Question about Garden
Troy Bilt tb25et trimmer won't start. Changed plug and gas and still won't start. A couple of weeks ago it ran for about 5 min then stalled. Won't start since. I have inspected carburetor and don't see the varnish buildup?
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
#1 Taper
  • 1040 Answers
SOURCE: Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
Posted on Jun 21, 2009
SOURCE: Troy-Bilt Chipper/Vac 5HP gas leaks out the carburetor
The float may have a hole in it causing it to sink and not seal the needle. Look at the float and check it for holes. You can shake it and listen for gas inside it. if so replace float.
Posted on Sep 07, 2009
  • 89 Answers
SOURCE: troy bilt mower. starts but shuts off within seconds.
sounds like you have a primer bulb if you take the bolt that holds the float bowl off and take a tip cleaner that they use for welding tips and clean the holes out of the side and the top it should let the fuel in again that will save you a trip to a service repair shop
Posted on Nov 23, 2009
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered)
Toro String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Jun 11, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Starts up when choked then dies. Has a new carb and using 4 cycle fuel that is fresh. Ran great till 3 weeks ago then this.
I just went through the same problem with my Yardworks trimmer that is identical to this. If it starts when chocked after priming but stall immediately would usually indicate that there is no fuel getting to the engine. I also found that switching to non-ethanol premium fuel made all the difference in the world.
Jun 06, 2015 | Troy-Bilt 29cc 4-Cycle Curved-Shaft Gas...
Troy bilt trimmer idle problem position 2 shut off
try fresh fuel fuel is only good for 30 days in small engines if not the carb needs a good cleaning
Jul 25, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
TB70ss will not accelerate
Change the spark plug..
Change the fuel filter..
Check the fuel line for crack/splits..
Make sure the primer ball is sealed and not succking in air while running..
If it still acts up - it might need the carb might need to be rebuilt..
If it sat for a long time - the fuel will shellac in the carb and provent it from working properly..
Good luck..
Sep 10, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy-bilt TBP6040 4-cycle stalls out after about 10 minutes. Started doing this the 2nd time I used it. After it stalls out it will not start until it completely cools off. Fresh fuel in it. Arrestor...
I have the same model from Troy-Bilt. I have only had it about 4 or 5 months. Mine has started using a LOT of oil. I noticed a significant increase in temperature compared to my old Husqvarna 2 cycle. Mine does not completely stall, but it does start to sputter when it gets hot. I am going to take mine back to Lowe's where I bought it. So far I am VERY unhappy with the TBP6040.
Aug 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Engine stalls when engaging cultivator tines
im 99 percent sure all you have to do is get the carburator cleaned out.
Jun 28, 2009 | Troy-Bilt Garden
Trimmer will not start.
Yes. Your carbeurator is gummed up. Get some new gasoiline and add some carbeurator cleaner to it, usually one ounce per gallon. Dump the fuel u have in there and put in the new fuel.
Also, get some spray carb. cleaner, remove the air filter and put a couple of squirts into the air intake chamber. Then start it.
Finally if it still won't start, use a squirt of starter fluid to get things going and get the carbeurator cleaning into the system.
May 20, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
