Question about Lexmark X75 All-In-One InkJet Printer
X75 problem Rather noisy taking in paper, makes a clicking noise as it's printing, leaving an ink blob at the start of the print job, then halfway through stops altogether, then get a message to say "there is a problem with the printer" Hope you can help.
  • Anonymous May 01, 2008
    ink cartridges incorrectly installed
    Genius:
  • 3,587 Answers
You may need to clean those print nozzles..check your printer manager settings
Posted on May 01, 2008
SOURCE:
Hp 3210 not printing magenta and leaving large quantities of magenta ink in printer blobs on right side of paper
defective cartridge; make sure you buy ANY cartridge from a REPUTABLE, not cheap, cartridge company.
Dec 24, 2012 | HP Photosmart 3210 Printer
Tip
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
Printer has stopped printing blue
Make sure that you are inserting only genuine Lexmark cartridges in your printer. Removing then re-inserting the color cartridge into the printer is a quick to minor cartridge communication issues.
Make sure that your color cartridge still has substantial ink level for printing using the Lexmark Solution Center software on your computer.
Click Start > Programs > Lexmark X74-X75 > Lexmark X74-X75 Solution Center. Check the ink levels.
If color ink level is still good, then it probably just needs some cleaning. Print quality issues can be due to dirty or clogged print cartridge nozzles. From the Maintenance tab in the Lexmark X74-X75 Solution Center, click Clean print nozzles to fix horizontal streaks. Your printer will then print a test page. Try to print a color page again to verify that the problem with the blue color is fixed.
If the problem continues, try to insert a different known working color cartridge to identify if it's a faulty cartridge issue.
Oct 26, 2011 | Lexmark X75 All-In-One InkJet Printer
Ink saturates the photo paper causing blobs of wet ink to ruin the print job.
Remove the cartridges. After this, remove the print head unit. Take some soft cotton tips and alcohol. Clean the print head unit until there is no ink on the lower end of it. Dry the print head of so that no alchol remains on it. next replace the print head and cartridges in the unit. Run the printer through a cleaning and alignment then print a test page.
if the problem persists, you can contact kodak and get a new print head from them. Sometimes you can get one for free, other times you may pay 1/2 the price of the printer. Having the print head seperate is how the ink for these are so cheap.
Jan 21, 2011 | Kodak ESP 5 Printer
I turned the power to the printer off in the middle of a job and then cancelled it. There is a paper halfway through and the error light is flashing. I cannot print a new job. Janice Simpson the model...
Disconnect the "data" cable between the printer and your computer.
Turn the printer on.
If the light still flashes, you have a "paper jam".
If you cannot "clear" it yourself, take the printer to a qualified technician, for servicing.
On your computer:
Click Start
Click Control Panel
Click Printers
Double-click the icon for your printer.
Click on the "suspended" (or "active") print-job, to "select" it.
Right-mouse-click on the print-job, and choose "cancel".
Nov 09, 2009 | Office Equipment & Supplies
Ink blobs on paper
It could be both. Leaky ink can be a problem and that probly is the problem. But, make sure your rollers are clean and cheak that your ink is not leaking. I hope this has helped you.
DigicalJAI
May 19, 2009 | HP Photosmart C4280 Aio Printer
My Lexmark X75 will print but not copy. When I
I have an X75 at home and I remember the computer has to be on to copy, so it's really just doing a scan and then an immediate print. Are you copying from the button on the X75 or from the All-In-One Center software on the computer? If the button, try it from the software.
Feb 24, 2009 | Lexmark X75 All-In-One InkJet Printer
Photosmart C6300 pictures are printing very wet and grainy. printer is also very loud - almost as though the parts were scraping and banging.
Sounds like you have the wrong paper setting in your print properties. I would use photo or high bright 24lb paper and set the paper type in your printer properties prior to executing the print job.
Regards,
Worldvet
Nov 12, 2008 | HP Office Equipment & Supplies
Paper feed problems
Set your printing job in print preview you can adjust inexact spaces in four corner of sheet of papers./ do't print w/out prvieew
it will wasting ink and papers.
Oct 31, 2007 | HP PSC 2355 All-In-One InkJet Printer
Printer makes clicking noise
Make sure the printer is not out if ink. When the light flashes this may be the case. Also check the print queue. If it contains pending print jobs and there is no paper the light will flash. Here is how to check print queue: Click Start > click priters and faxes > double click printer icon and see if there is something ... If you see any print jobs delete them right away. and restart your computer. This should solve your problem.
Oct 05, 2007 | HP PSC 2410 All-In-One InkJet Printer
Lexmark X75 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
