Question about Pioneer AVIC-Z110BT GPS Receiver
I can only get my cell phone to connect to my stereo as an audio device. It won't let me change the setting to handsfree. I can makeeceive calls but I can't hear anything and they can't hear me. How do I fix it?
I can only get my cell phone to connect to my stereo as an audio device. It won't let me change the setting to handsfree. I can makeeceive calls but I can't hear anything and they can't hear me. How do I fix it? It sometimes works, but it then goes back to the initial issue.
Posted on Jan 23, 2011
My Jaba wave and iphone 4s is connected but the calls do not come across my headset, but rather my phone only.
The question is how have you connected means that connected through bluetooth as audio device or handsfree? the right one is the handsfree if it still doesnt work then you should contact the device manufacturer.
Jun 20, 2014 | Jabra Wave
I am able to hear phone calls not the music ? why if is is possible how?
You have not mentioned the make & model of your mobile phone. You must set your bt device as default device and set it as headset device instead of handsfree device. You may also check the options in your audio player for bluetooth settings as bluthtooth headset/stereo headset
Jul 18, 2011 | Jabra BT2050 Bluetooth Headset
When i connect handsfree to phone i can listen to music but i cant connect to calls
If you cannot answer calls probably the answer to this problem that either your BlueTooth handsfree headset device is either malfuctioning or that when you registered the handsfree device you did not search for the service profiles and lock those in or either the handsfree headset device does not have an microphone.
Jun 27, 2011 | Cell Phones
How can i connect Nokia BH-106 to samsung omnia i900.
Hello there...
From what i've read in here:
http://europe.nokia.com/find-products/accessories/all-accessories/headsets/bluetooth-headsets/nokia-bluetooth-headset-bh-106/specifications
The BH-106 specification doesn't mention that it support A2DP. To enable you to hear songs from bluetooth headset you need the one which support A2DP feature.
Quote:
Advanced Audio Distribution Profile (A2DP) This profile defines how high quality audio (stereo or mono) can be streamed from one device to another over a Bluetooth connection.[1] For example, music can be streamed from a mobile phone to a wireless headset or car audio or from a laptop/desktop to a wireless headset.
Source:http://en.wikipedia.org/wiki/Bluetooth_profile#Advanced_Audio_Distribution_Profile_.28A2DP.29
And as for listening radio from bluetooth headset/handsfree, I think that it is not possible... since usually radio feature in a handphone need a wire type handsfree as it also function as the radio antenna.
Hope this helps.... :D
Apr 07, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
Unable to establish a connections with home stero and car
This is how this device works: regarding its bluetooth part, this device is able to handle handsfree (HFP) and headset (HSP) profiles, which are meant to be used by previously paired bluetooth enabled phones, for phone calls purposes only, and Advanced Audio/Video Distribution (A2DP) and AudioVideo Remote Control (AVRCP) profiles, which are designed for stereo music, coming from previously paired compatible bluetooth sources, to be received and controlled (play/pause/prev/next). The only purely transmitter part of this device is its FM funcion, i.e. it receives A2DP streams from a bluetooth enabled device (e.g. computer, smartphone) and converts them to a predefined FM station, so that your car (or home stereo) can tune up and sound on their speakers.
Summarizing: the T505 bluetooth car kit receives phone calls and stereo music from bluetooth enabled sources and either sends them to its own loudspeaker, or converts them to a predefined FM station, to be tuned by another device.
If you happen to need its user guide, you can download it from here.
Please, let me know if I can help you any further.
Regards, Carlos
Mar 20, 2010 | Motorola Mobility MOTOROKR T505
Headphone symbol though no headphones in so cant talk to people
It sounds like your device may be paired with a Bluetooth headset. Try turning off bluetooth connectivity and see if that fixes the issue.
Oct 25, 2009 | HTC Hero Smartphone
How do I connect my motorola bluetooh headset S9 to my LG Vu920?
When using your S9 for the first time, follow these
steps to pair (connect) to your Phone:
Important: If you are pairing separate Bluetooth
devices for handsfree calls and streaming music, it is
recommended that you pair your S9 with your
handsfree device (phone) first.
1 Ensure the Bluetooth feature is enabled (turned
on) in your phone.
2 Turn on your S9 by pressing and holding (|) button
until the indicator light flashes three times in
blue.
After a few moments, the indicator light will be
steadily lit in blue to indicate your S9 is in pairing
mode.
3 From your device, perform a Bluetooth device
discovery/search. .
When pairing your S9, use
the following steps to perform a device discovery
from your phone:
After accessing the Settings Menu, go to bluetooth.
to add a new device, tap [New].
1. Tap [New] key to search the device that can be connected and which is
within range.
The phone lists Bluetooth devices it
finds.
b Select Motorola S9.
c Select OK or Yes to pair your S9 with
your phone.
d Enter the passkey: 0000
e Select OK.
When your S9 successfully pairs and connects to
your device, the indicator light displays blue with
10 quick purple flashes. If wearing your S9, you
will also hear an audio tone indicating successful
pairing and connection to your device.
4 To verify your S9 has successfully established a
handsfree calling connection with your phone,
dial a phone number you want to call and press
the Send key on your phone.
When successfully connected, you hear ringing
on your S9. A Bluetooth Handsfree Phone (HFP)
connection is now established with your phone
Jul 13, 2009 | LG Vu CU920 Cellular Phone
How do I connect my Sony Bluetooth headset DR BT21G to my Vaio
I solved this problem by turning off my phone which had bluetooth active while i was trying to get audio through. thats why the bluetooth never connected to my headset as the phone was using up the bandwith.
make sure your headset is the only bluetooth device and then go into your bluetooth properties -> audio -> select your headset and press connect
now go into your sound options and it should be listed there if it connected succesfully. set if as default and remember to restart the music programm youre running
enjoy!!! =D
Dec 19, 2008 | Computers & Internet
Ear piece
Hi Snuggle ,
It depends on kind of cellphone you have. Normally there should be an option of Handsfree in the phone settings. choose bluetooth device it should detect the handsfree from there . connect to your earpiece from the list of devices.
for Example : I have Sony Ericsson W700i
I have that option under Main menu -- > Settings --> Calls --> Handsfree
Hope this is Helpful
Mar 19, 2008 | Jabra BT350 Bluetooth Headset Headset
Pair Bluetooth Stereo
put the music player on and press down on the jogwheel, select 'Play Via' and change it to Bluetooth stereo headset. It'll prompt you to open the swivel and take you to the bluetooth devices screen where you select the correct device, it'll then prompt you to close the swivel and will start playing through your headphones :-) Is that what you mean?... It's a bit of a pain really :-(
Aug 04, 2007 | Samsung SGH-X830 Cellular Phone
Pioneer AVIC-Z110BT GPS Receiver Logo
143 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
