Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Burner will not light. electronic gas valve stuck
Burner will not light. Electronic gas valve stuck on off
  • Dacor Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on May 15, 2010
Burner won't come on or shut off have to manually hold contact open
On some gas-powered appliances -- such as gas ranges, water heaters, boilers and gas fireplaces -- the pilot light works to ignite the main flame when the gas is switched on to the burner by the regulating valve. If the pilot light is not lit, the gas burner will not ignite, which could cause a dangerous situation by letting highly flammable gas escape into the air. If the pilot light goes out, you can relight it after the gas is shut off using a match or the unit's electronic ignitor if it has one, following the proper safety precautions
Nov 12, 2017 | Heating & Cooling
Front right burner will not ignite
I'd get a briquette lighter down in there when you turn it on and try to light it manually. If it does not light, it is a gas supply problem (bad valve or control), and time to call appliance guy. If it does light, the spark path over to the burner may just be plugged with something. If you have gas + spark, but no fire, it almost has to be that the spark can't reach the gas for some reason. That usually comes from something being plugged up.
Nov 27, 2013 | Electrolux EW30DS65GS Dual Fuel (Electric...
I have a Jenn-Air gas grill model #720-0061-LP it has 3 brass burners and a rotisserie burner on the back wall. the flame from the middle burner is shooting back into the knob causing issues with the...
I have had the same problem before with same exact grill. The burners get clogged and the gas pressure backs up. I have had this actually split a gas valve and the plastic electronic igniters do not have a chance withe the head. Call nexgrill and get all new burners under warranty. This will solve the problem for a while. The latest burners that I received in Aug 2010 are 1/2 inch shorter and may solve this problem. You may want to buy new gas valves since the excess heat in this area may have damaged the valve. Since 2004, I am on my 5th set of burners, 2nd set of gas valves and 3rd electronic ignitor. May just recycle grill and get a Weber or go with charcoal.
May 09, 2010 | Jenn-Air JLG7130A
We have a 6 burner, nat gas cooktop....all unit light but the igniter clicking will not stop...unplugged it . question: all mechanics are closed is this safe gaswise?
What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame. Once the set temperature is achieved the control stops all power to the ignition circuit which causes the ignitor to dim and the oven gas valve to close, stopping any burner flame. Cycling on and off continues to maintain the specific temperature the control is set for.
Jan 09, 2010 | Microwave Ovens
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Oven won't light - electronic ignition oven
    Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
    Aug 12, 2009 | Kenmore 33169 Gas Single Oven
    Electronic ignition works, but the gas does not come on
    The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
    The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, either repeat the procedure or call a qualified appliance repair technician.
    Jun 26, 2009 | Frigidare FGB24S5DC Gas Single Oven
    Gas range won't work
    Hi, Even tho the ignitor is glowing, it can be bad. It has to pull enough amps to open the gas valve. This is very common problem. I can get you the part and or prices if you could get me the model#
    If I can help further, please let me know.
    Thanks
    Vic
    May 15, 2009 | Magic Chef 9122 Gas Single Oven
    Gas burners/electronic ignition
    Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
    Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
    Jan 26, 2009 | Tappan TGF657 Gas Kitchen Range
    Electronic Igniter
    If it is only happening with one burner, the switch on that valve needs to be replaced. If it does it with all the burners it is a problem with the spark module or control.
    Post back if you have any questions.
    Nov 17, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
    Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
    148 people viewed this question
    Top Dacor Kitchen Ranges Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    240cpa
    Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
