Question about Panasonic Workio DP-2000P Copier
Workio dp 2500 everything is working properly no image on the drum the machine does not report any error
  • 59 Answers
Hi just cheq tha scaner lamp is glowing if glowing may you have problem in charge unit or charge crona
thanks
Posted on May 15, 2010
Workio DP-1820E Copier: Can anyone tell me how to clean a workio 1820 phot...
the copier can't be cleaned. The opc drum needs to be replaced so unfortunately its gonna cost you some moola
May 16, 2010 | Panasonic Workio DP-1820E Copier
WORKiO DP 2500 everything is working properly no image on the drum the machine does not report any error
yep!
For dp-2500 the common and usual problem is light or no image on print
and the common cause is the contact plate between drum and magroller. there must have a proper contact through that plate.
sometimes we also encounter the contact spring(3) of hvps going to process unit - misaligned position.
you may also check the tension spring of the drum (located inside the drum) if it has proper contact to the shaft.
... pls inform me if this still isn't helpful.
Mar 22, 2010 | Panasonic Workio DP-2000P Copier
I have a Workio DP-190 all in one Fax Machine. We have recently replaced the toner drum in the last couple of months. But are now recevining a error message saying to replace drum unit. Is there a way to...
yes there is a user troubleshooting to reset the drum counter.
you may follow these steps:
  1. press FUNCTION key
  2. press 1 to select general setting, then press SET to select
  3. press scroll V or /\ to locate the "replace drum" setting
  4. it think it will as for confirmation, if so just press 1 for yes, or 2 for no.
  5. press stop key to exit
  6. you might turn off/on your machine if needed.
that's it. :)
Feb 18, 2010 | Panasonic Workio DP-190 Multifunction...
Panasonic DP 3530 printer keeps saying Machine error E03-40
E3-40 is the copy density sensor on the drum unit. Toner is probably dropping from the drum unit onto it. You have to remove the drum to access the sensor.
Apr 13, 2009 | Panasonic Workio DP-3530 Copier
Workio DP 2500
means that the machine needs a good cleaning because it reached so many copies. has to be serviced by a dealer
Sep 23, 2008 | Panasonic Workio DP-2500E Copier
Service Manual Download -> Exchange Drum of DP-2500
For the service manual of a Panasonic DP-2500, pls try here or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 29, 2008 | Panasonic Workio DP-2500E Copier
What can I do to fix it ?
What is the problem first? Then maybe a solution..
Jul 21, 2008 | Office Equipment & Supplies
Mac Drivers for Workio DP-1820E
you can find the PS driver you want at workio.com
but for use with a mac you you need a PS"post script key installed" in your machine before you can do anything
May 25, 2008 | Panasonic WORKiO DP-1820E All-In-One Laser...
Panasonic Workio DP-2000P Copier Logo
152 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
