Question about Maytag Dishwasher
My Bosch 5316 dishwasher is leaving gritty residue in all the mugs and glasses. Also doesn't smell very good. I only have an installation manual. Also filter is covered with mineral deposits. Soaking yesterday in vinegar helped some but still caked.
  • Maytag Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 03, 2011
My maytag W10199645 is leaving gritty residue on my mugs & glasses. how can i troubleshoot this?
Try using a dishwasher cleaner. You can get it at any supermarket that sells dishwasher soap.
Nov 06, 2014 | Maytag Dishwashers
Glasses and dishes have a gritty residue...dishwasher is just a year old and this problem has been happening for as long as we've had it. What should i do...This is gross
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Jun 02, 2011 | Bosch SHU9915UC Dishwasher
My electrolux icon dishwasher leaves food residue in the interior of glassware and mugs. It has etched and left milky scratching permanent texture to all glassware. I have replaced glassware change...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
heatman101
Mar 10, 2010 | Electrolux EIFLW55HIW Front Load Washer...
We get a gritty / sandy residue. what can I do?
The cause may not be your dishwasher.
Especially hard water may leave the residue. If you don't have that problem when you hand-wash, then check your pipes. Homes more than 40 years old may have galvanized pipes that eventually rust on the inside. The grit could be grains of rust from the pipes. If you do have galvanized pipes (rather than copper) then you may need to replace them. You could put in a filter as a temporary work-around, but that will eventually clog with the gritty material.
Feb 16, 2010 | Bosch Dishwashers
We have Model DU1145XTPQ6 built in Quiet Partner II and for the past several weeks it is leaving a white, gritty deposit inside all glasses and coffee mugs that are in the top rack. Rotating blade seems...
To solve white, gritty deposits on the upper rack, take the upper arm out. You cannot pry it open but using whatever skinny object you have to poke in the holes, banging the arm gently, lots of chunky white deposits can be shaken out. Rinse arm, replace and we're back in business. For us, this will probably be repeated every three years, but it beats replacing the arm which costs $45--another option to solve this problem.
Jan 02, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Residue on glassess etc
changes r that gritty residue is detergant .water should b around 160 to desolve the deter.
Jul 03, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishes have soap residue despite using rinse aid. Machine is quite abrasive on coffee mugs etc. Unit is Fisher & Paykel DD605SS
use less soap.....excess soap in the rinse cycle will not allow the dishes to rinse properly causing white etching on the glasses and the dishes will have that gritty feeling
Aug 02, 2008 | Dishwashers
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Maytag Dishwasher Logo
177 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
