Question about Pioneer PRO-530HDi 53" Rear Projection Television
Power problems with PRO-530HD
When I connect to power supply and turn on the main power button I get a constant flashing of the red standby light.
    Champion:
  • 213 Answers
Do you know what the pix look like be for it whent dead?
some time bad solder can do this. in the center of the board
thear is fuse that go bad because of bad solder on stk 392-120 or 110 on the conv. pcb the fuse is 5amp 125v you have about 3 of them on the def pcb. to ch them. to hit the flyback&hozoutput
ch cap.s in power supply.
Posted on Mar 30, 2008
SOURCE:
I have a Denon avr 2801. My standby light is flashing and i cant seem to reset it. I have tried pressing the a and b buttons together and then turning the power on, all the lights flash but thats it.
Hello
There is always a constant 5v for the device to go to standby.and power on when you press the power button .
This flashing is not to reset the device it shows that there is a problem with power supply.
the regulators are burned or over voltage ...
it needs service .
hope this helps
good luck
Jan 20, 2016 | Denon Audio Players & Recorders
Does not power on
ok on pioneer most of the time it is because of bad connections all over the main power supply board solder these and see what happens like i said most of the times it starts with bad connections.
Nov 18, 2007 | Pioneer PRO-119 60" Rear Projection...
5 flasing red lights and no power supply
Five flashes to Sony LCDs inidicates [IKR Error at power on]. This fault is likeley to be with the main board and is very difficult to locate. In most cases, the main board might need replacement.
Jan 27, 2013 | Sony BRAVIA KDL-40V2000 40 in. LCD...
What's your problem?Pioneer PRO-530HD 53 in. Rear Projection Television flashing red standby light
This and a few other models like it have one real common issue:
they develop from age and heat bad solder connections all over the power board (rather large board).
My experience with them is the fix usually is remove rear cover and follow power cord to power board (a lot of plugs to mark) and remove that board----then solder every single connection on the board which by the way has some special fuses on it.
Jun 14, 2012 | Pioneer PRO-530HD 53" Rear Projection...
Does not turn on
If there is no reaction at all on standby button, the receiver most likely has a problem with standby power supply or mcu. If you get flashing red standby light, there is a problem with one of the channels or main power supply. Either case you need to bring it to a reoair facility.
Dec 10, 2011 | Denon AVR-1803 Receiver
Have a Pioneer pro elite 730hdi. When you try to turn it on (main power, not standby), the tv cycles from the red (standby) light with the normal click to the green light, then one second later, it cycles...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this will help in solving the problem....
Aug 09, 2011 | Pioneer PRO-730HDi 64 in. Rear Projection...
Hi, i have 2 televisions different makes both turn on to standby but wont turn on fully, the bush tv when i push programme button to turn on the red standby button flashes but nothing else.
I have the same problem, my Bush LCD worked fine last night but won't turn on today. The main power button on the TV puts it onto standby but the remote or the buttons on the side won't turn it on!....HELP!
Sep 06, 2009 | Televison & Video
My Daewoo LCD TV (DLT-32C3FTB) will not come off standby.
Common problem on power supply board, replace dried out electrolytic capacitors
Apr 22, 2009 | Daewoo DLP3212 32 in. LCD Television
Panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Dec 29, 2007 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Pioneer PRO-530HD
Its really hard to say if its a major problem or not. I think anytime a circuit part goes bad thats its a major problem, because these sets HAVE NO USER REPLACEABLE PARTS inside so you should call out a trained technician, as theres alot of High Voltage inside these sets and also this is not a place for an experimenter or a handi-person to be messing around in. Your problem if you are a tech and Know the HI voltage saftey issues is most likly in the standby or main power supply... Good Luck
Aug 05, 2006 | Pioneer PRO-510HD 53" Rear Projection...
Pioneer PRO-530HDi 53" Rear Projection Television Logo
112 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
