Maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Check to make sure that the contacts on the printhead carriage is clean.. Remove both cartridges. Unplug printer.Wait at least 3 minutes. Plug printer back in. Printer will turn on. Reinstall cartridges.
This is general a result of died ink. Try the following
The vista directions you can follow with windows 7 as well. http://www.t-x-2.com/articles/archive/how-to-clean-your-print-head-with-windows-xpvista/
If that dosen't work try manual cleaning below. http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=445462&prodTypeId=18972&objectID=c00013609
If all of the above does not work you will need to buy a new ink cartage.(Do not refill)
Greetings,
Try this In service mode. Put Stop/reset 4 times orange => reset waste ink. Put stop/reset 8 times orange => set level ink.
This isn't set level but it disable ink check. The LED warning still blink but no error code appear anymore.
The installation disk for your printer has a setup wizard that monitors your ink levels in your printer. Go through the installation again as it will not hurt anything and you should find it on one of your pop up screens that it leads you to.
You cannot reset the ink level for the HP 60 ink cartridge. Simply ignore the ink level indicator if you refill your cartridges. It is only an estimate of the ink level anyway. See pg 72 of the user manual.
The ink level indicator is only an estimate to give you an idea when it's time to buy a new cartridge. You cannot reset the ink level indicator so simply ignore it if you refill your cartridges. See pg 72 of the user manual which you can get here:
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
The Deskjet 6940 will only show ink level for original HP cartrdgies. Refilled or reman cartridges will show as empty or unknown in the toolbox. This is not an issue with the driver, the cartrdige itself has information that it has been previously used and this is not resettable. You can continue to print with a cartrdige that has unknown ink levels, you will just not get low ink warnings.
Regards, Bob Headrick, Micosoft MVP Printing/Imaging
It is best for you to take time to a Hp Center. You will damage the cart if you try to take them out. Hp service center has special tools which they use to take the cart out. If you are really good to them they will even do it free for you. It will not take more than 10 mins for the job.
