Question about Mackie SWA1801 Subwoofer
How do you get to the AC fuse on the SWA1801 ?
There are 4 allen-head screws that hold the amplifier assembly in - two on top and two on bottom. Remove these and the entire thing slides out the back. There is one fuse near the power switch and two on the power supply board inside. Be sure to use the correct value.
Posted on May 29, 2010
04 navigator is blowing ac fuse 11, ac coil shorted, 3 different coils, can ac compress short the coils
How did you hook up the inline fuse to compressor and ground to compress ? Ground what ? Right at the clutch coil ? You have to be hooking it up wrong . The compressor can't cause the clutch coil to short or blow the fuse , even if the compressor were seized up . An before that would have the serpentine belt would burn up , squealing noise. applying B+ voltage in the relay socket ,pin 30 to pin 87 will engage the compressor clutch . If the fuse blows the wiring from the relay to the compressor clutch is shorted to ground . Look for rubbed through wiring harness .
Jul 14, 2017 | Ford Cars & Trucks
Where is fuse box. Ac not working
The fuse panel is typically located to the right of the fuses in the breaker box. The AC system may also have a fuse in the control box of the AC.
May 30, 2014 | Fleetwood 2012 Jamboree Sport DSL 24L
Fuse keeps blowing on a/c on 2001 dodge truck
Let's break this down.
1 Does the fuse blow when the heater is on, or just the AC?
Yes- Fan motor problem likely need new blower motor.
No- 2
2 Disconnect the AC compressor clutch wire. Remove the blown AC fuse, connect a multimeter across the sockets for the fuse, measure DC voltage across the two sockets with the AC switch, and Ignition switch ON. Is Battery voltage present?
Yes- The wiring harness has a short between the output of the AC switch and ground, likely a pinched harness.
No- The AC compressor clutch is shorted. Replace either the whole compressor or the clutch.
Apr 01, 2014 | Dodge Ram 1500 Cars & Trucks
Which fuse do I need to replace for my ac compressor?
The AC clutch is passenger compartment fuse # 5. This is the fuse for the circuit through the function selector switch to the AC pressure cut off switch & the AC pressure cycling switch.
The engine compartment fuse # 23 & 3 control the WOT ( wide Open Throttle ) relay to the AC clutch diode & AC compressor clutch solenoid.
Aug 22, 2010 | 1999 Ford F150 Regular Cab
Ac fuse
all the fuses are in the fuse box under the hood ,you may find another fuse box under the dash as well,but with the AC there are sensors under the dash on the unit that cut the AC in & out to keep it at the right temperature, AC problems sometimes have to left to qualified people to diagnose the problem.....hope this helps....cheers
Aug 02, 2010 | 1992 Honda Accord
AC does not engage when turned on
Take the glove box out. Behind the fuse box you will find a big gob of black tape, (it looks like a box shape all taped up. Take the tape off and you will find three inline fuse holders taped together. The AC fuse is the 10 amp one.
Sep 28, 2009 | 1996 Buick Century
2004 gmc sierra 5.3. AC not working AC Compressor fuse blowing
UNPLUG THE A/C CONNETOR ON THE A/C COMMPRESOR. REPLACE THE FUSE AND TURN ON THE SWITCH. FUSE OK . REPLACE THE COMMPRESSOR AND THE RECIVER DRIER.
Apr 17, 2009 | 2004 GMC Sierra
Mackie SWA1801 NO POWER, NOT TURNING ON
  1. I have blown capacitor in my mackie swa1801, Can you send me schematic g_man001@hotmail.com thanks Georgie.
Feb 24, 2008 | Mackie SWA1801 Subwoofer
Mackie SWA1801 Subwoofer Logo
327 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
