Question about Garden
Knocking sound from an '02 Briggs & Stratton engine.
I've got a 18 hp single cylinder b&s Intek moter in a troybilt riding mower. The engine has just started knocking ( loud heavy & rises & falls with the revs.)while running and throttle control is now wide open or off only. It was bought new in '02. Motor model# is 31H777 type 021-E1 & code# 0201282A. Thanks Billy
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
  • 468 Answers
SOURCE: Knocking sound from an '02 Briggs & Stratton engine.
Your engine is about to blow. That knocking sound is indicative of a connecting rod bearing out of tolerance. This condition never gets better; it'll finish out by breaking the endcap on the rod, and usually puts a hole in the block. Sometimes, it can be caused by a bolt coming loose from the endcap, and I've had success by taking it apart and tightening the bolt, fixing the problem for at least several years. This can only be done if there isn't any deformation from it knocking.
Posted on Mar 22, 2010
Testimonial: "Very good info. I suspected a rod getting ready to let go. I needed confirmation and this does it. Thanks for the quick response."
kel1guy2002
  • 3740 Answers
SOURCE: NEED A OPERATOR MANUAL
Go to www.brigsandstratton.com
http://www.briggsandstratton.com/maint_repair/manual_and_more/docsearch.aspx?enginelookfor=407777-0137-20
Select your manual. It is the first on on the list of 7 manuals.
Thanks for using FixYa.
Kelly
Posted on Mar 29, 2010
  • 88 Answers
SOURCE: briggs and stratton engine model
there are the basic things for an engine to start. air, fuel, and spark. if you are getting spark at the plug one down. try taking your air cleaner off and spray starting fluid into carb with choke open then close. if it starts and runs a litlle then dies then you have a fuel problem. take carb off and clean real good take bowl off and clean with carb cleaner. that should solve you problem if not let me know
Posted on Dec 24, 2010
  • 640 Answers
SOURCE: I need and exploded view
Get the model and type number off the engine and go to briggs website or you can go to another website such as partstree. On partstree.com scroll to bottom of page and select briggs. On the left side of the next page enter model number followed by a space and the type number. If it does not take the model and type number (happens sometimes) enter just the model number and hit enter, then scroll down the page until you get to the right type number. There will be a list of the illustrated parts drawings for the engine. These are exploded views.
Hope you find what you need.
If this was really helpful for you please rate four thumbs up.
Posted on Jul 19, 2011
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to know the weight of the motor oil
sae 30 in winter sae 40 in summer i preffer rotela
Aug 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Does a briggs 18 hp twin 2 have a oil filter its a late 90's model mtd riding mower
Most likely yes. It will look like a car oil filter. It looks like a round can that is screwed to the engine.
Mar 17, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a white mower with a 18 hp intek v-twin briggs & stratton motor. I was cutting the lawn and it loss power all of the sudden, then it died. Now it won't start. I changed the plugs, which looked...
back pressure is from a blocked muffler ( carbon build up)
if it is that old then it could be overheating from grass and dirt build up around the cylinder fins and not cooling properly
Apr 06, 2017 | Briggs & Stratton Briggs Stratton Intek V...
Mar 22, 2010 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Have to hold chocke out to keep it running
sounds like the needle and seat is dirty within the carb
Aug 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
Jun 18, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
144 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
