Question about Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC
CANNOT INITIALIZE API - REINSTALL THE SOFTWARE
I´m user of Roxio Products since it was named ADAPTEC (around 1998) and I have all the original versions of Easy CD Creator, Easy CD and DVD Creator and also Easy Media Creator 7.0 installed in a XP based machine. This matter concerns to EZCD 6.0 which is installed in a Pentium III 750 machine running W98 Second Edition and 1GB of RAM. No troubles until two days ago when the subject message first appears. No changes have been made in the machine, no new softwares installed, no viruses or trojans, very clean register, WMPlayer 9.0 installed for a long time, just a few programs running because this machine is used only and solely for NLE jobs (Creation of Home Videos). Tried to update version 6.XXX to the version suggested by Roxio but problem still exists (only when attempt to run Creator Classic). I have reinstalled software (original) but problem continues. Have removed the software and installed the old version (EZCD Creator 5.0) but problem also continues too. I have burned one DVD last week as I do always with no problems. Could you suggest anything please? I have many cd´s and dvd´s to burn, because is time to update my backups but cannot initialize the engine. Thank you for any suggestion!
  • Herminio Trujillo
    Herminio Trujillo Apr 02, 2008
    Dear friend,
    I have attempted to fix the problem with EZCD 6.0 for many days and decided to migrate to Windows XP Professional Edition. My PC consist of a PIII 750MHz, 1GB SDRAM 133, MB Asus P3V4X, Miro DC-30Pro Capture Card, one HD for the OS and softwares, one HD for data and one 10.000 rpm SCSI HD controlled by Adaptec 19160 for the capture of video. I use Première 5.1c for edditing, Holywood FX for effects, Title Deko for titles and TMPG 2.5 for encoding thru Avisynth Frame Server. Also have original CD of Roxio Media Creator 7.0 for XP and updates. Do you recomend this migration in order to solve the problem? I found out that DC-30Pro works very well in XP, except that will not be possible to export to video thru DC30. In the other hand, i will not face the limitation of 2GB files. Nowadays I no longer export to video, due to the encoding to MPEG2 and DVD burning. Based on your own experience with hardwares, do you think that my hardware will work well on XP? Thanks again!
    Novelist:
  • 141 Answers
When you installed the 5.0 in, did you put the update in also?
ecdc_v53.5.10 basic_enu
You will need this or 5.0 will not run.
Posted on Mar 30, 2008
Cannot initialize the API please re install? I
Check your version of OS supported or not. MIght be the .msi installer issue.
Oct 30, 2013 | Sonic Roxio Easy DVD Copy for PC (310107)
Tip
Microsoft Visual C++ Runtime Library error when starting Roxio creator
Hi.
I have had several questions from users getting Microsoft Visual C++ Runtime Library errors when starting Roxio Creator 2010 and previous versions.
After the error prompt, the software will close down.
The problem is caused by a system error , and this sometimes is causedby Microsoft self installing update, that confuse settings of installedsoftware.
Microsoft Visual C++ Runtime Libraries are part of the operativesystem, and this kind of Run time errors are commonly caused whenapplications try to access resources that are allocated for otherprocesses.
A new Roxio installation did not fix the problem, because the newinstallation will still keep the registry settings from oldinstallation.
If the problem started recently you can try the following:
Uninstall Roxio.
Do a System Restore to a date before the problem started.
Reinstall Roxio.
See: How to install System restore.
If that does not fix the problem you can also try the following;
Uninstall Roxio
Create a new user with administrator privileges
Log in using the New User account
Install Roxio again.
If the problem was bound to local user settings, this will fix the problem.
If the problem is still there, then the most efficient way to proceedis by doing a new Windows installation, using a Windows setup disk or arecovery disk for your computer.
Do a full backup of your data before reinstalling Windows.
See:Install, reinstall, or uninstall Windows
The solution does not apply only to Roxio, but can fix the same problem on different software.
