Car audio i am installing a premier deck with front,rear and sub preouts.my amp is too powerful for my rear speakers so can i use the speaker wires off the deck to run them and then the preout for the amp to run the fronts? it is going in a truck where the fronts are 6.5's and tweets through crossovers and the rears are only 4's should i use the hi rear preout or the mid front preout for the amp running the fronts?
  • 31 Answers
Yes you can use the speaker output in conjuction with the rca pre-outs...but depending on the wattage of the amp, there may be a big difference between the loudness of the front speakers over the rear speakers. If you have a 4 channel amp you can put the rear speakers on the amp also and lower the input gain for the rear speaker. Or if you have a 2 channel amp, you could use a passive crossover to filter out some of the bass to the rear speakers since they are smaller, this would help prevent over-driving them...as it is normally too much bass that distorts and blows a speaker. I'm not sure what you are asking about the hi-rear preouts vs the mid front pre-outs. If you decide to use the amp for the fronts you should be able to connect the amp from the front preouts of the deck. Hope this helps.
Posted on Mar 30, 2008
WHAT ARE THE SPEAKER COLOR CODES
2000 Cadillac Deville Car Stereo Wiring Diagram, SPEAKERS ARE HILITED
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Mar 29, 2011 | 2000 Cadillac DeVille
I need to know,when adding a ampliffier to the factory deck to a 2008,nissan altima.what wire do you connect the remote wire from the amp to?
Here is the diagram but make sure because this car has an amp. installed. To check the right wire you have to use a volt meter and check if you have 12 volts. at this wires (Blk/Pnk or Blk/Grn) as soon you turn the stereo On
2008 Nissan Altima Car Audio Wiring Diagram
Battery Constant 12v+ Wire: Yellow/Red
Accessory Switched 12v+ Wire: Violet/Yellow
Ground Wire: Chassis
Illumination Wire: Red/Blue
Dimmer Wire: Red/Yellow
Antenna Trigger Wire: Black
**Amp Trigger Wire: Black/Pink or Black/Green**
Amplifier Location: Under the Rear Deck
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Fron Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): Green/White
Right Front Speaker Negative Wire (-): Brown
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Orange/Black
Left Rear Speaker Negative Wire (-): White/Red
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Black/White
Jan 11, 2010 | Car Audio & Video
I need to know the color codes for the radio rear sub.
2000 Ford Expedition Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Purple
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Blue/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Audio Front Speakers Size: 6′ x 8′
Left Front Speaker Positive Wire (+): White/Red
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: 6′ x 8′
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Light Blue/Black
Right Rear Speaker Positive Wire (+): Purple/White
Dec 24, 2009 | 2000 Ford Expedition
I need the wiring diagram for a 96 Geo Tracker
1996 Geo Tracker Car Radio Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: White/Black
Car Radio Illumination Wire: Red/Yellow
Car Stereo Dimmer Wire: Red/Green
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): White/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Light Green/Black
Right Rear Speaker Positive Wire (+): Gray
Right Rear Speaker Negative Wire (-): Gray/Black
Nov 22, 2009 | 1996 Geo Tracker 2 Door
Color codes wiring for delco bose radio replacement n a1992 installing a aftermarket brand thx.
1992 Cadillac Eldorado Car Radio Wiring Schematic
Car Stereo Antenna Trigger Wire: Pink
Car Audio Front Speakers Size: 5 1/4′
Car Audio Rear Speakers Size: 6′ x 9′
Oct 07, 2009 | 1992 Cadillac Eldorado
Need to know the wires to install a deck for 97
Red is power to from ignition to cd deck
Yellow is direct power from battery to cd deck to hold the memory.
Black is ground
Blue is only needed if you are hooking up an amplifier.
I always suggest buying a wire harness quick connect system for $5, then you won't have to cut origional car wiring. If by chance you are taking the original wire route, then go to installer.com to find which wires on the car are for what.
Sep 02, 2009 | 1995 Toyota Celica
Installing my deh 2300
Heres all the radio wiring colors for your car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
window.google_render_ad();
Jun 02, 2009 | Pioneer DEH-2300 CD Player
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
Pioneer DEH-P3000IB... Hook up RCA cables to 2, 2 channel amps for front and rear control. Supposed to be able to set rear to either rear full or sub... can't find how and all I'm getting is sub response.
Here are the directions according to the manual:
1 Use MULTI-CONTROL to select
SW CONTROL.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
REAR SP (rear speaker setting)—PREOUT
(RCA output setting)
4 Use MULTI-CONTROL to select the desired
setting.
Turn to change the setting.
When REAR SP (rear speaker setting) is selected.
REAR SP:SUB W(subwoofer)—REAR SP:FULL
(full-range speaker)
When PREOUT (RCA output setting) is selected.
PREOUT:SUB W (subwoofer)—PREOUT:REAR
# When no subwoofer is connected to the rear
output, select REAR SP:FULL.
Hope this helps.
Oct 13, 2008 | Pioneer Audio Players & Recorders
Need to know the right setting to apply for my subs
You need to match your amp's input voltage (the gain) to the output voltage supplied via your deck's preouts. Turn you radio up to normal listening level, and turn the amp's gain until you induce audible distortion then back it off slightly. Set the bass boost and crossovers to on and type (highpass for front/rear full range or lowpass for subs).
Apr 26, 2008 | Jl Audio 12W3 Car Subwoofer
 Grubhead
Grubhead
