Question about Maytag Atlantis MAV6451 Top Load Washer
Water Temperatore problem
Wash machine seems possessed. Doesn't matter what water setting you put it on, it comes out hot for days-on-end then will actually run cold if you have cold selected. When choosing hot, it always works, just won't always accept the cold setting and I choose cold nearly always. Thanks for any suggestions.
  • 185 Answers
Are your hoses switched around
Posted on Apr 01, 2008
The cold water is not working in my washing machine
Check the supply hose filter, and the filter on the intake of the solenoid. Switch the wires on the solenoid to see if rinse will put hot water into the machine, the contact at the timer may be going bad. While reversed, see if it puts cold water into the wash, that will test the solenoid.
Dec 01, 2013 | Maytag Washing Machines
When going to wash with my GW11 it stops during the was cycle and the cold and hot water light blink and the machine beeps
Hi just read your posting.Now, when the hot and cold lights flash at the same time it means that you are not getting enough or no hot or cold water.Remove the cold and hot inlet hoses from the machine end and put the ends into a bucket.Now turn the taps on to see if you have water coming out the hot and cold hose and if the water pressure is adequate.Try a cold fill on the wash cycle and see how it goes.please reply and let me know if there is water coming out of the hoses at a good pressure and also what water temp do you select on the wash cycle.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
No matter what the temp setting is at it only has very hot water
Your water temp is determined by 2 things. First the hook up to your water supply. If you are able to turn off the hot water valve that feeds the unit and then select a cold water only wash, do you get cold water?? If not then someone hooked up the hoses to 2 hot water feeds. If hot and cold feeds are installed right, the second thing is your computer which monitors the incoming temp through the boards atc control and a thermister. If you select cold, and only get a hum and the cold water valve is on, you may have to clean the screens in the valve of any sediment. If no hum, and no cold, dead solenoid on valve, but that would throw an error code usually. All fills are monitored by the board and usually begin with a hot/wrm mix and then changeover to a monitored cold temp , about 70 degrees.
May 05, 2010 | Kenmore Elite 45986 Front Load Washer
I have 2 problems with my AEG Lavamat 981. 1. The drum won't empty out. We have tried using the emergency drain and even removed the hose connecting the drum and the pump(at the pump end) but the water...
first if you drum is filling again after wash you may have a faulty hot or cold inlet valve turn water taps of after wash has finished if no water in drum the next day just a matter of isolating which valve it is
your second problem sounds like you have a blockage in the hose coming out of your drum to the water pump may be that missing sock you were looking for hope this helps let me know how you went
Nov 13, 2009 | Audio Players & Recorders
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Haier Genesis HLT364XXQ CAN'T GET HOT WATER WASH
hey Paul, you don't have to wash anything in hot water. Hot water only wastes money and does nothing, in my opinion, to get anything cleaner. It does ,however set the stains. To kill any thing the water has to be 212 degrees [ boiling ]I have not used hot water for over 40 years and our clothes are coming out clean. Just set the machine on cold. I put a twoway spigot on my cold tap and put the hot water and cold water together incase someone breaks in and does my laundry. Barry
Feb 14, 2009 | Haier HLT364XXQ
Frigidaire washer hot water only
sundsas if you have a bad temp select switch. only selecting hot/hot
Oct 31, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Asko 12605 overheating the wash water
(even not taking in hot water when filling before the wash stage which seems good)
The washer fills with cold water then heats it up 3 degrees a min. Your problem does sound like a faulty thermostat. Especailly if the glass door does get hot even if it is on 85f.
May 29, 2008 | Asko Washing Machines
Bleach and softener dispensers filled with water at end of cycle
what u need to do is take the soap drawer out totally u need to put under the hot tap pull the containers out of the soap drawer and clean out everywhere what happens is the containers have small slits underneath them and when these get blocked it doesnt let the water run out using hot water and a brush to clean everywhere will sort this problem out this is a problem for all washers
Feb 10, 2008 | Washing Machines
Maytag Atlantis MAV6451 Top Load Washer Logo
85 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
