Question about LG LRBN20510WW Bottom Freezer Refrigerator
Lg multi air flow gr-349sqf
My fridge/freezer trips my master fuse box every 10 or so hours.
This has happened recently and the only change in anything related to the fridge is that I have cleared out 2 of the 3 drawers of frozen good and they are currently empty. I think form shortly after this point we experienced the Master fuse trip. It is now fairly consistent - every 10 hours. It has varied between 7 and 10.5 hours over the last 8 days.
Can you advise if it is worth repairing and give me an idea of cost of replacement parts?
  • Anonymous Jan 04, 2009
    Does anyone have a solution for this, I am having the same issue with this fridge.
    DomesticFool - what was the outcome?
  • Anonymous Mar 25, 2014
    LG MULTI AIR FLOW GR 359 SQ
    New Friend:
I have done that but there is no cold air coming in the refrigerator and it is not geting cold at all there is just a little bit my food is not geting cold so what can it be as i had it redgas just 4 weeks ago
Posted on Apr 24, 2013
Could be a wire short,bad defrost heater, or comp. pulling too many amps which is between 2 and 6 or higher being bad. I would say the main problem is you purchased a LG fridge which is a poorly made fridge,sorry.
Posted on Apr 01, 2008
2 Suggested Answers
SOURCE:
  • 400 Answers
SOURCE: lg multi air flow gr-349sqf
It sounds like the defrost element is faulty and is causing a leakage to earth when the unit comes onto defrost cycle. Check the defrost element in the freezer compartment behind a panel cover.
Posted on Mar 10, 2009
LG GR-349SQF the freezer trips the power circuit. it started working after a few days was turned off and now its tripping power again, any ideas.Is it the defrost element.
it is a dead short so could be the element, compressor motor , start/run capacitor or bare wires
call a technician for the diagnosis
Jul 11, 2018 | LG Refrigerators
How do i fix my lg multi flow fridge/freezer that trips the earth leakage all the time
It may be possible the defrost heater is shorting to earth or ground. This would trip the GFI every time the refrigerator went into defrost. It also is possible that water has infiltrated the insulation and causing a leakage current. This would be much harder to fix.
Mar 22, 2015 | LG Refrigerators
Lg gr-432sf refigerator not getting cool air flow to fridge compartment
It's not clogged full of ice behind the cover plate? That happens often - the defrost timer dies, and the evaporator packs solid with ice.
If that's not the case, then... does the fan rotate when the power is turned on? If not, suspect the (defrost timer) controller board. If it does, look for obstructions to airflow.
Jul 26, 2014 | LG Refrigerators
I AM HAVING LG FRIDGE. HOW WILL I CLEAR IT THE MELTING? RECENTLY PURCHASED LG 225 MODEL. HOW WILL MAINTAIN THE FRIDGE? HOW WILL SAFE?
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 19, 2011 | LG LRBN20520 Bottom Freezer Refrigerator
My LG GR-349SQF freezer keeps getting ice in the very bottom
I believe your defrost condensate drain is blocked with ice or other foreign objects. Could you also double check the model number? Thanks, Sea breeze
Dec 29, 2009 | LG Refrigerators
Mar 10, 2009 | Refrigerators
LG LRBN20510WW Bottom Freezer Refrigerator Logo
1,484 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
