Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Stopped steaming while I was using it and will not steam at all
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
;l
Posted on Sep 24, 2010
SOURCE: My Shark steam cleaner just stopped working -
I have the same problem - just heard from the support tech to soak the "device" in 1/2 vinegar and 1/2 water. Read on line a customer used vinegar in the device itself, heated it up until it made steam, then emptied it and used distilled water and it was fine. I haven't tried it yet, so we'll see if either solution works . . .
Posted on Apr 01, 2010
VacuumRepair
  • 438 Answers
SOURCE: My steam vac stopped sucking up the water. How do
Hi There,
Here's a link to the instruction manual for your Hoover SteamVac. There is a trouble shooting guide in the back of the book that will explain how to check no suction problem.
If none of these suggestions fixes your machine, please just refer to my answer below the link, these are the problems you may have.
Here's the link:
http://www.hoover.com/pdfs/manuals/F5914900.pdf
There could be several problems that would cause the dirty water tank to be empty after you've cleaned the carpets. I'll try and walk you through each to help you diagnosis the problem.
Possible Problem #1: The dirt water tank lid may be the reason the machine is not sucking up the water. There is actually a gasket on the bottom of the lid where it connects to the actual tank itself. If the lid is not put back on properly (this is really easy to do, I've done this myself many times on my Hoover SteamVac), and the gasket is not sealing the lid to the tank, this will allow the suction to leak, greatly diminishing the suction power to **** the water back up. Try removing the lid and reinstalling it, making sure that it's put back on the correct way, and try to see if this fixed your problem.
Possible Problem #2: The Hoover SteamVac's like yours have a very poorly thought out design flaw to them on the attachment hose. Where the attachment hose connects into the SteamVac when the machine's handle is lowered to get underneath furniture2_bing.gif and is close to the ground it puts a lot of stress on the hose where it connects into the machine (not the end the attachments go on, but the other end). This will cause the hose to tear at the stress point. This is a very common problem unfortunately, and I suspect might be the cause of your suction loss. To check this, remove the dirty water solution tank from the machine completely. Step on the handle release pedal to lower the handle part to the ground. Look at the lower part of the handle portion of the machine for where the hose enters into the handle section, then follow the hose to where it connects into the machine. Right at the end of the hose, before the hose cuff that's connected to the motor, inspect this part on all sides to see if you have a tear here. If you do, this is the reason the machine is not sucking water up off of the carpeting.
Possible Problem # 3. If neither of the first two possible problems were the source of your suction loss, try this one. Turn the machine upside down (you should probably remove both the clean water tank and dirty water tank before doing this, just to ensure that no water spills when you turn the machine over) so that the brushes are facing upwards. Look right behind the brushes for two red plastic tabs that are slightly sunken into the bottom housing of the machine. Pull these two tabs upward as far as they will go. There is a metal filter screen that will be exposed when you pull the tabs. Make sure that this screen is clear of debris. This screen protects anything from going into the motor, and if it has debris blocking it, this can cause the machine to loose suction.
Also make sure that there is nothing in the clear plastic suction channel on the top of the machine where you can see the water being sucked up. Sometimes if something gets stuck in this suction chamber, this can also cause the machine to loose suction.
I really hope that this helped you find the cause of your suction loss. If you were able to diagnosis this problem, and would like me to help you fix the cause of the suction loss, I'd be more then happy to now walk you through the repair as well. Please just use the Clarification Request form here on the same page, and I will then help you out with your repair. I just ask that if this repair was helpful to you, please help other Fixya members to find it, and rate the repair helpful by clicking the 4 Thumbs Up icons in the top corner of the repair.
Thanks,
Chris Jones
GoVacuum.com
Posted on Apr 23, 2010
heatman101
  • 43501 Answers
SOURCE: the shark steam mop stopped steaming
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Posted on Sep 03, 2010
heatman101
  • 43501 Answers
SOURCE: The Shark Steamer stopped steaming. Can I fix it
heatman101
Posted on Dec 24, 2010
  • 11800 Answers
SOURCE: Mop stopped producing steam while
In this unit the steam is generated by the boiling of a liquid. It doesn't matter what liquid: water, tea, wine, even gasoline - as long as it boils you can use it.
The heat needed to make the liquid boil is generated by a simple resistance controlled by a basic thermostat - if the temperature of the resistance goes over 100C the power to the resistance is cut. So in your case either the thermostat or, most likely, the resistance has failed.
Unfortunately there are no replacement parts for this unit - it's a use and junk device that is cheaper to replace than to repair. Sorry, time for a new one.
Posted on Aug 09, 2011
Oreck vacum steamer stopped steaming
Probable failure of the steam generator
Jun 03, 2014 | Oreck steam-it Stick Vacuum
Stopped Steaming.. Can I fix it ?
heatman101
Nov 22, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
heatman101
heatman101
ac
Mar 22, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop heats up but stopped putting out steam.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Mar 08, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Stopped shark steam mop was plugged in and stopped working, it was working fine and just stopped in is only 7 mos old used 1 time weekly
The heating element may have died or there is an obstruction...
heatman101
Feb 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Purchased Feb. '09 and has stopped steaming. Mop
heatman101
bt
Nov 02, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Stopped steaming only releases water into pad
heatman101
ag
Mar 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam mop stopped steaming
heatman101
jlk
Jan 24, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
207 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
