Question about Endless Summer 233010 Natural Gas Stainless Steel Commercial Patio Heater
What to do from propane to natural gas - Endless Summer 233010 Natural Gas Stainless Steel Commercial Patio Heater
I had a natural gas furnace installed in place of a propane gas furnace. will this cause my rollout switch to trip constantly. my fuel source is propane. gas valve on furnace wasn't change to propane
If it has a position for natural gas/propane then it needs to be changed to the position that the gas source is either propane or natural gas..
Nov 22, 2015 | Heating & Cooling
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
I have a kenmore ellite bbq model 141.16691 propane - I want to convert to natural gas, there is no conversion kit to make it but the natural gas model 141.17691 is exactly the same - just natural gas. If...
Many manufacturers make grills in propane and natural gas, but are not convertible from one gas type to another. The reason being safety. Each grill model, whether it's Natural Gas or Propane is tested and approved for that one specific gas type and that alone. Converting it would put all the responsibility on you, if something was to go wrong.
I suspect in part, the reason you want to convert is so that you want have to refill the propane tank any longer. But, you may want to consider this against convenience. Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Which boils down to lower high end temperatures, longer preheating times and the expense of running an approved gas line to the grill for Natural Gas. Not to mention the cost conversion parts.
But, the decision is yours to make. Thanks for choosing FixYa.
Aug 06, 2011 | Kenmore Elite 644 sq. in. Cooking Area Gas...
I have a small counter top fryer set up for lp gas how do i change to nat
check the supplier for the conversion kit.the kit contains burner orifice, pilot orifice and gas valve spring which are commonly needed for conversion from propane to natural gas or from natural gas to propane.
****natural gas orifice has larger bore than propane, gas valve spring for propane is thicker than for natural gas.
Mar 29, 2011 | Cecilware FMS-40 Deep Fryer
How to change a weber natural gas grill to propane
According to Weber, "There is no conversion kit available to convert any Weber gas grill from one gas type to another. Any attempts to do it will void your warranty."
Sorry, but if it's any consolation, Propane Gas burns cleaner and hotter that Natural Gas in an outdoor environment. Which translates into faster preheating and hotter searing temperatures.
Hop e this helps and happy Grilling!!
Mar 19, 2011 | Weber SUMMIT S-620 Propane Grill
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
Feb 23, 2011 | Weber Spirit? E-310 Propane Grill
Switched from natural gas to propane now oven flames up sides how do I fix? Model#362.75571691
Propane and natural gas are two different fuels and require adjustments to the appliances to which theye are connected. Typically, when converting to propane from natural gas, a pressure regulator and a change in gas jets are required. This is because propane has a different heating value (hotter) and behaves differently.
Also, propane doesn't burn as cleanly as natural gas so after you have made the hardware changes, if you start to smell something in the kitchen, you may need to crack a window slightly to provide for better venting.
Please be careful
Jan 01, 2010 | Kenmore Kitchen Ranges
Liquid Propane vs. Propane (like used for BBQ)
They are the same thing.
The propane you buy for your BBQ is liquid in the bottom of the tank. At the top, it comes out as a gas, which you run through a regulator and then into your grill. If you by some chance turn the tank sideways, the valve inside will shut and keep the liquid propane from coming out. If it did you could have a serious fire.
However, there is a difference between what most folks call "Natural Gas" and propane. If you have gas piped into your home, it's natural gas and not propane.
Natural gas dryers won't run right on propane (LP Gas) and vice versa. There is usually a conversion kit you can buy to switch them over.
Oct 14, 2009 | Dryers
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
I moved and after hooking up my gas dryer to gas tank it will not heat up....
were you on propane b4 the move or natural gas? A natural gas dryer will not run on propane nor a propane one run on natural gas
Jan 14, 2009 | Kenmore 73932 Gas Dryer
Endless Summer 233010 Natural Gas Stainless Steel Commercial Patio Heater Logo
Top Endless Summer Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
