Back to:
Tags:
Gateway FPD2275W  LCD Monitor
Hp lcd monitor
posted by xpsguy on Mar 30, 2008
Could you tell me where the capacitors that you replaced are located and what voltage they are?
Thank you,
Thinh
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 31, 2008
Not Rated (0)
ndhelp2008
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
The capacitors that I replaced were near the large heat sink on the power board. They were radial capacitors. Looking at them I noticed that the metal end of the capacitor was dome shaped and not flat. I figured what do I have to loose and replaced them. The voltage and size of the capacitor is usually identified on the side.
Hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on hp lcd monitor:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Gateway FPD2275W (Black) LCD Monitor
As the subject line desribes, my monitor does not work....
needs new hardrive and possible memory
gateway lcd monitor fpd1530. unit shuts off in one second...
Why does the window slowly roll down to close as opposed...
my computer screen just goes black whenever im playing a...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