Regards.
on Feb 26, 2010 | Computers & Internet
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
Is it a good idea to install the MSI driver?
This is online upgrade service..MSI products. Use the time saving service to update your product with safe and ease.this is good for system upgradation.
Mainboards: Drivers/BIOS versions/Utilities; Graphics Cards: Drivers/BIOS versions/Utilities; Barebone: Drivers.
Please rate me.......
Thanks,
Mar 26, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Initialize API : Failure in initialization This think is in an mobile application when i use the Symbol.WPAN.dll
Roxio has posted a knowledge base article on this issue.
http://kb.roxio.com/search.aspx?URL=/content/EE7000028&PARAMS=set-locale=en
Sep 15, 2009 | Roxio Easy CD & DVD Creator 6...
Can't install Roxio Creator 2009
There is a patch from Roxio to resolve this error!
http://kb.roxio.com/content//kb/Creator/000217CR
Deadog4201
Feb 05, 2009 | Roxio Easy Media Creator 10 Suite
Roxio10 Deluxe Suite, Vista OS - When editing an audio CD label (back of jewel case), all text disappears from project window. All text is still there if you go back to Edit Text but still gone from...
Since Roxio will not aknowledge this issue, I am using Publisher to create my CD jewel cases. I am also using other software programs as work arounds for other Roxio issues that I have. Roxio has really gone down hill since version 7! After being a Roxio user for many years (and several versions), I will no longer encourage others to buy this product.
Aug 11, 2008 | Audio Players & Recorders
Roxio cd upgrade
Sir,
The roxio software is difficult to use. That software have use only original buyer will get upgrade.ok. So that software is fully copy protected so only authorised buyer can use of it without any problem. U just reinstall the OS. This would make better. ok
Thanks
Good luck
Don't forget to rate the solution.
Jun 29, 2008 | Roxio Computers & Internet
Dead Driver for Easy CD Creator
Resolution WARNING: THIS PROCEDURE MIGHT CAUSE ANY OTHER ROXIO OR ADAPTEC SOFTWARE INSTALLED ON THE PC TO BECOME INOPERABLE. PLEASE UNINSTALL ANY OTHER ROXIO OR ADAPTEC SOFTWARE FIRST BEFORE ATTEMPTING THE LISTED PROCEDURE.
  1. Renaming the Take Two system file
    • Click on the Start button, and then select Search
    • Search your Local Hard Disks for the following file prtseqrd.sys
    • If you do not find this file, please go to step 2
    • If found, right click on the file and then click on rename. Change the file extension to ROX (i.e. prtseqrd.sys would be renamed to prtseqrd.rox)
      NOTE: If you decided to not finish this article at any point please rename this file back, you will be doing that later in this article. right hand corner of the window
  2. Remove Easy CD Creator 5 from Add/Remove Programs
    • Click on the Start button, then go to Setting and select the Control Panel
    • Double click on the Add/Remove Programs icon
    • Uninstall Adaptec Easy CD Creator 5, if prompted choose No to reboot the PC
    • Then click the X in the top right hand corner of the Window to close the control panel
  3. Removing Directories from your Hard Drive
    NOTE: All directories stated might not be found
    • Click on the Start button, then right click on the My Computer icon and then select Open
    • Double click on the icon for the Local Disk that the software was installed to
    • Double click on the Program Files folder
    • Locate the Roxio and Adaptec folders, right click on each folder and choose Delete
    • Go to C:\\Program Files\\Common Files folder, locate the Roxio Shared and Adaptec Shared folders, right click on each folder and choose Delete
    • Go to C:\\Program Files\\Common File\\InstallShield folder, locate the Engine and Iscript folders and rename them to Engine.ROX and Iscript.ROX. Once all the directories are remove right click on the "X" in the top right hand corner of the window to close it
  4. Rename additional files on your hard drive
    NOTE: All files in the list might not be found
    • Search your Local Hard Disks for the following files:
      *CDR4_2k.sys
      *CDR4_XP.sys
      *Cdr4dll.dll
      *Cdr4vsd.sys
      *Cdr4vsd.vxd
      *Cdral.dll
      *CDRALw2k.sys
      *Cdrtc.dll
    • If found, right click on the file and then click on rename. Change the file extension to ROX (i.e. cdrtc.dll would be renamed to cdrtc.rox)
    • After all files are searched for and renamed close the search window by clicking on the "X" in the top right hand corner of the window
    WARNING: THE NEXT STEPS INVOLVES EDITING YOUR SYSTEM REGISTRY. WE STRONGLY RECOMMEND YOU EXPORT YOUR REGISTRY BEFORE SYSTEM DAMAGE. WE RECOMMEND THAT IF YOU DO NOT FEEL COMFORTABLE EDITING YOUR REGISTRY THAT YOU SKIP THESE STEPS.
