Question about Cell Phones
Had a Razr which worked great for three years, the...
Had a Razr which worked great for three years then my accompanying wall charger started showing a quick green flash folowed by permanent red. Went to Verizon store where the guy sold me a Verizon charger. Too it home and charged up both batteries after which the phone sumply refused to see any signal. I now notice that the new crager is 5.0 volts versus the old one which was 4.2. Did the new charger blow my phone? dale d. escondido ca
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cell Phones Master
  • 1,001 Answers
  • QC2.0 Applicable Phones:Samsung Galaxy S6/S6 Edge/Edge+, Note5, Note 4/Edge, Nexus 6, Sony Xperia Z4, Z4 Tablet, Z3, Z3 Compact, Z3 Tablet Compact, Z2 Tablet, Motorola Droid Turbo, Moto X 2014, HTC One M9, HTC One (M8), LG G4, Asus Zenfone 2, etc.
  • Convenient to Use: with stable stand, compact and portable design for the usb charger.
Chornic Quick Charger 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
Posted on Dec 16, 2016
  • 641 Answers
It might have,contact www.phoenixtec.ca fill out the contact form and they will respond very fast
Posted on May 15, 2010
I left my Motorola Razr 3 on charge last night as usual. This am it had switched off & will not switch on again. I have attached it to my computer via USB charger & the green light is showing on the front...
Computer will not charge your phone if the computer is off, may stop charging during standby or sleep mode. If failure to charge over night was on wall charger its a problem with charger/cable. OR your phones battery is junk.
Aug 11, 2013 | Motorola Mobility RAZR V3
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
Jassy 1103, will not start charging the battery.\r...
the 1103 uses an onboard charger. Charger's life span is about 3 years; some fail in 6 months, some in 6 years keep in mind. You can charge the 1103 using an offboard charger which are available for about $50.00 on Ebay. Search for electric wheelchair charger. You want one that has a 4 to 6 amp rating.
The offboard charger has a 3-prong connector on one end and the other plugs into a grounded wall outlet. Plug the charger into an outlet and the three prong connector into the female three prong connector located at the bottom front of the joystick. Give it a good overnight charge and it should be back up to snuff in the morning.
May 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Motorola razr2 v9m wont charge
My guess is that the charging port in your phone has gone bad. By holding it a certain way, you may be reconnecting it just enough to make the connection. Probably have a loose or broken wire inside your phones port. You may also see this is a problem if you try to hook it up to a pc.
Feb 05, 2010 | Motorola Mobility RAZR2 V9m
Razr will not charge with wall charger
Your charger is faulty. If your phone is able to charge off of other sources (computer, car charger, another wall charger) Then, the charger needs to be replaced. Some mobile companies have a 90 warranty on accessories like the charger and battery. Then the mobile manufacture (Motorola) has a 1 year warranty on the charge and battery. I would check on that, and get those replaced.
Feb 04, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Screen and keypad.
well, there is no much to do in there, either the charger, the battery , or the phone is dead.
Try removing battery from inside and then put everything back, and try restarting it again, after charging for ten minutes.
If it still does not work, and the phone is new, call the number on the phone booklet, and ask if you can take your new phone to an authorized shop for a checkup, if it is a faulty charger or battery, they usually replace them on the spot.
Dec 27, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
RAZR V3 - New battery w/full charge drains in 1hr of standby
take out a battery and check if there is any red paper dots on the back of the phone. If you do have a dot that is at least partially red, that means that your phone got wet and it can not be fixed.
Nov 15, 2008 | Motorola Mobility RAZR V3
Motorola razr v3m battery problems and bootloader ini showing on screen
Well it is both. It should only ever say bootloader when it is plugged in to a PST machine and getting the software updated. I would say that it the hardware is causing the poor battery life or a combo of the battery and the phone.
Apr 24, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Charging problems
umm dat mite be a prob becuz the car usually pumps more voltage in the fone...........and if too much is pumped it damage the circuit board and mite even fry the system...... be care ful and keep trying the wall charger..........hope it works
Feb 21, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
