Question about Denon DVD-2800 MK II DVD Player
My Denon DVD-2800 mkii will not play dvds. Cds play fine but player acts like it can't read the dvd? Any ideas?
5 Suggested Answers
  • 3 Answers
SOURCE: Player does not recognize or play CDs
Thats how some manufacturers sell there replacement parts as they come into the country assembled. it cost let to import but more for us. i once needed a spindle motor for a unit, no replacement except the manufacturer part. Had to buy entire laser assy and thats what they bare selling you too. If you already tryed to manualy clean the lens, look on the side of the laser pick-up. it might be made by sony or a popular manufacturer go by the number printed on the label on the side or bottom of the laser assy unit itself. Good Luck
Posted on Aug 17, 2006
  • 3 Answers
SOURCE: Dvd doesnt play but cds do
Hi
The problem might be due to hardened greasing. Did You replace the drive or only the laser? The mechanism is named VED-0378, which is also the name of the laser. It is a Panasonic/matsushita thing. Try to google the name and find a dealer near your area, if you can't find it this polish electronic pusher is able to deliver both laser or mechanism: www.impelshop.com
Best regards and good luck! The Denon thing is worth a try.
Niels Peter from Denmark
Posted on Jun 15, 2008
SOURCE: Denon 3910 won't load some dvds/cds and vibrates while trying.."disc error"!
I have the Denon 2900 (about 4 years of use) and until recently, suffered from the same (growing) problem. CD's were very difficult to start/read. I recently found advice which I tried and was succesful with. It was manually cleaning the laserlens. I took away the outer housing by unscrewing all off the on top (6), side (4) and the back (2) bolts. After that I took out the top plate of the laserunit which took two very little screws taking out. Now you are looking at the cd-tray with the lens. Take a very soft and clean cloth and moisten it a little bit with clean water (be very carefull with the moistening, don't allow any waterdrop to come out of the cloth into the laserlens while cleaning! Carefully clean the lens and dry it with a dry part of the same cloth. Replace the top plate and the outer housing and the player will recognize the discs like it's new again. Good luck! Robert Jan, The Hague the Netherlands
Posted on Jun 25, 2008
AJIN G
  • 6694 Answers
SOURCE: My Denon DVD 955 frequently fails to play audio
hi,
in dvd player this problem can occur when there is a problem with the spindle motor. it will not rotate at the required RPM for cds. just check the spindle motor. if available replace it and try again.
ok
Posted on Jan 04, 2011
My Denon DVD 955 frequently fails to play audio CDs, but never any problem with DVDs. Ist there a fix you can suggest, please? **** P
hi,
ok
Jan 04, 2011 | Denon DVD-955 DVD Player
Does not read Cds or DVDs
most sony CD and DVD players have a digital signature design to play CDs and DVDs that are original and licensed. some CDs or DVDs dont work since the player does not recognize or scan any digital signature embedded in the CD or a DVD. 2nd, lens problem causes most players not to read CDs nor DVDs. you can try to buy CD or DVD lens cleaners to have your lens cleaned.
Nov 01, 2010 | Sony Computers & Internet
After I reinstalled my pc, the toshiba dvd-rom (sd-c2502) only plays cds, not dvds.
Try re-installing your the driver for your dvd rom. Then try to put different dvds and check if it can read from your drive. If problem remains, I suspected it's your dvd rom is faulty
Jun 02, 2009 | Dell Computers & Internet
The unit will not play dvds but does play cds
shut it down and restart it. It has to do with the settings. Did You configure it when You first hooked it up?
May 24, 2009 | Philips DVD795SA Multi-disc DVD Player
Won't play dvds but will play cds
The following is a direct link to my tips and tricks.
Mar 09, 2009 | Samsung DVD-R155
Plays cds but not dvds
If the lens is clean (clean with cotton swab and alcohol), then the optics are failing. DVDs require more power and accuracy to be read than CDs. The ability to read CDs but not DVDs is usually a good indication that the optics are starting to fail.
Dan
Feb 18, 2009 | Televison & Video
My burned media from my new DVD Burner ASUS DRW-2014L1T isn't able to be read by my DVD Player
no data dvds work on the players.
use NERO 6 OEM to write Video DVDs or CDs they will run Players
Jan 07, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
Plays music cds but wont play DVDS
Hi ,
You should do...
1- clean to lens
2-change with new lens
3- change the spindle motor
I hope to fine it.
Dec 30, 2007 | Zenith DVP615 Portable DVD Player
Portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
Apr 01, 2007 | Audiovox D1812 Portable DVD Player
Plays cds but wont read dvds
upgrade the firmware on the product.
Nov 10, 2006 | Sanyo DRW-1000 DVD Recorder/VCR
Denon DVD-2800 MK II DVD Player Logo
95 people viewed this question
Top Denon Televison & Video Experts
Jonathon summesfield
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
