Question about Dishwashers
Doesnt pump water out - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
Dishwasherdoesnt pump water out - 2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on May 15, 2010
Rinse cycle doesnt work
Because the water from the wash is still inside it and has not drained. So you need a new drain pump!
Jan 19, 2014 | Speed Queen AWN432 Washer
Doesn't overheat, but losses coolant. also has oil in resivior. heater doesnt blow hot air
sounds like bad head gasket or intake manifold need compression test thing that scares me is oil in water resivoir
Jan 10, 2014 | 1992 Cadillac DeVille
How do I check water pump?
if it doesnt leak and doesnt squeak or the pulley wiggle then leave well alone
Sep 03, 2010 | 1996 Acura TL Series
My simpson eziset605 came up with an error pu now it doesnt spin... i turned machine off and left it over night... tried again it washed ok but doesnt spin... the water drains out but the clothes are still...
PU is pump the drain pump probally has a hair clip or stone or summat interfearing with the **** impeller. if the pump doesnt function correct then it will not go into spin mode.
May 21, 2010 | Washing Machines
My kenmore clothes washer won't empty water
some models reverse the moter to activate the pump .. some have a solonoid to engage the pump .. depends on what model you have ... if the motor runs but still it doesnt pump then look for a broken belt that drives the pump .. on some there is a little universal joint that sometimes breaks .. often the pump becomes clogged with coins and other debree .. you didnt say if the spin cycle started or not .. if it doesnt then you could have a bad door switch .. if that doesnt operate then the spin cycle wont start and it wont drain as well .. you can test for clogs by taking the drain hose out and placing it on the floor .. if a lot of water comes out then its not clogged .. if no water comes out then you have a clog .. (be prepaired for lots of water) .. even if water comes out there still could be a coin stoping rotation of the pump .. there is no reset on the pump, it is almost always run by the main motor ..
Sep 12, 2009 | Kenmore Washing Machines
At the end of each cycle there is a puddle of water at the bottom, it doesnt sound like its pumping properly
Solve at the end of each cycle there is a puddle of water at the bottom, it doesnt sound like its pumping... (More)
Aug 19, 2009 | Zanussi 24 in. DE6544 Built-in Dishwasher
Washer doesnt drain all the water out
you will need to check drain pump for debris but also if the drain pump is loud then it needs to be replaced..
Feb 24, 2009 | Washing Machines
Ge dishwasher is 12 yrs old. water doesnt drain, checked trap, its clear..
check the pump and motor to see if it is working the motor might run but the pump could be to weak to move the water, and the opposite the motor could be to weak. if you hear the motor run then its a fairly simple test put a small rag in front of the intake to the pump and carefully move it close to see if the pump tries to pull it in dont let it suck it in that will cause lots of problems.
Dec 09, 2007 | GE 24 in. GSD3620Z Built-in Dishwasher
Dishwater fills with water, hot...but doesnt wash?
when in the wash phase, listen for a low hum near the wash pump. if you hear this it indicates the wash pump capacitor is faulty or something jammed in the pump.after that you will have to access the wash pump and check if there is any supply to it
May 04, 2007 | Maytag 24 in. MDB7751AWS Stainless Steel...
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
Owen Barnes
