Question about Char-Broil Advantage 463453306
The second burner does not ignite
The only way I can get the second burner to ignite is by putting a match to it.  it should ignite by using the flame from the first one but it does not.
  • MarthaVila Apr 27, 2008
    Thank you so much for the tip to clean out the carryover bar! I thought I was going to have to buy another BBQ, but after cleaning out the bar, all my burners now light!
    New Friend:
I have this grill and can not use it because evidently we were shorted the "vent" tent and the drippings from the food go directly onto the burner and clog the burner. So, anyone have any suggestions???
Posted on Jan 08, 2010
The carryover bracket in the back is the problem. You need to remove it and clear any blockages and try again or just buy a new one. I have the same problem at this time and am trying to find out how to remove the bracket.
Posted on Apr 19, 2008
SOURCE:
The glow stick lights up; approx30 seconds later, you can hear and smell the gas turn on, but the flame does not start
Depending on the specific unit you have the hot surface igniter (glow stick) may be only for lighting the pilot, which then ignite the main burners. The flame has to be proved before the gas valve opens for the main burners. This is done by the flame rod, which could be faulty in your case. The proximity of the igniter could also prevent ignition. Check that the flame rod is clean and secure. Note. be very careful when servicing gas appliances, and never ever use lighters, matches or any other flame source to light them except for the ignition system supplied by the appliance. These appliances are designed and built with safety devices to prevent ignition when it senses a fault or malfunction. This is all for safety. Do not bypass safety devices, it can kill. Call a qualified tech.
Dec 07, 2013 | Ruud Heating & Cooling
Tappan gas stove
Older gas stoves used a battery to ignite the flame but due to its age, I would get a hand held gas lighter.
Apr 21, 2017 | Kitchen Ranges
Landmann 12376 ignition
Firstly, check the distance between ignite and burner, the spark must contact with the hole of burner.
secondly, turn on the control at maximum level then keep and push control knob try to Push-button Piezo ignition several times.
Finally, If you do not find out any trouble with gas supply, connection and assembly, do the same with step 2 however, Instead of push the button use the paper or wood with flame on to ignite for side burner for the first times, after that keep it running for few minute to heat burner, then turn off then use Push-button Piezo ignition to ignite.
With my experience it can work 100% after you heat the burner, if not call me. ^^
Aug 14, 2012 | Landmann 12376 Gas Grill
Electronic ignition doesn't work anymore. How do I manually light this?
Before you go to match lighting, have you changed the battery in the ignitor button? If you haven't, I'd start there first. Unscrew the ignitor cap and the battery's Positive Tip (+) will be facing you. Be sure to install the new battery in the same direction.While the battery is out, check for any corrosion that may be present in the battery holder. A Q-Tip & WD40 work well to clean out any corrosion.
To match light the burners ... use a long stick match (also called a hearth match) and carefully guide the match between the grates and under the flame tamers, as close to each burner as possible. Of course, the match should be lit prior to doing this. Turn each burner on individually, as you place the lighted match next to it. Once the burner lights, turn it down to low and move to the next burner and so on, until all the burners you want to use are lit. Then set the flame heights where you want them.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 01, 2011 | Char-Broil Advantage 463453306
Rotisserie burner won't light
It could be a dirty or inop spark electrode. Also could be weak batteries in the spark igniter.
Before you start you should make sure that the ignition system has fresh batteries. The batteries are usually located within the igniter button but not always. Some BBQs will have a battery pack located somewhere on the BBQ and others you can remove the igniter button by turning it left to reveal the battery.
First verify that the rotisserie burner can be lit manually. Take a BBQ lighter or long stick match and then put the flame right at the base of the burner where the electrode is and then slowly turn on the burner valve. It should light within four seconds. If it does not then shut the burner off and check for any restrictions in the gas line for the burner.
If it does light with a match then the spark electrode could be dirty, out of position or simply the wire for the ignition system is loose. Press the igniter button and watch the electrode for a good bright spark at the burner. If you do not see any spark you can verify that the igniter wire has not come loose and also gently adjust the position of the electrode end a little bit closer to the burner using a pair of needle nose pliers(It should not be touching the burner). It does not need to touch the burner but have a really small gap.You can use a small wire brush to gently clean the electrode of any debris that might be causing a weak or no spark
If you are unable to remedy the non-spark issue all is not lost. You can still use the manual lighting procedure I described to light the burner. And remember to be careful when trying these procedures. I do not want you to get injured from delayed gas ignition. Be careful and have a safe holiday.