  5. To export a copy of your registry, please do the following:
    • Click on the Start button, then select Run
    • Type regedit and click the OK button
    • Locate and left click FILE in the upper left hand corner of the Registry Editor, then click on Export
    • Choose the Desktop as the location to save the file in, and name the file regbackup
    • Also ensure that under the Export Range section there is a dot beside All
    • Click on the Save button. Your registry should now be backed up to a file named regbackup.reg on your desktop.
  6. Remove the Roxio and Adaptec registry entries
    • Expand the HKEY_LOCAL_MACHINE key (looks like a folder) by double clicking it (or clicking the + next to it.)
    • Expand the SOFTWARE Key
    • Locate the Roxio and Adaptec folders, right click each folder and click on Delete
    • If prompted to confirm the delete click the Yes button
    • Collapse the keys that you expanded by double clicking the expanded key (or clicking the "-" next to them.)
    • Expand the HKEY_CURRENT_USER key
    • Expand the SOFTWARE key
    • Locate the Roxio and Adaptec folders, right click on each folder and click on Delete
  7. Remove the UpperFilters and LowerFilters values:
    • Expand the HKEY_LOCAL_MACHINE key (looks like a folder) by double clicking it (or clicking the "+" next to it.)
    • Expand the SYSTEM Key
    • Expand the CurrentControlSet Key
    • Expand the Control Key
    • Expand the Class Key
    • Please look for a key containing the following string of letter and numbers: {4D36E965-E325-11CE-BFC1-08002BE10318}
    • High light this key by left clicking once on it
    • On the right hand side you are looking for UpperFilters and LowerFilters under the Name column, once you find these please delete them by right clicking on them and choosing delete
      Note: It will be easier to use the Registry editor in the future if you collapse the keys that you expanded by double clicking the expanded key (or clicking the "-" next to them.)
    • Please exit the registry by clicking on the "X"in the top right hand corner of the screen
  8. Renaming the Take Two system file
    • Search your Local Hard Disks for the following file prtseqrd.rox
    • If found, right click on the file and then click on rename. Change the file extension to SYS (i.e. prtseqrd.rox would be renamed to prtseqrd.sys)
  9. Shut down and Reboot the PC
    • Click on the Start button, then click on Shut Down
    • Choose the Restart option and click the OK button
    • Adaptec Easy CD Creator 5 should now be removed from your PC
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Mar 28, 2008 | Computers & Internet
Cannot Initialize API
1. Try to launch Creator Classic to see if it can repair the engine files. a. Double click on the "Roxio Easy Media Creator Home" icon. b. Click "Creator Classic" under the "Applications" section. c. The Windows installer should launch and ask you to insert your installation disc
Try this and see how it works, if it does not, contact me and give me more details
Mar 25, 2008 | Roxio Easy CD & DVD Creator 6...
Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC Logo
1,562 people viewed this question
Top Roxio Computers & Internet Experts
Tony
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
