Computers & Internet Logo
A
Anonymous Posted on May 13, 2010
Computer wont turn at all worked fine the night before moniter works no lights dvd door wont open
Anonymous
Level 2:
New Friend:
  • Expert 66 Answers
  • Posted on May 15, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
66
Questions
0
Helped
14735
Points
119
If the unit worked last night and now it will not turn on then it's one of two issues. first we need to look at the unit are there lights or can you hear a fan running . if so your motherboatrd has failed , and the fact that most dell mobo's have intergrated video you couldn't see anything at that point. two if there is no lights or fans running and you can not open any drives then your power supply has filed . decide witch one and let me know if you dell is still under warranty i can call and do a warranty claim and get them to send parts and a tech if not give me the service tag number and I can find part numbers for you . hope this helps
1 Related Answer
Anonymous
  • 14 Answers
  • Posted on Mar 22, 2010
SOURCE: computer wont turn at all worked fine the night
sounds like the power source or bad motherboard
My garage door lights wont work. the door works fine just at night and during the day the lights wont come on
At the risk of sounding stupid, I have to ask "did you replace the light?" There is a circuit board inside the opener that senses the door is operating. That turn on the light and then times how long it stays on. That circuit board could be bad, or the light socket could be bad, or the light is burned out.Good luck.
Thanks for using FixYa.
Gaker
Jun 19, 2011 • Garden
Why f257 turns on no picture light blinking?
Sounds like you have a video card issues..Also try turning off Monitor first, then shutdown PC. Then Turn monitor back on first then PC..It should sync up...
Dvd player is recognized but cannot read anything
please send the dvd drive for service to your nearest acer service centre....
1helpful
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Screen black
if monitor light is on, check the connecting data cable if it is ok then consult a technician.
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Grand Canyon Tech
Grand Canyon Tech
