Question about HP Pavilion dv1000 Notebook
Pavilion dv 1000
When try to boot it up , some times it boots but if i put my finger near the mouse pad it will shut down but with all lights still on
it is pavilion DV1659us
    Master:
  • 474 Answers
Hook up a extrenal mouse and see if it still does it. If not, get into windows and check your power save options and make sure its not going into standby. Windows defaults to Three minutes on laptops and it may be going into standby.
If it blanks out with all the lights still on, try pressing the power button once and see if it comes on to where it was before. If it does, its going into power save.
These options are in the display settings which you find by right clicking on the desktop and selecting properties in the little box, it will open a box with tabs. click on the screensaver tab and at the bottom it has a button for power options, click it and change settings accordingly, also make sure the screen saver isnt set to come on after like a minute, usually you want it for 5-10 for a laptop and you only want power save options set for when its on battery power.
Also make sure that it doesnt have it set to go into standby when you close the lid.
Posted on Apr 01, 2008
My mouse is frozen on my hp dm4 and the orange light in the left hand corner is not on, nor will it turn on when double tapped
First thought is look at the top of the touch pad, there is a button. Push this button once and see if the mouse works. HP put this button on to deactivate the mouse if needed.
If this does not work, plug in an external mouse and see if it works, if not do a hard boot on the computer and try the mouse again.
Jul 20, 2011 | HP Pavilion dv6000z Notebook
My hp pavillion dv 1000 shut down then turns back on but the screen is black and it reboots itself every 5 sec.
thats a trojan or virus in your laptop,i suggest u format or boot from cd/dvd rom with a compatible operating system disk(WIN7/XP/VISTA/2000),THEN U DO system repair..THAT IS IF U HAVE ANY IDEA ABOUT IT,IF NOT,TAKE IT TO UR REPIARMAN
Nov 25, 2010 | HP Pavilion dv1000 Notebook
I left my hp on the bed , running, and it is not responding ........what could be the damage
the dv and tx series are very poorly designed, they can't keep the internal electronics cool enough to run properly (even under ideal conditions they will fail in just over the warranty period) with the vents obstructed cooking your motherboard becomes a near certainty.
if you really need to get this machine to boot up again (eg to rescue files before it is completely done)
step 1 power down completely (you can hold the power to off for a few sec or unplug and pop the battery.)
once system has cooled test to see if it can boot. If the lights and fans all come on but the screen stays black... (warning u should never try this with a healthy pc) ..
then
turn on pc (lights come on but nobodies home, no boot, no post, no nothing) put the pc into a bag or case (whatever you would carry it around in should work)
let it run for about 30 min or so (it should be really hot now)
try booting again.
it might just be superstitious but i have found that holding down the f10 key while booting seems to help. good luck
and don't buy HP unless you want a half-*** product
Oct 20, 2010 | HP Pavilion dv1000 Notebook
Hp pavilion dv 8000 will not boot from DVD drive or Hardrive. It goes to LAN card regardless of precedent set in the BIOS
when u start ur system try pessing f8 or f10 or watever is the key for boot option nd from there u can select from which device to boot
Apr 05, 2010 | HP Pavilion dv8000 Notebook
I have a hp pavilion dv 1659 us (dv 1000) the sata drive goes bad
It will recognize the new drive if you were able to "migrate" your data from the old drive. If not, you can clean install by booting from an optical drive (changing your boot order at start-up) and using a new OS disk or your recovery disks. You might be able to perform a remote partition & format and install from one drive to the other with USB external enclosures for each drive and another computer (depending on the 100G drive's condition). I hope this helps.
Feb 23, 2010 | HP Pavilion dv1000 Notebook
I have a HP Pavillion tx 1000 and the strip on the right of the mouse pad that allows me to scroll up and down a page is not working. I run my finger along that area and it allows the mouse to move up and...
Try contacting hp through their live chat and aqsk them how to reinstall the mousepad driver. if they cant help try restoring your computer to a date before the problem started or reset the operating system.
Jan 29, 2009 | HP Pavilion tx1000z Notebook
USB ports all seem troublesome
You cannot use wireless keyboard or USB keyboard in setting up the computer BIOS, what you need is a PS2 keyboard, if your motherboard supported USB booting, in Boot section of your BIOS change the Boot Priority to USB Generic Device, after you change the boot priority change the First Boot to Removable Device or USB Generic Device.. and after that save your configuration and restart the computer.. you must put the USB stick first before you configure the BIOS.. TY
HOPE I CAN HELP
Dec 05, 2008 | HP Pavilion (PN153AAR) PC Desktop
Hp a305w Pavilion No Mouse or Keyboard at first bootup
i would reset your keyboard and mouse settings to default then shut down pc.. unplug components and wait for 3o secs and then try again.. if the problem persists, you may just have some loose connections especially if your pc is older..make sure there is enough slack for your mouse and keyboard wire to move around.. i know sometimes we can ruin them if we have then stretched to far out.. hope this helps.. d
Feb 22, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
HP Pavilion dv1000 Notebook Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
