Question about Bosch 23 in. SHU3302UC Built-in Dishwasher
Shu3302uc water comes out bottom of door when running
  • Bosch Master
  • 43,501 Answers
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Posted on May 15, 2010
Water overflow then no water
It may be a sticking float switch. The float switch controls the level of water in the dishwasher and if it is sticking on or off it could cause them problems you have
part numbers 263834 and 263185.
Hope this helps
Jan 02, 2014 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Water doesn not drain out
The problem is most likely that there is still water residue at the bottom of your machine.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again. Also check that the drain pipe is not kinked or caught somewhere.
Feb 17, 2011 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Dishes not coming out clean, water is coming out of arms but doesn't appear to be rotating (either top or bottom). Trying to figure out the test cycle on the shu3302uc model (when I hold down pwr scrub and...
There is a recall repair notice for this model (and several other models) on the Bosch website. There is a faulty controller which may cause a fire! They have an 800 number for setting up a recall repair appointment. Check it out! We just found out by accident of the recall...we were never notified, even though we registered our Bosch SHU33UC unit when we bought it...poor customer service!
Jul 09, 2010 | Bosch 23 in. SHU3302UC Built-in Dishwasher
I have a bosch shu3002uc that is leaking at the bottom of the door. I have to put sponges on the floor to catch the water. What should i do?
Check the levelness of the dishwash. Is it level.
Check the seal around the contact surface of the door and the washer opening. Are there any cuts or gaps?
Apr 25, 2010 | Bosch 23 in. SHU3302UC Built-in Dishwasher
After two to three days the water starts to appear
hello mam
please check the solenoid walve which controls the water to check this please open the top cover of the washer and see the water line where the water hose pipe is connected there you can find the solenoid walve and observe this as you give the supply and timer switch is ON you hear the sound of the walve operation while it opens the line to take the water and as switch of the mains it should shut the water line to stop the intake of water and if this operation is not happen then please change the solenoid walve.
Oct 07, 2009 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Water keeps filling up under passenger seat in rear of car
My 2001 passat did the same thing. my leak was coming from the door panel. Open your door and use a water hose to simulate rain water running against your window. Water should run into door and drain out of several drain holes at the very bottom of your door. Check for water leaking from the bottom of your plastic door panel. The water runs down into the door and leaks through your inner door panel seal causing water to leak inside from the bottom of your door panel and run into the floorboard instead of draining out the water hole in the bottom of your door.
Aug 26, 2009 | 1999 Volkswagen Passat
Water is leaking out the bottom of door
clogged defrost drain. remove ice from bottom of freezer and take very hot water and work back and forth with a turkey basteruntil water drains. blow out with hose.
Jul 25, 2009 | Frigidaire FRS23R4A Side by Side...
Door locked and will not open. i ran an empty cycle to see if that would work and it doesn't.....thanks! Margit
IF water is left in machine then door wont unlock, check pump, run drain cycle. If pump runs but doesnt remove water, then check filter at bottom (small door on bottom front) water will come out when this is done. If washer is completely empty of water and door locked then you may access lock release tab from bottom or reaching down from top to lock asm. Then check lock
Jul 19, 2009 | LG WM1814CW Front Load Washer
Where do you put the jet dry?
ALONG SIDE THE POWDER DISPENSER- LIFT THE DOOR-
Jul 10, 2009 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Bosch dishwasher will not cycle. Water in base
First...make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
Dec 22, 2008 | Dishwashers
Dishwashers Logo
138 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
