Question about Kitchen Ranges
Oven element We have an older Kelvinator built in oven. The broil element burnt out. I removed it and it is 3000 wattage. Does it have to be replaced with same wattage or can it be lower, like 2000
    President:
  • 1,314 Answers
No needs to be 3000 wats for proper operation as broil is supposed to be hoter than bake but you could use 2000 if thats all you have available it wont damage any thing if thats what you mean
Posted on Mar 30, 2008
Oven will not heat
GE Oven: If it only gets warm, it is not getting 220 volts. It may only be getting 110 volts. First check your breaker (double pole) and reset it manually. Since it is an older oven, there may be a break in one of the wires or connections. A voltmeter will indicate just how much current you have. Be careful.
Mar 29, 2017 | Ovens
Broil element won't come on.
1. Cut power to the stove by unplugging or switching off at the mains.
2. Remove broil element and inspect for burnt or melted places, if you have multimeter, then check it for continuity, it shouldn't have more than about10 ohms resistance. Burnt-out element is easily replaced.
3. If element is good, then check for voltage at element terminals, it should be 220 volt AC ( with caution, after turning power back on and setting oven to broil).
4. If all above checks out, then the problem will require disassembling the appliance to investigate thermostat issues, relay, etc. It would be at this point that I would strongly consider putting in a service call!
Mar 25, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
The lower element burned in my oven. I replaced the element, but the oven will not work.
unplug range ..remove the back cover plate check all wires all connections ..their must be a burnt /broken /dissconnected wire ..check where the wires connect to the bake an broil element ..and the bake broil switch..if all looks good .then the bake broil switch burnt out when element blew out..plus is the breaker tripped in the box ..it prob. tripped when the element blew out..let me know..good luck
Aug 28, 2010 | Frigidaire FEF366 Electric Kitchen Range
My Kelvinator oven is not working. I've checked the fuses and it is getting power. The 4 burners of the stove still work and I'm getting an occassional flicker of the little orange light if a switch the...
Kelvinator oven not heating? How to replace a kelvinator fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for KELVINATOR element How to Repair Home Appliances
May 12, 2010 | Ovens
When set to bake oven does not preheat and tempature does not increase. when set to broil oven heats
Since your oven has a separate element for bake and broil I would bet the bake element is burnt out or burnt electrical connection to the element. Make sure you disconnect all power to the range before checking.
Mar 21, 2010 | Amana AER5844VAD / AER5844VAB / AER5844VAW...
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
Wattage for oven pleb30s9fc
  • Connected Load (kW Rating) 240/208 Volts: 3.5/2.6
  • Amps @ 240/208 (Approx.): 14.6/12.6
  • Minimum Circuit Required - Amps: 30
  • Bake Element Wattage 240/208 Volts: 3400/2554
  • Broil Element Wattage 240/208 Volts: 2750/2065
  • Armored Electrical Cable
What kind of wires did you buy?
Jul 25, 2008 | Frigidaire PLEB30S9DC Electric Single Oven
Broiling works but baking does not work
CHECK FOR 240VOLTS AT THE TERMINALS OF THE BAKE ELEMENT. GAIN ACCESS BY REMOVING THE BACK PANEL OF THE RANGE. SOMETIMES THE TERMINAL WILL BURN OFF OF THE WIRE GOING TO THE ELEMENT. THE WIRE WILL JUST BE HANGING THERE. BE SURE TO UNPLUG THE OVEN BEFORE REMOVING BACK PANEL. IF THE WIRE IS BURNT, REPLACE THE TERMINAL AND REATTACH TO THE ELEMENTS TERMINAL. IF THE TERMINAL IS DAMAGED, REPLACE BAKE ELEMENT.
IF THERE IS NO VOLTAGE TO THE ELEMENT, REPLACE CONTROL.
Apr 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Kitchen Ranges Logo
85 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
