Question about Keurig B60 Coffee Maker
The Keurig is heating up the water, yet is does
The keurig is heating up the water yet is does not dispense/pour into the cup. Almost like it is clogged all of a sudden somehow. Makes the usual brewing soundsoises...but no water pours into the cup I have the single per cup unit - no water reserve like the large Keurig's
  • 40 Answers
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
Posted on Oct 07, 2010
  • 8 more comments
  • donnajonel Nov 15, 2010
    Thank you so much! This worked for me and I am truly appreciative!
  • Diceman51 Nov 15, 2010
    You are certainly welcome. I love my unit and don't want to even think of having to order parts, wait for delivery, "fix it" and only to have spent money needlessly, still not work due to the clog and more importantly having gone without coffee during this time. :)
  • b1jassc Nov 19, 2010
    OK, so the symptom sounds the same as the issue I had, but when I tried it - no luck. The only symptom not mentioned is that when trying to brew, just the large cup option is flashing. Any thoughts?
  • Diceman51 Nov 19, 2010
    Sorry, I haven't experienced only one light blinking.
  • crossonm Nov 20, 2010
    Thanks! I had to do it three or four times before the water flowed smoothly, but it worked perfectly in the end. Following up with a de-scaling and I should be back in business.
  • Laylun Nov 26, 2010
    Thanks... you saved me a hassled trip returing my beloved machine to the store.
  • Diceman51 Nov 26, 2010
  • abkb1 Nov 26, 2010
    This worked for me. Thanks. Looks like the grinds clogs it up. Took a year for this to happen to me.
  • Drleostev Jan 19, 2011
    I have the exact same problem. No water, only the large cup option is flashing
  • bytheC312 Jun 11, 2011
    I was skeptical that something so simple would fix my beloved Keurig but it worked. Thanks for sharing and saving me $$$ because I likely would have gone out and bought another one today.
  • 3 Answers
So I had this same problem the fix was pretty simple. Air had gotten into the fill line and the pump couldn't pump the air filled line. So to get rid of the air try to brew a cup of coffee (make sure you have a cup under) now cover the over flow at the top of your water reservoir with your finger or thumb. Air bubbles should blow into you water storage tank. Once the bubbles are gone remove your thumb or finger. Now try to brew a cup of coffee again.
--snapshot4
Posted on Jan 07, 2011
    Sniper:
  • 67 Answers
The pump definatly has broken,it is a problem with these machines a know of a great site that sells replacement parts and all kinds of keurig accessories i know this site http://stores.ilikenew.com it has tons of keurig parts
Posted on Nov 12, 2010
Frigidare top loading washing machine, 1995 model # GLMS174SAS4
I believe the softener is dispensed through centrifugal force when the machine is in the high speed spin after draining and before filling for the rinse cycle. I had the same issue on another machine. Use very hot water and a washcloth to clean out the softener cup. When adding softener at the beginning of the load, only add the recommended amount and then fill the remainder of the cup with water.
Mar 06, 2015 | Washing Machines
The descale light keeps blinking, what should I do?
The 'Descale' light that turns on indicates that it is time to de-scale the machine.
Scale - or mineral deposits- form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water.
You will need :
  • Keurig coffee maker
  • 48 oz. white distilled vinegar
  • Water
  • Large ceramic cup
  • Sink
Instructions :
  • 1 Unplug the coffee machine and remove the cup.
  • 2 Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
  • 3 Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
  • 4 Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
  • 5 Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
  • Good luck ;)
    Dec 14, 2011 | Keurig Elite B40 Coffee Maker
    Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
    Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
    Keurig CoffeeBrewer not making a full cup of Coffee
    heatman101
    Feb 02, 2011 | Keurig B70 Coffee Maker
    The coffemaker won't brew and showed a descale message. What does that mean?
    Scale---or mineral deposits---form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water
    1.Unplug the coffee machine and remove the cup.
    2.Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
    3.Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
    4.Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
    5.Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
    6.Unplug the machine and dump the water into the sink.
    7.Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue
    Dec 10, 2010 | Keurig B70 Coffee Maker
    Keurig B60 Coffee Maker Logo
    4,542 people viewed this question
    Top Keurig Coffee Makers & Espresso Machines Experts
    Lisa
    Lisa
    Jason
    Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
