Question about Soyo SY-K7V Dragon Motherboard
Soyo k7v dragon plus motherboard continuous
Hi. I have a Soyo k7v dragon plus motherboard system that's been working fine for almost ten years up until today when I booted up the pc..the fans started up but I then heard after about 4 seconds a 2 second beep then another 4 sec another 2 second beep and so on continuously with a blank screen..changed the memory..still same issue..help is appreciated!!
    Scholar:
  • 128 Answers
Hi! 1 long beep and a 1 short beep is a motherboard failure. it means that you may need to replace your 10 year old motherboard. Since the motherboard was this old already, there will be no chance that you can purchase a part for this to be repaired.
Posted on Jun 06, 2010
  • Soyo Master
  • 11,800 Answers
2 beeps = memory problems. Since you get them even after the memory has been replaced then the problem is in the motherboard itself. Check the capacitors for bulging. If you can't find ones or you can't replace them then the motherboard is dead.
Posted on May 16, 2010
What does three long beeps soyo sy-p4vgm indicate? Everything was running well. Powered down, powered up..beeps thanks
might be a faulty connection/lead make sure they have secure connections
test all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive also cd/dvd/3.1/2 inch floppy drive leads
hope this helps
Sep 30, 2010 | Soyo SY-K7V Dragon Motherboard
Hi Jopav1,
At the age of *********** board, I would recommend physically looking at the board, in particular, the large upright capacitors. If the tops are bulging, or have anything leaking out of them, send the board to a recycler, and look for an exact replacement on the used market, or replace with new. I just bought the same board you have today for $25, with AMD 1800 CPU.
At 10 years of age, the battery is probably past due for replacement too. It is a standard CR2032 3Volt battery. If you replace it quickly, you may not loose your BIOS settings.
If you have a volt meter, you can check your power supply voltages. Again, your manual will show what voltages to expect at each power connector pin. A range of +/- .05V is generally allowable on all sources.
Also try unplugging all boards and powering it up. The beep should change to a sequence of 2-1-3-1 beeps, indicating that it's not able to see the video card. If you still only get a repeated long beep, It's possible that the CPU itself may have died. These are also available very cheap at this point. The fact that you are getting a cycling beep indicates to me that the CPU is OK though.
I looked up beep patterns and did not find anything for one long repeating beep for the Phoenix BIOS on your board. There is no mention of them in the Soyo manual either.
Last resort is resetting your BIOS settings to "First Birthday", and try again. This will require you to re-set any manual settings you had set previously (probably 10 years ago). This is done by moving the jumper located between the green LED, and the battery, to the two pins nearest the LED, for a second, and then back to the position nearest the battery.
Good luck
Video Flyer
Mar 22, 2010 | Soyo SY-K7V Dragon Motherboard
What is the bios command for Soyo KT600 Dragon Plus Motherboard?
When system is switched on press on F2 if it does not take then again switch on and press Del or then try one option F12.
Regards.
Feb 08, 2010 | Soyo KT600 Dragon Plus Motherboard
What dual core CPU is compatable with the dragon plus?
hello sir, hi im afraid that the dragon plus has no AMD x2 (DUAL CORE) compatible CPU. if you want a dual core motherboard compatible, get the socket AM2 version for AMD or the LGA 775 for intel processor.
Nov 06, 2009 | Soyo KT333 Dragon Plus Motherboard
Where can I get a manual for my KT600 DRAGON PLUS V2.0
I have a PDF file for SOYO KT-600 Dragon Plus V2.0. I can email it to you.
Oct 15, 2009 | Soyo SY-K7V (SY-K7VKPE) Motherboard
Soyo SY-K7V Dragon Motherboard Logo
162 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
