins. Codes DC and UC come on when it it is time...
I’m an owner of the machine and know it quite well. If the One-Way roller clutches in the clutch pulley hub and the upper roller clutch assembly (if your series use’s it) can be cleaned up and re-lubed you can be back in service today. See this post Clutch Fix. My roller clutches failed at the 3.5yr mark Dec 08 causing dc/UC errors for any size load. I cleaned up and re-lubed and it worked fine. I replaced the clutch to try this clutch assembly back in Feb 08 25001169 to see if it would work it does and I recommend it to all owners for your and mine FAV6800AW and the LCD flavor of this machine the FAV9800AW. The clutch will work for all series of those machines. If you have basic mechanical skills and want to save money try to clean up the roller clutches and re-lube or replace for $60. If you call in a repair service I think you will be in the $300 range to repair. I have changed my nickname from dh1200s to FAV9800AWDIY I have many postings on the clutch subject at this site and Fixitnow.com where my Clutch Fix posting has been posted for these machines.
Good Luck and post back if you need help to DIY. …. Rich
Oct 25, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune top loader-will not start
Hello tinagomez479,
Some basic questions for troubleshooting;
Your machine type is a FVA6800AW/FAV9800AW correct?
Any errorcodes to the console?
Can you tell me what this action was for? “”We took it apart and cleaned it and put it back together and it worked good for about 5 loads then the water stopped draining and now it won't start again.”” Was this a Clutch clean up for dc/UC errors?
Does the clicking noise come from the console area like relays clicking or down below where the clutch pulley is located?
When you press the start button do the lid locks lock the lid?
Can you enter into Service Mode? If so can, can you turn on the drain pump for me? This will let us know if the Control Board is at least functioning in Service Mode and will take commands.
Go to page 16 of the Service Manual lower right hand part of page, Board Output Test and turn on the drain pump in service mode and see if the drain pump motor runs.
Here is the process; close the lid and enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00” Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on do you hear it run? Stop the test as the SM states with the off button or hit the Presoak key.
You mentioned it stopped draining, if the Control Board will take the command in Service Mode we can at least get rid of any standing water in the wash tub. When it stopped draining in the wash cycle did you take any error codes to the console like “ND”
Can you also try a Spin Only cycle and see if that will start and complete?
If you can’t do anything at the console pull the 120VAC power plug to the washer for 10 seconds then re-power up and try all above again.
Error codes are very helpful so please let me know what if any error codes you take to the console with your machine issue.
Rich
Jun 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
