Question about Canon imageRUNNER C6800 Copier
How to know IP adress for Canon ir c6800 - Canon imageRUNNER C6800 Copier
  • 23 Answers
Network settings are in the additional functions> system settting > network settings. If your printing to the copier the ip address should be there in the network settings.
Posted on May 17, 2010
Canon IR 2520 lost IP address
This is regular feature. Nothing defective here.
IP address is to communicate with the router on wire or wireless.
Dynamic IP address will assigned to your printer again when re-connected and will be lost when disconnected.
Static IP address assigned will be reserved at the router for the device even when the device is disconnected.
Apr 18, 2016 | Canon Office Equipment & Supplies
Ip address
Click the Menu button on the printer and scroll to the Network settings to the IP address. You may need to change the IP address to suit your network.
Feb 26, 2013 | Canon MultiPASS MP360 All-In-One InkJet...
IR 22 30:HOW TO PUT IP ADRESS? i whant to
the easiest way is to print out a function list on the copier it should give the ip address on the list then open internet browser and input the ip address in the browser nd change the ip address there dont forget to make the ip address static hope you come right
Feb 19, 2011 | Canon IMAGERUNNER 2230 Copier
HOW DO YOU NETWORK A canon imagerunner 1023
do You want to connect the machine on network or .... ?
First check if you on back side of copier have the network connector.
If yes, you need to connect the normal network cable if you have network switch or cross cable if you are connect directly on PC.
Then you must enter the IP adress in machine, under user mode (*) under system settings, under IP adress.Also enter subnet and gateway adress.
Free IP adress you can check on your pc under CMD and type ipconfig, to see your ip, subnet, and gateway.Then type : ping XXX.XXX.XXX.YYY The YYY marks number that you can change and must not be same as yours PC.After typing ping .......... and you have answer DATA LOST that means the ip is awailable and you can type it in copier.
Install drivers and select tcp/ip port.
If these isnt solution that you asked for, you can also contact me on emma.servis@gmail.com with more detailed description.
Hope that helps!
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
Connect device to laptop
you need to be able to configure your lap printing drivers to print to the ip adress of the copier.... does the copier have a rip or is it stand alone
Apr 19, 2010 | Canon imageRUNNER C3200 Copier
On the control Panel
Press Additional Functions Key.
Press Report Settings
Print List should be 2 rows of choices/ Select Network and print list. TCP/IP will be on the print out.
To Change the IP Address
Press System Settings
Press Network Settings
Select TCP/IP Settings
Enter New Address or turn DHCP on
Back out by using reset key on control Panel.
Be sure to re-Power the copier by turning off/on at the main power switch on the right side of machine or any setting will not take.
Mar 22, 2010 | Canon imageRUNNER C6800 Copier
Canon Imagerunner C6800/5800 scanner message ''Network processing is timed out. Check the scanner and network status.'' Was working perfectly with the Scan2PDF program but now scanning gets hung up and...
Probably because the scan2PDF is using twain drivers. The reason why you get an error message is because the ip settings that it needs in the device settings to scan via network is not configured correctly. That is why it times out because it cannot communicate without the ip adress
Oct 15, 2009 | Office Equipment & Supplies
Input IP address on IR C3220 with ImagePass-C2
go to printer tab then function then print pages then configuration page. and you'll see the ip address
Feb 11, 2009 | Canon imageRUNNER C3220 Printer
Can't connect Canon Pixma MX310 to wireless network!
This printer does not have a network interface. There is no ip address for this printer. You must connect via usb.
Jan 21, 2009 | Canon PIXMA MX310 All-In-One Printer
Ir 3300
i have an IR 3300 (used) i have given TCP/IP correct with machine and PC also. ping command is working properly and IR Machine also response from the host and also i'm success output (Printout) but can't scanning. I have scangear also tried but the messeage appear "the spacified IP address is invalid or scanner is not connected to the specified IP" but my IP address is correct. (both side) i know that after this my Machine will be online from System button but there is no software. i cant solve my problem
how can i connect my Machine from PC
Dec 18, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER C6800 Copier Logo
325 people viewed this question
old marine
old marine
