Hi, my AWM 1200 is 9yrs old but still washes and
Hi my awm 1200 is 9yrs old but still washes and spins perfectly except the noise on the spin cycle! Its so loud that you can hear it out in the garden! Any ideas what it could be? Thanks. x
  • 343 Answers
Your machine most probably has had water in the spin bearing. The seal has worn and allowed water to rust the ball bearings which are no longer smooth...Hence the noise! A fairly major job which could also need a new shaft and inner drum. Get quotes, but be prepaired. Too much detergent can also speed up seal failure......Good luck....Nomess
Posted on May 16, 2010
Whirlpool AWM 312 front loading washing machine motor does not spin.
Hi Sachinl, Before you check out the link below read how To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components.(This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
If that did not solve the problem then it may be the "Lid Switch". Top loading washing machines that have a faulty lid switch will not turn the agitator and the spin cycle will not start. However on some washing machine models it will still agitate but not spin. To properly check this you must remove the lid switch.
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 03, 2016 | Whirlpool Washing Machines
Maytag MAH8700 AWM will not spin during rinse cycles
As you said in the question you are washing machine need to get services during rinse washing machines should spin.Try selecting only rinse option only.If it does not spin means just services it will be fine.Thanks for you are question.
Jun 17, 2011 | Maytag Washing Machines
Spin cycle doesn't work
It sounds like the rear bearing has gone bad, was the machine making any loud noises before? Can you move the tub with your hand?
Oct 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Washing Machine AWM 029 is not draining
Hi.
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Thanks
Nov 25, 2008 | Whirlpool Washing Machines
AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
HI, I am having a lot of trouble with my front loader which is only about 4 years old. It seems to become very unbalanced during the coloured wash setting (even with a small load) - and yet is perfectly...
check teco coil on the back of the motor, it may have come loose'its about inch round thing it gives power to the the speed control module circuit board thats why its tumbleing too fast.bye Eamonn Ireland
Jun 11, 2008 | Whirlpool Washing Machines
Whirlpool AWM312/3 Front Loader Washing Machine - not spinning
I would recommend getting the service manual for your model as some models have clutches that control spin and others have belts. The service manual would be the best route if you are planning on repairing this yourself. If you would like the service manual let me know and I will post a link to where you can get one emailed to you.
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Won't spin fast.
sounds like motor control ..but three thing can keep it from not spinning .. Motor control- main control and or door lock... if just the spin cycle it may be the motor control..let me know what you find..
Aug 29, 2007 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
134 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
