Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Screen image goes out
Periodically, screen "cuts off". TV is on but no sound either. TV is about 2 years old. You can still see menu prompts on screen if you call them up but not the broadcast image---will not show DVD as well during this time. Have re-routed cable to bypass box and changed outlets but still has the problem.
It will come back on after a while of "on/offs" then go out again. The times it goes and comes back appear random.
  • jessedunbar Apr 03, 2008
    The picture will flicker in and out until it finally goes out. If I let the tv sit for a while it comes back on then does the same thing. The sound never goes out.
    Sergeant:
    Champion:
  • 375 Answers
Sounds like a problem or cold solder connections in the video section or b+ vlotage missing muting the video.
Posted on Apr 13, 2008
SOURCE:
Hi I hv a toshiba smart tv it's two years old , it comes on but does not hv pic it does hv sound
if you choose the menu does it display menu items or is there no image at all? No image at all when you press menu would mean the backlight is likely not working and requires repair. If you do get menu items on screen check the image settings and ramp up brightness and contrast
Jan 14, 2016 | Toshiba Televison & Video
My TV has sound but screen is dark
Go into menu settings of tv and look to see if the energy saving box is ticked.this is usually designed to run by selection of user not by default from factory.you may even have an intelligent saver which can detect if the screen is using a lot of power when the image is predominantly white as opposed to black so it turns the brightness down.too clever for its own good!
Nov 16, 2015 | Toshiba 50 Class 1080p 120Hz LED Smart HD...
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
Negative type images in pink & lime green
I had the same problem....turned out it was the "lvds" cable that runs from the mainboard to the lcd controller board. Simply remove the tape that holds it to the back of the backlight housing and also remove the foil shielding tape from the connector on the lcd controller board.
Sep 01, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
No video in any of the TV inputs
first try resetting and rebooting. reset = menu, 2470, enter.
reset is press reset button and wait for green lite to stop blinking.
if that takes care of it great. if not it sounds like a signal board or dm problem and will need repair. check out www.tv-techs.com
Sep 06, 2008 | Mitsubishi WD62628 62" Projection HDTV
Projection TV problem
sounds like the vertical deflection is causing the CRTs to blank cause you still have sound and on screen displays. Try resoldering the vertical output IC see if that helps. If not you may need a new vertical output IC. Let me know if i can assist you further.
Apr 04, 2008 | Hitachi 51F510 51" Rear Projection...
Hitachi 51F510
Same problem but mine goes black for long periods. Menu prompts still available and volume "meter" on screen is still visible. Have rerouted cable, changed outlets, all to no avail.
Mar 28, 2008 | Hitachi 51F510 51" Rear Projection...
Aging 43H7143
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
2 year old Samsung 50" DLP
Sounds like a bad digital board to me. Not too hard to replace in those models but, you do have to write down a few settings before replacing it. These settings are available in the service menu. Any questions let me know [email protected]
Nov 30, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
75 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
