Question about Sanyo CLT2054 20 in. EDTV-Ready LCD Television
CLT2054 I have had my TV for about two years. Two days ago a yellow band about 3/4 inch in height has appeared at the bottom of the screen. What would cause this? Can it be corrected?
  • Margaret Summers Apr 01, 2008
    Do you think this condition will worsen? I will probably have to buy a new TV wondering how long this one will last.
    Sergeant:
  • 308 Answers
This set has a history of problems that seem to occur around the two year mark. My own experience with this model is with a defective "Ball Grid Array" IC which has balls of solder under each contact point where the device is surface mounted to the Printed Circuit Board. The disadvantage of BGAs is that they do not have the flexibility that a leaded package has under extreme temperatures and mechanical stress, which means that the solder joints can crack over time, creating oddball symptoms like you are experiencing. The short answer is that the board is not field repairable and a replacement board is not available that I know of.
Posted on Apr 01, 2008
SOURCE:
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Disney princess tv suddenly narrowed the visible part of the screen. Now everything is squished into a two in wide band with all the rest of the screen is black.
if that 2 band according to you from top to bottom,it has a defective vertical stage.if this two band appears one on top and one at the bottom,it`s on vertical stage.leaky capacitors,resistance changed or resistor devalued ang ic`s, are too weak to amplify a signal to make the screen complete....
Jan 29, 2014 | Disney 13" TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
I HAVE A LG50PQ30 PLASMA TV,WHICH IS JUST OVER A YEAR OLD AND OUT OF WARRANTY. AFTER THE TV HAS BEEN ON FOR A FEW HOURS THERE IS HORIZONTAL LINES APPEAR ABOUT 6 INCHES FROM THE TOP OF THE SCREEN IT STARTS...
Hello that's a 2010 model set. It sounds like the y sustain board is failing (part # EBR61855101), it usually starts with bad connections on it. A screen shot would be helpful...thanks
Apr 28, 2017 | LG 50PX5D 50 in. Plasma HDTV
I have an 8 inch wide yellow vertical band in the picture of my 52 inch LCD Samsung TV, what is this? I just moved into my new house a couple of weeks ago and purchased a new 52 inch TV, We are without...
If the band is there within the menu then the screen has a fault. If not then possible signal ghosting issues and a proper aerial should fix that.
Jun 30, 2017 | Televison & Video
I have a 2 inch black band which appears intermittently dwon the full height of a 22inch JVC lcd television can anyone explain it for me? thanks
If it is black vertical band from the top all the way down to the bottom of the screen, your LCD panel is going bad and you will see more bands and it will get worst.
Nov 04, 2009 | JVC LT-23S2 23 in. LCD Television
TV picture size (height) adjustment
TV model # PCJ 612 R SAMSONG SERIAL # 39Z 300 125 W
Dec 06, 2008 | Televison & Video
Red Dots on My Plasma.
Did you get this problem resoslved? I had the same issue a few months ago. I tech came by and took my TV to the shop, a few days later he said it was fixed as they needed to make some adjustments.....The TV has been fine up until a week or so ago and now the red dots have appeared again. Was wondering what happened to yours.
Dec 17, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
Sanyo CLT2054 20 in. EDTV-Ready LCD Television Logo
56 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
