Question about Lands Phones
The connections and the cable with the GN 9120 are too small for my receiver connection. Conversely, the receiver cord is too large to plug intothe GN 9120. Both receiver cable and connection are the standard phone connectors. Are there adapters available, if so, where would I get them from? I would need a small female to large male and a large female to a small male. Thanks. Bill
  • wwrighten Mar 30, 2008
    So basically I am converting a RJ-11 to a RJ-45 and vice versa? Using the bezel, wouldn't the pin placement and contact points be different? Thanks. Bill
    Master:
  • 377 Answers
Here's an idea which the coverter look like..
Extron
PLug & Jack
Thank you.
Posted on Mar 30, 2008
  • 813 Answers
U have get form ur nearest electronic ( electrical ) store
take the sample of it they will give u the same of sample of pice
How can I get replacement cord?
depends on if it is a plug in cord or hard wired to handset .they sell the plug in type any place they sell phones if it's a hard wired unit , then buy a new phone
Jan 14, 2016 | GE 29267GE3 Telephone
Phone connection
By extra cord if you mean the modular cord that connects the phone to the phone jack, you probably received a single and 2 line cord with the phone. Look at the plug if one cord has 2 gold pins and the other has 4 then that is what you have. Either cord would work but if you have only 1 line use the cord with 2 pins. otherwise use the 4 pin one if you have 2 lines.
Apr 15, 2014 | Vtech Lands Phones
I am only using line 1 on the aastra 9120, how do i get "check line cord line 2" off the display?
i have the same issue. considering the following solution; install a splitter to connect both phone ports to a single line.
Sep 24, 2010 | Aastra Telecom 9120 Corded Phone...
When I plug the phone line (Comcast is the provider) into my GN Netcom GN7100 Base it "shorts out" (according to the Comcast Tech) the voice modem and so I can't get a dial tone. This makes it impossible...
1. Be sure the jack on the base unit is clean and that the pins inside are straight. 2. If try line another cord - the cord is often the problem due to twisting or crimping. You can test the cord on another phone if you don't have a spare. 3. Make sure the headset is in the off or "on-hook" position. 4. To see if the unit itself is defective try it at a friend's house. Do other phones work OK on that line?
Aug 11, 2010 | GN Netcom GN 7100 Corded Phone (GN7100)
The phone has a buzz on it and it is not the line it's the phone att945
Buzz may be from many different sources.
First, is there DSL on this line? Make sure you have a filter on the line going to the phone or plug your phone into the jack coming out of the DSL modem.
Next, remove any other device from the line and check the buzz. Sometimes a fax machine, computer or credit card machine will create noise on the line.
Then check the connections in the wall, any splitter and in the phone. Make sure the wires are straight before you plug in the phone cord.
If that does not help, take a regular phone and plug each wire into that phone and listen for the buzz, it may be a pinched wire.
Or, you may have a wire running past something that has a large electrical current. Try moving the wires away from a television, florescent light, etc.
Lastly, these phones have a cable length maximum. If you have too much cable in the office they will act as an antenna and this will add buzz to the line.
Feb 10, 2010 | AT&T ATT-945 Corded Phone
Do the Norstar M7208 and Aastra 9120 phones compatible on the same PBX? I have a M7208 that works fine on current PBX, but new Aastra 9120 doesn't work. Should they both operate on the same PBX?
No, the M7208 is a propriatary set which requires the PBX to function, whereas the aastra phone is a stand alone set which requires a standard telephone line and a power source.
Dec 23, 2009 | NorStar M7208 Corded Phone
AAstra 9120 - i am currently using only one line. how do i get
Turn phone upside down and look for a little ***** switch that says 1 -- 2 -- 1+2 and slide it to the "1" position.
Mar 13, 2009 | Aastra Telecom 9120 Corded Phone...
DTU 16D-2 Corded Phone
headset key has to be programmed on a key for it to work properly
Jan 23, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Lands Phones Logo
117 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
