Question about Car Audio & Video
1990 ford ranger
Trany on my ranger is stuck in one gear how can i fix the problem trany is good, i bought it at junk yard
  • Capito May 11, 2010
    Manuel or automatic?
  • 185 Answers
Sorry wish i new about traneys
Posted on Apr 07, 2008
6ya staff
SOURCE:
2004 FORD RANGER 4.0L 4X4 5SPD STUCK IN 4TH GEAR
The synchronizers are the reason it won't come out of gear. They are damaged and the slide ring won't go over them. You will have to remove the transmission and replace the 4th gear synchronizer. I wish I had a better answer. Hope this was helpful. Good luck.
Feb 19, 2015 | 2004 Ford Ranger
Im going to the junk yard to get a power steering pump and i need to know if theres any other year than 1990 that will fit on my 1990 ford tempo?
WHY BUY A JUNK YARD POWER STEERING PUMP 12 YEARS OLD SEALS PROBABLY CRACKED DRIED UP. 94 TOPAZ HAS SAME ENGINE 2.3 2300CC. FROM 1990 TO 1994 HAS SAME ENGINES.
Feb 02, 2011 | 1990 Ford Tempo
I have a 1989 Ford Ranger with a Mazda Standard Transmission. The Reverse has gone out on the transmission. How difficult to replace this gear would it be or would I do better to find a transmission in a...
Well, to replace a gear in the trans, you need to be able to disassemble the trans. Apart is easier than reassembly. Gears are costly, and when one goes out there is also a mating gear that gets damaged, so that is two big parts. I suggest for the do it yourself guy, consider a wrecking yard trans.
The only down side is you may have to r&r an extra time, if trans is no good..., still worth it.
At our shop, we would often buy the wrecking yard trans and rebuild that, as the big parts add up so fast.
But, just get a used one, and not the cheepest, and get back on the road...for the least money.
Oct 15, 2010 | 1989 Ford Ranger
I have an 89 ford ranger that i have had to put two A4ld tranys into. I have no passing gear and an odd plug, help!!!! when the frist was installed by a transmission shop starts with an a and ends with co...
YOU NEED A ATSG TECHTRAN MANUAL WHICH IS A TRANSMISSION REPAIR MANUAL WITH ELECTRICAL DIAGRAMS WITH PRESSURE SWITCHES.YOU CAN GO ON LINE TO INTERNET FIND THE REPAIR MANUAL.ANY TIME WHEN YOU WORKING ON TRANSMISSION WHEN YOU HAVE ELECTRICAL PROBLEMS OR SHIFT PROBLEMS WITH 3 - 4 PRESSURE SWITCH.OR ANY SHIFT SOLENOID PROBLEMS A TRANSMISSION REPAIR MANUAL WITH ELECTRICAL DIAGRAM WILL BE HELPFUL.BUT GO ON LINE LOOK FOR ATSG TECHRAN AUTOMATIC TRANSMISSION REPAIR MANUALS. IT HAS THE FORD A4LD TRANSMISSION MANUAL.
Mar 07, 2010 | 1989 Ford Ranger
1st, 2nd gear and reverse will not engage on my 4 speed manual transmission. what is the problem and how should i go about getting it fixed?
Sounds like the transmission is worn out. It could be rebuilt or call around to the junk yards and see if any has a good clean used trans.If you get a junk yard one change the fluid before you drive the truck.
Nov 07, 2009 | 1990 Toyota Pickup
1990 Ranger had the battery backwards now won't start
their is a very good chance the computer has been shorted out.You need someone to run code from obd port and see if computer responds
Sep 15, 2009 | 1990 Ford Ranger SuperCab
1998 saturn manual transmission will not engage in any gear
Well, there is one thing for sure the trany is damaged. You will be further ahead looking for another junk yard trany rather than worry about what is going on inside since there is probably parts and pieces inside that would still give you trouble without completely overhauling it, plus a junk yard trany, standard would be easy to come by.
Sep 01, 2009 | 1996 Saturn SL
2203 ford taurus SEL transmission
sound like you need a new trany I would recommend junk yard for cheaper trany cause it would cost more to rebuild.
Oct 25, 2008 | 2003 Ford Taurus
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
