Question about Maytag Neptune MDG5500AW Gas Dryer
How do I check to see if the ignitor glow red?
How do I get access to view the ignitor and can I run the dryer with any of the panels off.
  • 725 Answers
You can remove the front replace the door and check the ingitor .. let me know and I can guide you step by step
krazytech
Posted on Apr 05, 2008
I have a gas dryer and cloths come out wet
Does the dryer get hot? If so check dryer vent.
If it is cold check the gas supply. Next open the lower cover and look to see a red glowing from the ignitor when running. It it comes on and no flame then you probably have a bad gas solenoid. If there is no red glow then it is probably the ignitor.
Hope that helps
Dale
Nov 10, 2013 | KitchenAid Clothes Dryer Gas Dryer Ignitor...
Dryer wont stay hot
Assuming you have removed the lower access panel (two or three scres all the way at the bottom of the lower front panel) to view the glow plug (ignitor), if you see the ignitor cycle on but the gas does not ignite after the machine initially heated in the beginning of the cycle you will want to replace your gas valve coils. They are the round black things mounted to the top of your gas valve.
This should solve your problem.
Good luck to you!!
Jul 13, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Fridgidare dryer model GLGQ2152ES3 runs but does not heat how do I get inside front or back to check the ignitor. It doesnt light (i think)
ok, you can remove the small screws below the kick panel below the door on the front. that will gain you viewing space to watch and see if the ignitor is even glowing, if it is then you most likely need gas valve coils, or to turn on the gas.
if the ignitor is not glowing at all you will need to do some testing on the safetys and thermostats within the dryer. they are all closed at rest so you should have continuity through them. there is the operating stat on the air duct blower housing in the front of the dryer. there is also a hi limit that is on the rear housing of the unit that you will need to remove the top of the dryer to view and gain access to..
those dryers have been a pain and the rear hi limit is especially susceptible to poor venting practices so very common today, and the higher operating temps caused by the poor venting..
best of luck..
May 20, 2010 | Dryers
My Maytag model no. MDG6200AWW will not ignite. Gas is on; electricity is OK; dryer acts like it's on "air dry" when it is on "regular" setting. Can I repair on my own?
It sounds like you could have a ignitor issue. Usually there is a small plastic plug located at the bottom right of your dryer in which you can view the ignitor in action. if there isnt a plug you will have to first take off the door by removing the hinges. after the door is off there are two screw at the bottom of the front access panel remove them and your panel should lift out from the bottom. once this panel is off you should again be able to see the ignitor in action. turn your dryer on a normal heat setting and wait for the ignitor to come on, if it glows RED hot the ignitor is NOT good. if it is burning WHITE hot you do not need to replace this, ignitor part number is 304970. hope this helps
Thanks
Oct 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
This is the closest model # I could find but I have a gas dryer model TGDX640EQO and it doesn't heat up but does tumble. My husband thinks it is the ignitor, how would you determine that?
First clean all the dust and lint from around the burner and its components, including the sensor which 'tells' the dryer that the ignitor is on or the burner is lit.
There are two different types of ignitors. The most common glows a bright red to light the burner. The other gives off a series of sparks.
In either case, a visual examination should tell you whether the ignitor is working. Before you start the dryer, remove the burner access panel. Have someone start the dryer while you look into the burner unit to see if you see the 'glow plug' or the 'sparker' trying to light the burner. If not, the ignitor is probably bad.
If the ignitor is not the problem, look for dirty or defective sensors that will keep the burner from coming on. If these sensors do not sense the light given off by the ignitor, for safety reasons the burner will not come on.
Hope this was helpful.
Oct 10, 2009 | Estate TGDX640JQ Gas Dryer
Whirlpool lg9521xt gas dryer- no heat or flame. I replaced thermal fuse and coil kit, but didn't solve problem. What's next ? The igniter ?
Remove the bottom panel and start dryer . If you see the red glow , then ignitor is ok . Disconnect the plug (2 or 3 wires ) going to the burner and check for 120 volts . If no red glow , replace the ignitor pt # 279311 . If not 120 volts , then , normally , thermal fuse is bad (white piece with 2 small terminals on blower box ) is bad .
Sep 07, 2009 | Whirlpool Dryers
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
We don't have any flame.....it turns and blows but no fire I have a Kenmore Model 11070902990 Ser. # MK 0612958
This is the flame sensor that you probably need.
Aug 03, 2009 | Dryers
Kenmore 80 series Heating Problem
Most of these issues will need an ohm meter, unless you want to just take a guess.
For Gas dryers.
1. See if the ignitor glows, if not, check the thermal fuse. (if the lint screen is on top, the fuse is accessed behind the back panel, it's small and white, next to the bulkier thermostat. If the lint screen is in the front panel, the thermal fuse is mounted on top of the blower wheel housing, accessed behind the bottom-front or "kick" panel. The fuse should read 0 to .2 ohms at the most, technically is should be zero. If that checks ok, check the ignitor itself, which has a wire harness that connects about 6" from the ignitor. Should be around 50 ohms... a faulty ignitor would read infinite ohms (open).
2. If the ignitor does glow, and you hear a click, but there is no flame, replace the valve coils, (two small cylindrical objects mounted on the valve) Part # 279834. This is assuming your gas is ON.
If Electric, it would not be the fuse, as on electric dryers it is also in the motor circuit, and the dryer would not run at all. Check the heating element, should be around 9-11 ohms. If good, check all thermostats (operating, hi-limit, thermal cutoff). Infinite ohms is bad. Hopefully it's not more complicated than this, or it can get weird..... Hope this helps.
Sep 15, 2008 | Dryers
Kenmore elite gas dry 6 years old - no heat
PUT YOUR DRYER ON AIR FLUFF AND TURN IT ON. THEN SELECT A HEAT SETTING. IF YOU HEAR A DISTINCTIVE CLICK WHEN YOU SELECT HEAT, THEN CHECK FOR A GLOWING IGNITOR. MOST KENMORE/WHIRLPOOL DRYERS HAVE A PEEP HOLE IN THE FRONT LEFT SIDE OF THE DRYER. REMOVE A PLASTIC COVER TO VIEW INSIDE.
IF THE IGNITOR GLOWS, AND THEN CLICKS OFF, YOU HAVE A BAD SOLENOID (COIL SETTING ON TOP OF THE VALVE). IF IT NEVER CLICKS OFF, YOU HAVE A BAD RADIANT SENSOR( LOCATED ON THE SIDE OF THE BURNER HOUSING). IF NO IGNITOR GLOWING, THE IGNITOR IS BAD.
IF WHEN YOU SELECT HEAT, THERE ISN'T ANY CLICK, THEN THE THERMAL FUSE LOCATED BEHIND THE BACK PANEL DOWN NEAR THE EXHAUST IS BAD. IT IS A SMALL WHITE ITEM WITH TWO THIN WIRES ATTACHED TO IT.
Apr 07, 2008 | Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
82 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
