Question about Hotpoint First Edition FEW10P Front Load Washer
Fitting new brushes on a hotpoint washing machine
  • Hotpoint Master
  • 3,463 Answers
Remove lower rear panel.remove drive belt, undo screws that secure motor. unplug motor lead, noting which way it is fitted.,lever motor back and remove, replace brushes and refit motor and belt.
Posted on Jan 04, 2009
  • 7 Answers
SOURCE: hotpoint aquarius 1000 deluxe W22 washing machine
the newer type motors have carbons tht are fixed in place you would need to remove the motor and on either side will be the carbons they need to be un-screwed to be replaced
Posted on Jan 30, 2008
SOURCE: Hotpoint washing machine WMA66
Thank you gittos73.
It's as gittos says. When you open the door and look inside, at the very top of the door is a white square. This holds the metal clip. If you push the little white dot in the middle of this clamp gently, it gives way and you will see the round metal clip that goes all the way round the door rubber (gasket). Remove this and you can put your fingers round the gasket and pull it toward you.
Then take the lid off the machine and you will see a 6mm nut with a spring behind it and a wire clip similar to the front one, going round the gasket where it attaches to the drum. This has a crosspoint (phillips type) head on it and you can get a small screwdriver into it and undo it all the way. Then slide the gasket off and it will come away.
Fitting it is the reverse but it is a little bit tricky as you have to get the gasket behind the lip to make the seal. Take your time and they will both go round properly.
Posted on May 28, 2008
SOURCE: Hotpoint wma57
the filter is at the back where it enters the machine undo the cover you will see a big black tube clipped in a few places undo and the filter is inside there
Posted on Dec 23, 2008
  • 56 Answers
SOURCE: fitting new belt on hotpoint washing machine
check if plug is loose on motor,in the general area where the belt was changed has anything been disturbed,cables i mean?,sounds like the motor brushes may be worn(this would cause motor to stop),they are situated 180degrees apart at one end of motor,they are easy to change,there is a spot at brushes to put a screwdriver in to remove brushes-hope this helps
Posted on May 15, 2009
  • 353 Answers
SOURCE: Fitting pump to hotpoint WF250
disconnect the machine hoses and all drain put it on its side you will see the pump usually help in place by 2 screws/ 2 hose clips/ 2 wire thats it pump should cost no more than approx.18.00
Posted on Jun 30, 2009
Have a hotpoint washing machine wma34p. Brushes gone; got new one from the web genuine hotpoint part but comes in a ceramic holder ; does not fit; does not fit if take out of holder (one attached to motor)...
There was more than 1 type of motor fitted to this model of washer. so it is important to get the correct thype of brush.
Have you tried Hotpoint direct?
Go to---
WWW.HOTPOITSERVICE.CO.UK
Follow the menu on the left.
Feb 01, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Model WM75 Error Code E30 (Motor Drive problem)
what does e30 mean on wm75 hotpoint ultima 1200
Dec 02, 2010 | Hotpoint Washing Machines
Drum not turning
Get a new se t of LAMINATED brushes watch how you fit them , they break easy..After fitting make sure motor does not spark too much, parts cost ...!" pounds....
Sep 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Fitting new belt on hotpoint washing machine
May 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Brushs
no they dont make a noise when they are new in correct fitting of the brushes cause this.. on certain motors the brushes can be fit onto it in two ways.. check to see if you motor has more than one position method
Aug 20, 2008 | Hotpoint WMA54 Front Load Washer
Fixing new brushes
To fit new brushes to Hotpopint, you need to remove the rear panel if the washer.
There you will see the motor. remove the motor and fit the new brushes
Mar 27, 2008 | Hotpoint First Edition FEW10P Front Load...
Brushes
if replacing the brushes has not fixed then its most likely the motor is duff.
Feb 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint First Edition FEW10P Front Load Washer Logo
205 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