Jul 04, 2010 | Ducane 30400042 (LP)
Gas stove burner will not turn on
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
Tappan front right side burner gives out very little flame...
sounds like a ignitor problem or a dirty burner.clean all the holes of the burner and if you could see the oraphas clean that as well.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Mar 06, 2010 | Tappan TGF320 Gas Kitchen Range
Purchased range used. Burner Head assembly with
Yes, you need a burner cap to sit on top of the burner assembly and create the normal star shape flame.
Feb 09, 2010 | Kitchen Ranges
Lighting the pilot light
The steps involved can vary slightly depending on your furnace model and pilot valve type, so if possible try and find the instructions inside the furnace door cover or in the instruction manual. This is for a gas fired furnace, but applies to any gas-fueled appliance including water heater. Two of the most common types of pilot valve body assemblies either have a red reset button and a gas valve or no reset button and a valve knob that can be depressed. But whichever type you've got, if you have an older model furnace with a standing pilot (flame is lit all the time) then this is the basic procedure.
  • Turn you thermostat to 80 degrees or to a setting that will demand heat. Make sure the thermostat is in "Heat" mode.
  • Go to the furnace and find the pilot valve. The pilot valve body is a box shaped device into which the main gas line will run and is located near the gas burners. It will usually have a gas **** or valve knob that reads "On, "Pilot" and "Off." Locate this gas **** or knob.
  • Turn the knob or gas **** to the "Off" position and wait about 3 minutes for any residual gas to clear away.
  • Find the pilot. It's located near the gas burner tube assembly in the furnace.
  • Get your match or lighter ready. Sometimes the pilot is hard to reach. If possible, try and use a long fireplace match when you light it. If you don't have a fireplace match then a butane BBQ grill lighter works well too. If you don't have that, then you can fasten a match to the end of a stick when you light the pilot
  • If you have a pilot with a red Reset button, turn the gas valve from "Off," to "Pilot."
  • If you have a pilot with no red button, turn the knob from "Off" to "Pilot."
  • Place the lit match or ignited lighter tip at the pilot and depress and hold the button or depress the knob as appropriate. Depress the button or knob for about 30 seconds. This maintains gas flow to the pilot until the thermocouple gets hot enough to open the main gas valve.
  • Once the pilot stays lit, slowly release the button or knob and turn the gas **** or knob from the "Pilot" position to the "On" position. This will ignite the burners and keep the flow of gas supplied as required for the burners as called for by the thermostat.
  • If the burners fail to ignite then it may be because the thermocouple did not get hot enough to open the gas valve. Wait a few minutes and then repeat the above procedure. This time hold the red reset button or depress the knob for about 45-60 seconds.
  • Once the main furnace burners ignite, adjust the thermostat to the desired setting.
  • If you've followed the previous steps on lighting the pilot and it still does not light after, or will not stay lit, then you probably have a problem with the thermocouple or an adjustment needs to be made to the pilot. You'll need a furnace service technician to replace or repair these parts. You may find that the pilot lights, but it is an anemic looking flame. That's a different problem we'll look at in the next section.
  • If the pilot lights but the flame is a weak yellow flame, it will not get hot enough to heat the thermocouple to its set point allowing the gas valve to open.
    A natural gas flame should be a bright blue with the tip of the flame having just a tinge of yellow. A propane flame should have a bluish green flame with a tinge of yellow at the tip. The flame should be strong enough to hit the thermocouple tip about 1/2 inch from the tip end. If the flame is weak or shaky looking, check to see that a breeze or draft is not blowing on it. Adjusting the Flame
    There is usually a small screw on the pilot valve body that will adjust the flame. You may have to refer to the manufacturer's instructions to find the screw. Turn the screw as needed to adjust the flame throw. Yellow Flame
    A yellow flame is caused by lack of air and incomplete combustion. It can be caused by a dirty pilot tube tip. Split Flame
    This is caused by dirt in the pilot tube. Take a needle or small nail and gently clean the tube. Flickering or Wavering Flame
    A flame that flickers is usually caused by a draft.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 18, 2009 | Water Heaters
Hotpoint RGB745 Burner Problems- Unique, needs help
Not sure, but sounds like you may have a gas pressure problem or the stove is set-up for the wrong type of gas.
Apr 25, 2007 | Hotpoint RGB745 Gas Kitchen Range
Char-Broil Advantage 463453306 Logo
283 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
choprboz5
Dave Cottrell
Dave Cottrell
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
